Attribute rules
许可门户需要 ArcGIS Topographic Mapping 许可。
The product data files for the ArcGIS Topographic Mapping extension include schema geodatabases with preconfigured attribute rules that can be applied to Multinational Geospatial Co-production Program (MGCP) and Topographic Data Store (TDS) data using ArcGIS Data Reviewer checks. The schema geodatabases include support for MGCP and TDS data beginning at the following versions:
  • MGCP TRD 4.6
  • TDS 7.1
Supported rule types
The schema geodatabases for the Topographic Mapping extension include constraint attribute rules and validation attribute rules.
注:
The preconfigured constraint attribute rules are not enabled by default. When enabled, feature edits that violate constraint rules cannot be saved and are rolled back, which may be an unintended consequence.
Error layers
The schema geodatabases include attribute rule error layers that store the error features identified by validation rules. These layers consist of three feature classes and a table that store and manage the errors that are found during attribute rule evaluation.
You can manage attribute rule errors using the error inspector table in ArcGIS Pro.
Preconfigured rules
The table below contains information about the preconfigured attribute rules that are included with the schema geodatabases.
注:
Constraint attribute rules are configured to be applied when an Insert or Update action takes place.
Rule name
Geometry types
Rule types
Details
Data model type
Check Geometry
Areas
Lines
Points
Validation
Identifies features with invalid geometry.
MGCP
TDS
Cutbacks
Areas
Lines
Constraint
Validation
Identifies cutbacks with an angle size of less than 10 degrees.
MGCP
TDS
Domain
Areas
Lines
Points
Validation
Identifies rows or features that violate domain constraints.
MGCP
TDS
Duplicate Feature
Areas
Lines
Points
Validation
Identifies features that are duplicated in geometry, feature type, and attribution.
MGCP
TDS
Duplicate Vertex
Areas
Lines
Constraint
Validation
Identifies features that have consecutive duplicate vertices.
MGCP
TDS
Evaluate Part Count
Areas
Lines
Constraint
Validation
Identifies polygon or polyline features with more or less than one part.
MGCP
TDS
Evaluate Polygon Perimeter and Area
Areas
Constraint
Validation
Identifies polygons with a perimeter that is less than 5 meters.
MGCP
TDS
Validation
Identifies polyline features that contain a segment with a length less than 0.02 meters.
MGCP
TDS
Evaluate Polyline Length
Lines
Constraint
Validation
Identifies polyline features with a length less than 5 meters.
MGCP
TDS
Constraint
Validation
Identifies features that contain a segment with a length less than 0.02 meters.
MGCP
TDS
Find Dangles
Lines
Validation
Identifies polyline features that have nodes that are within 10 meters, but are not connected to other polyline or polygon features.
MGCP
TDS
Nonlinear Segment
Areas
Lines
Validation
Identifies nonlinear segment geometries from polygon or polyline features that have nonlinear segments.
MGCP
TDS
Polygon Sliver
Areas
Validation
Identifies area features that have an area to perimeter ratio less than 0.09.
MGCP
TDS
Subtype
Areas
Lines
Points
Validation
Identifies features that have invalid subtypes.
TDS
Unique Field Value
Areas
Lines
Points
Validation
Identifies features with identifier field (GFID or UID) values that are not unique.
MGCP
TDS
Unnecessary Nodes
Lines
Constraint
Validation
Identifies node—if database topology exists—or polyline—if no database topology exists—geometries that share a node and have identical attribution on editable fields.
提示:
Running this check with a database topology improves performance.
MGCP
TDS
Unnecessary Polygon Boundaries
Areas
Constraint
Validation
Identifies area features that border another area feature with the same attribution.
MGCP
TDS
