Get started with Pipeline Referencing
Available with Location Referencing license.
ArcGIS Pipeline Referencing is an extension targeted at meeting the location referencing needs of the transmission pipeline industry. The extension provides capabilities to manage linear referencing system (LRS) networks used to locate assets, characteristics, and other data on and around transmission pipeline networks. This is achieved by providing a linear referencing system that evolves and extends the original set of LRS capabilities present in ArcGIS today.
In ArcGIS Pro 3.8, the tools on the Location Referencing tab will be moved to the Linear Referencing tab.
Pipeline Referencing provides a GIS-enabled, linear referencing data management solution for pipeline organizations. It supports the following:
LRS information model
Network and event loading tools
Network editing
Event editing
Geoprocessing tools
Web services
Learn more about installation and licensing in ArcGIS Pro
LRS data model
To use Pipeline Referencing, you must have your data in the LRS data model. Pipeline Referencing has a data model for LRS Networks (routes) and a flexible data model for LRS events that allow you to model your own event feature classes.
Pipeline Referencing provides the ability to edit and maintain LRS Networks and associated event data. It also supports updating event measures and route associations based on changes to an LRS Network.
Before using Pipeline Referencing tools, read the information on the foundational concepts behind the LRS Network and LRS events information model. These concepts not only aid in understanding the data loading process, but also set the foundation for how to use the tools.
Utility and Pipeline Data Model (UPDM)
The Utility and Pipeline Data Model (UPDM) includes predefined feature classes for events and features in the pipeline network. The UPDM is based on the data model used by Pipeline Referencing.
With Pipeline Referencing, you have the flexibility to define your own events data model or use the UPDM.
You can create the UPDM schema in a file geodatabase and load all the required data. Once the data is loaded, you can migrate your LRS to an enterprise geodatabase.
You can model your own LRS geodatabase using the UPDM or an out-of-the-box data model that requires you to create an LRS, create LRS events, and load event data using the Append Events tool.
Modeling an LRS geodatabase is an involved process and is recommended only for people with experience.
Learn more about managing Pipeline Referencing and a Utility Network together
LRS Network and event loading
The modeling, creation, and configuration of the LRS, networks, and events, including route and event loading, are managed in ArcGIS Pro using geoprocessing tools.
Learn more about creating the LRS, networks, and events
Use the Append Routes tool to load routes. Both continuous and engineering networks can be loaded.
Use the Append Events tool to load events. Both event tables and event feature classes can be loaded.
LRS Network editing
To edit LRS Networks, you must use the Location Referencing tab that is part of Pipeline Referencing. This tab supports editing the Pipeline Referencing information model elements used to build an LRS network. On this tab, you can create a route, realign a route, reassign a route, retire a route, extend a route, and cartographically realign routes. You can also edit calibration points and centerlines. You can't edit LRS route directions, but you can use these tools to apply edits to the LRS routes. The Location Referencing tab is context based and is available only when you have LRS data added to a map.
Pipeline Referencing features (routes, events, calibration points, and intersections) are time-aware. If you are configuring maps for editing networks, it is recommended that you configure time support for each of these layers in the map.
LRS event editing
Pipeline Referencing supports event editing through Experience Builder widgets.
Experience Builder is powered by ArcGIS Enterprise.
Learn more about using Experience Builder and deploying Location Referencing widgets
LRS geoprocessing tools
Pipeline Referencing includes a suite of geoprocessing tools that support LRS data loading, processing, and transformations.
LRS web services
Pipeline Referencing extends the ArcGIS Server map service to provide linear referencing capability to your data as REST services. These capabilities include the following:
Event editing
Translating coordinates to measures
Translating measures to coordinates
Translating between measures systems
Dynamically segmenting event layers
Detecting gaps, overlaps, and invalid measures on events
For more information about services and developing for services, refer to the following:
Quality control
Pipeline Referencing provides quality control checks for LRS Networks and event data. In addition, Pipeline Referencing includes ArcGIS Data Reviewer, a feature set that extends the ArcGIS software for checking data and managing data errors.
Learn more about ArcGIS Data Reviewer
Workflow management
Pipeline Referencing includes access to standard ArcGIS Workflow Manager capabilities that you can use to manage workflows across business units and develop a standardized process for LRS data management in your organization.
