Create the LRS, networks, events, and intersections
Available with Location Referencing license.
The following information describes the process of linear referenced data modeling, loading, and route editing using the ArcGIS Pipeline Referencing extension.
LRS dataset
A linear referencing system (LRS) dataset is a controller dataset in a feature dataset in the geodatabase along with all the feature classes that participate in the LRS.
You can view the LRS hierarchy from either the Contents pane or the Catalog pane.
The LRS dataset is visible only in ArcGIS Pro. An error message appears if a geodatabase that contains the LRS dataset is opened in ArcMap.
The following tools create an LRS dataset:
  • Create LRS—The newly created centerline, calibration point, and redline feature classes are placed in a feature dataset with the same name as the provided LRS name.
  • Create LRS From Existing Dataset—The existing centerline, calibration point, and redline feature classes that are not yet registered with an LRS must be in a common feature dataset. The feature dataset name can be different from the LRS name.
All tools in the Location Referencing toolbox require an LRS dataset to run.
Use the Migrate Object ID to 64 Bit tool to migrate the LRS dataset to 64-bit Object IDs.
Upgrading a dataset to 64-bit Object IDs is useful when Object ID values exceed 2.1 billion or if data is coming from cloud data warehouses.
Learn more about migrating to a 64-bit Object ID
You can review some of the information contained in the LRS dataset using the arcpy.Describe function. To review the LRS metadata and event behavior rules for a geodatabase with an LRS dataset, use the following functions:
FileGDB:
desc = arcpy.Describe("C:\\Data\\LRData\\LrsSchema.gdb\\Lrs\\Lrs")
lrsXML = desc.lrsMetadata
eventBehaviors = desc.eventBehaviorRules
EnterpriseGDB:
desc = arcpy.Describe("C:\\Data\\LRData\\LrsSchema.sde\\GPRefresh.DBO.LRS\\GPRefresh.DBO.LRS")
Writing to a file:
txtFile = open("C:\\Data\\LRData\\lrsXML.xml", "w")
txtFile.write(lrsXML)
txtFile.close()
Data modeling
Pipeline professionals are routinely tasked with considering alternative routing options to ensure regulatory compliance, market, construction, and other business needs. This usually results in realigning (rerouting) a pipeline. Realignment not only changes the pathway of pipes but also impacts networks and events configured in a linear referencing system (LRS) data model.
To use Pipeline Referencing, your data must adhere to the LRS data model.
Learn more about Tolerance and resolution settings for the LRS and the Events data model.
Configure an LRS
To create and configure an LRS, complete the following steps:
  1. Create and modify an LRS.
    You can use either the Create LRS tool or the Create LRS From Existing Dataset tool to create an LRS.
    To modify an existing LRS, including enabling conflict prevention in the LRS, use the Modify LRS tool.
    Learn more about creating and modifying an LRS
    If you have existing point features that can be used as calibration points, use the Append tool to append the point features to the calibration point feature class before loading routes into the LRS Network (step 5 below).
  2. Create an LRS network using one of the following tools:
    To modify an existing LRS Network, use the Modify LRS Network tool.
    Learn more about creating and modifying an LRS Network
  3. Create LRS events using one of the following tools:
    To add derived measure fields to the event feature class, use the Enable Derived Measure Fields tool.
    To add referent fields to the event feature class, use the Enable Referent Fields tool. This tool enables the referent fields by allowing you to register existing fields as referent fields.
    To modify an existing LRS event, use the Modify LRS Event tool.
    Learn more about creating and modifying LRS events
  4. Create LRS intersections using one of the following tools:
    To add intersections to the intersection feature class, use the Generate Intersections tool.
    To modify an existing LRS intersection feature class, use the Modify LRS Intersection tool.
    Learn more about creating and modifying LRS intersections
  5. Load routes into the LRS Network using the Append Routes tool.
    Route shapes can be regenerated using the Generate Routes tool.
    Learn more about loading routes into an existing LRS Network
    Learn more about setting gap calibration rules for an LRS Network
  6. Create calibration points using the Generate Calibration Points tool.
    If you have existing point features that can be used as calibration points, use the Append tool to append the point features to the calibration point feature class before loading routes into the LRS Network (step 5 above).
  7. Prepare centerlines.
    To remove overlaps that may cause data errors, use the Remove Overlapping Centerlines tool.
  8. Load event data using the Append Events tool.
  9. Configure a derived network.
    You can use either the Create LRS Network tool or the Create LRS Network From Existing Dataset tool with the Derive From Line Network parameter checked.
    Learn more about how to configure a derived network
Realign and reroute data
Use the following tools to realign (reroute) and maintain linear referenced data:
Route editing workflows
Similar workflows can be created for other route editing activities such as create, extend, reassign, retire, calibrate, and cartographic realignment.
The following table lists the steps required for editing and maintaining pipeline data:
Step
Workflow
Create
Calibrate
Cartographic Realignment
Extend
Realign
Reassign
Retire
Create a centerline.
Yes
No
No
Yes
No
No
No
Perform the editing activity.
Yes
N/A
N/A
Yes
Yes
Yes
Yes
Run the Apply Event Behaviors tool.
No
Yes
Yes
Yes
Yes
Yes
Yes
If you have a derived network configured, run the Generate Routes tool.
Yes
Yes
No
Yes
Yes
Yes
Yes
If you have a derived network configured, run the Derive Event Measures tool.
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Route edit activity table
If additional LRS networks or line networks are configured, repeat the edit activity for each affected network.
Update event behaviors, route shapes, and derived network information for each affected network using the following tools:
