ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class
    SymbolFactory Class Methods
    For a list of all members of this type, see SymbolFactory members.
    Public Methods
     NameDescription
    Public MethodConstructs a fill. The default color is ColorFactory.GreyRGB.
    Public MethodOverloaded.
    Public Method Constructs a marker from a bitmap source.
    Public Method Constructs a marker from file. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Constructs a marker from a stream.
    Public Method Constructs the marker outline for the given marker style. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Constructs a picture fill with the specified parameters.
    Public MethodConstructs a polygon symbol in the specified color representing a pen and ink cross hatch effect. See Pen and Ink styles
    Public MethodConstructs a polygon symbol in the specified color representing a pen and ink ripple water fill. See Pen and Ink styles
    Public MethodConstructs a polygon symbol in the specified color representing a pen and ink stipple effect. See Pen and Ink styles
    Public Method Create a symbol reference with a procedural symbol layer for a rule package. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Constructs a solid fill of specific color.
    Public Method Generates an image for point symbols.
    Public Method Gets the list of available fonts in the application for the Pro session. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Builds a symbol from a dictionary. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Populate the associated rule package description. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Check if a specific font is available in the application for the Pro session. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Checks the compatibility of the rule package geometry with the feature layer shape type for use as a renderer. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Checks if the underlying shape type of the layer features is supported for use with rule package renderers. This method must be called on the MCT. Use QueuedTask.Run.
    Top
