Geoprocessing tools that use credits
Several geoprocessing tools consume ArcGIS credits when they are run. These tools can be used in the same way as other geoprocessing tools. The only difference is you must be signed in to an ArcGIS Online organizational account and your username must have privileges to use the tool. For example, to use the Enrich tool, you must be signed in to ArcGIS Online, and your account must have GeoEnrichment privileges.
Caution:
Credit rates may change. See Credits for current rates.
Estimate credits
Many tools that consume credits require you to estimate the number of credits needed before running the tool. To get the estimate, fill in the tool parameters using the data and settings you intend to use, then in the banner at the top of the tool, click estimate credits. An estimate of the number of credits will display in the banner, as well as the number of available credits if enabled by your organization's admin. If your account or organization does not have enough available credits to run the tool based on the estimate, an error will display in the banner at the top of the tool. Altering the value of any tool parameter will reset the banner. You can then re-estimate the number of credits.
Restricted status
Your organization may be in restricted status if it runs out of credits. This restriction will block the running of tools that consume credits. If your organization is restricted, an error appears in the banner at the top of the tool after attempting to estimate credits.
Learn more about organization status
Analysis tools
Tool
Credit consumption
Example
Enrich
Uses credits unless you've installed and selected a Business Analyst data source. Credit consumption is 1 credit per 100 variables or features. If a drive time is used to define areas to enrich, additional credit consumption is 0.5 credits per drive time.
You can enrich 100 features with 1 variable and the cost will be 1 credit, or you can enrich 50 features with 4 variables and the cost will be 2 credits. If you enrich a 20-minute drive time around 20 points with 5 enrichment variables, the cost will be 11 credits.
Summarize Nearby
Uses credits when you run the tool using a network-based Distance Measurement setting, such as Driving time or Driving distance. Credit consumption is 0.5 credits per distance and per feature.
If there are 10 input features and you summarize within a driving time of 10 minutes, the cost will be 5 credits.
Business Analyst tools
The following Business Analyst tools will consume credits if ArcGIS Online is the active Business Analyst data source. Some of the Business Analyst tools listed below use a credit estimator.
Credit consumption estimates may differ slightly from the amount used during processing. For example, generating multiple radii within an Arcade expression or clearing selected features prior to running the tool may result in higher credit usage.
Tool
Credit consumption
Example
Assign Customers By Distance
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is .00005 credits per input origin and destination pair.
If there are 10 store origins and 2,000 customer destinations, the cost will be 10 credits.
Add Variable Based Suitability Criteria
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 1 credit per 100 attributes (data variables multiplied by the number of input features).
Benchmark Comparisons
You can enrich 25 features with 4 variables and the cost will be 1 credit. The cost for enriching 50 features with 5 variables will be 2.5 credits.
Color Coded Layer
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Running the tool does not consume credits; however, every map request made to the output color-coded layer will result in 1 credit per 100 map requests (pan, zoom, and identify).
You can select one variable as a color-coded layer. If you then pan or zoom the map 100 times, the cost will be 1 credit.
Enrich Layer
Find Nearby Locations
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 0.0005 credits per input origin-destination pair. The first distance limit parameter met is used to determine consumption.
A 10 (origins) by 100 (destinations) matrix will generate 1,000 origin-destination pairs, and the cost will be 0.5 credits.
Generate Approximate Drive Times
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 0.5 credits per iteration of the tool. There may be between 3 and 5 iterations before a drive-time polygon is generated.
If you run the tool for 20 locations, each location may need 5 iterations to generate a drive-time polygon. If the tool completes 5 iterations for 20 locations, the result is 20 * 5 * 0.5 = 50 credits.
Generate Customer Derived Trade Areas
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credits are consumed only when the trade area method is set to Threshold Drive Time. Internally, two operations incur credits: Threshold Drive Time per iteration (0.5 credits per polygon) and GeoEnrichment request (0.01 credits per view).
A Threshold Drive Time takes approximately 6 to 12 iterations to reach one drive-time polygon. Restrict the number of iterations with the Iterations Limit parameter.
If you run threshold drive times for two locations, each location may need 10 iterations to reach the threshold variable, followed by one GeoEnrichment request to retrieve the selected variable, resulting in 10.1 credits used.
Generate Desire Lines
A 10 (origin) by 100 (destinations) matrix will generate 1,000 origin-destination pairs, and the cost will be 0.5 credits.
Generate Drive Time Trade Area
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 0.5 credits per drive-time polygon.
If there are 10 facilities and you specify 5- and 10-minute drive times, the total cost will be 10 credits.
Generate Grids and Hexagons
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credits are only consumed when the Enrichment Type parameter is specified. The number of grids or hexagons created by the tool depends on the Cell Size or the H3 Resolution parameter specified for the Area of Interest.
Drive-time trade areas will first be computed when using the Enrich Buffer option as the Enrichment Type parameter value and specifying a Distance Type parameter value other than the Straight Line option. Employing an option other than Straight Line will result in substantially more credits being consumed in comparison to the Enrich Cell or Enrich Buffer options with a Distance Type parameter value of Straight Line.
The Enrich Cell option performs enrichment only. An output of 10 squares or hexagons with one variable will consume 0.1 credits.
The Enrich Buffer option will first generate trade areas and then perform enrichment. An output of 10 squares or hexagons with one variable will consume 5.1 credits: 5 credits for 10 buffers and 0.1 for enrichment of those buffers. Only distance type, other than straight line, consumes credits.
The credit banner shows an estimate of the credits that will be consumed. It is not an actual amount that will be charged.
Generate Points From Business Listings
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 10 credits per 1,000 business records downloaded.
You can search for all businesses in an extent and initially locate 1,000 and filter the results to 500 businesses. If you run this analysis and save the outputted records locally as a layer, the cost will be 5 credits.
Generate Threshold Drive Times
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credits are consumed for each Threshold Drive Time per iteration (0.5 credits per polygon) and GeoEnrichment request (0.01 credits per view).
Generate Threshold Rings
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credits are consumed for each GeoEnrichment request per iteration (0.01 credits).
A Threshold ring may take approximately 15 iterations to reach one ring polygon.
If you run threshold rings for 10 locations, each location may need 15 iterations to reach the threshold variable, resulting in 1.5 credits used.
Measure Cannibalization
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credits are only consumed if variables are added from the data browser as additional metrics. Credit consumption is 1 credit per 100 attributes (data variables multiplied by the number of input features).
You can enrich 25 features with 4 variables and the cost will be 1 credit, or you can enrich 10 features with 20 variables and the cost will be 2 credits.
Summary Reports
Uses credits when you use ArcGIS Online as the active Business Analyst data source. Credit consumption is 10 credits per report.
If you run 10 reports on one trade area, the cost will be 100 credits, regardless of the number of pages per report.
Geocoding tools
The following geocoding tools will consume credits when you run the tool using the ArcGIS World Geocoding Service as the input address locator.
Tool
Credit consumption
Example
Batch Geocode
Uses 40 credits per 1,000 addresses geocoded.
If the address table has 1,000 rows, the cost will be 40 credits.
Geocode Addresses
Rematch Addresses
Uses 40 credits per 1,000 addresses rematched.
If the geocode results layer has 1,000 unmatched rows, the cost will be 40 credits.
Reverse Geocode
If the input layer has 1,000 points, the cost will be 40 credits.
Network Analyst tools
The following Network Analyst tools will consume credits when the network analysis layer references ArcGIS Online as the network data source, or when you use a server connection to logistics.arcgis.com.
Tool
Credit consumption
Example
Solve
Credit consumption is determined by the type of network analysis layer you're solving.
See the table to determine credit consumption for various types of analysis.
The service tools below can be accessed at http://logistics.arcgis.com/arcgis/services
Find Closest Facilities
Uses 0.5 credits per closest facilities route.
If there are 10 incident points and 2 facilities, the cost will be 5 credits if all 10 incident points can be successfully routed to a facility.
Find Routes
Uses 0.005 credits per simple route.
Uses 0.5 credits per optimized route.
If there are 2 stops, the cost of the route will be 0.005 credits. If there are 10 stops, the cost of the route remains 0.005 credits. For these routes, the order of stops is determined by the order of the records in the stops table. If you choose the option to reorder the stops to optimize travel time, the cost will be 0.5 credits.
Generate Service Areas
Uses 0.5 credits per service area or drive time.
If there are 10 facilities and you specify drive times of 5 and 10 minutes, the cost will be 10 credits.
Origin Destination Cost Matrix
Uses 0.0005 credits per input origin and destination pair.
If there are 100 origins and 200 destinations, the cost will be 10 credits. If you specify a cutoff, or limit the number of destinations, such as to find only the 5 closest destinations within 10 minutes of every origin, the cost will still be 10 credits, as the credits depend on the number of input origin-destination pairs.
Solve Last Mile Delivery
Uses 0.3 credits per input order.
If you're routing 5 vehicles through 100 total orders, the cost will be 30 credits. If only 80 out of 100 orders are assigned to routes, the cost will still be 30 credits. If no orders are assigned to any routes, there is no cost.
Solve Location Allocation
Uses 0.1 credits per demand point.
If there are 5 facilities to evaluate and 100 demand points to allocate to those facilities, the cost will be 10 credits.
Solve Vehicle Routing Problem
Uses 1 credit per VRP route.
If you're routing 5 vehicles through 100 total stops, the cost will be 5 credits.
Public Transit tools
Tool
Credit consumption
Example
Calculate Transit Service Frequency
Uses credits when you calculate the frequency of public transit service at points of interest or in areas and use ArcGIS Online as the network data source.
When calculating the frequency of public transit service for areas, the tool internally uses the Service Area service. Credit consumption is the same as for the Generate Service Areas tool documented in the Network Analyst tools section. The exact number of credits used depends on the number of public transit stops in the system (used as facilities).
When calculating the frequency of public transit service for points of interest, the tool internally uses the Origin Destination Cost Matrix service. Credit consumption is the same as for the Origin Destination Cost Matrix tool documented in the Network Analyst tools section. The exact number of credits used depends on the number of features in the input points of interest (used as origins) and the number of public transit stops in the system (used as destinations).
If you use a travel distance limit, the tool attempts to reduce the OD Cost Matrix size using a simple straight-line distance selection first. This may eliminate some origins and destinations from the OD Cost Matrix analysis in advance, thus reducing the number of credits needed. In this case, the number of origin-destination pairs will always be less than or equal to the number of points of interest times the number of public transit stops. This optimization is not possible if the travel limit is not based on distance, however. In that case, the number of origin-destination pairs is exactly the number of points of interest times the number of public transit stops.
If the number of inputs is large enough to exceed the number of allowed inputs for a single analysis run by the service, the tool will split the inputs into chunks. If the travel limit is based on distance, the tool will repeat the simple straight-line selection for each chunk. When this is the case, you can further reduce the problem size by spatially sorting the input data using the Sort tool with the Spatial Sort Method parameter's Peano option prior to running the Calculate Transit Service Frequency tool. Sorted data yields clustered chunks, which increases the likelihood of eliminating a larger number of irrelevant destinations for each chunk of origins. See the origin and destination limits for the OD Cost Matrix service
If you are calculating the frequency of public transit for areas, and your public transit system has 1,000 stops, you will be generating 1,000 service area polygons. At a cost of 0.5 credits per service area, running the tool will consume 500 credits.
If you are calculating the frequency of public transit at 10 points of interest, and your public transit system has 1,000 stops, you will have 10 origins and 1,000 destinations, or 10,000 origin-destination pairs. At a cost of 0.0005 credits per origin-destination pair, running the tool will consume a maximum of 5 credits. The tool may consume fewer credits due to optimizations that reduce the problem size prior to calling the OD Cost Matrix service.
Generate Shapes Features From GTFS
Uses credits when you generate shapes based on a road network and use ArcGIS Online as the network data source.
Internally, the tool uses the Route service. Credit consumption is the same as for the Find Routes tool's simple route option documented in the Network Analyst tools section.
The tool calculates one simple route per unique shape required by your transit system. Each shape represents a unique sequence of stops used by a transit vehicle. In general, the number of shapes required is at minimum the number of routes present in your GTFS data, but often each route requires multiple shapes. For a typical transit system, the number of shapes may be two or three times greater than the number of routes. It is not possible to calculate the exact number in advance of running the tool because the tool must analyze the entire GTFS dataset to find all unique sequences of stops.
No credits are consumed if you use a network dataset as the network data source or if you generate shapes using straight lines instead of a road network.
If your GTFS dataset requires 100 shapes, 100 simple routes will be calculated. At 0.005 credits per simple route, running the tool will consume 0.5 credits.
Ready to use service tools
These services are hosted on ArcGIS Online. The tools can be accessed in the Ready To Use tools gallery or through an ArcGIS Server connection.
Elevation
These service tools can be accessed at http://elevation.arcgis.com/arcgis/services.
Elevation tools no longer consume credits and can be used for free.
  • Profile
  • Summarize Elevation
  • Viewshed
Hydrology
These service tools can be accessed at http://hydro.arcgis.com/arcgis/services.
Hydrology tools no longer consume credits and can be used for free.
  • Trace Downstream
  • Watershed
