Tools that are not available in ArcGIS Pro
ArcGIS Desktop has approximately 1,000 tools. ArcGIS Pro, a newer and more modern technology, has more than double the number of tools. With each release, the collection of tools in ArcGIS Pro continues to expand.
While the majority of the tools from ArcGIS Desktop are also in ArcGIS Pro, a few are not.
Tools from ArcGIS Desktop that are not in ArcGIS Pro are often tied to legacy data formats or have been eclipsed by improved tools and practices. For example, tools related to raster catalogs have been replaced with tools that work with mosaic datasets. Tools that work with geometric networks have been supplanted by tools that work with trace networks and utility networks. Metadata-related tools have been superseded by functionality in the arcpy.metadata module.
The sections below list specific toolboxes and tools that are no longer available. Many tools have alternatives, which are described.
To evaluate your tools, models, and scripts for compatibility issues, use the Analyze script and model tools for ArcGIS Pro compatibility option or the Analyze Tools For Pro tool.
3D Analyst tools
- Export To 3D Web Scene
Learn about exporting scene layer packages that can be viewed in a web scene
Bathymetry tools
- Export BIS Metadata
Coverage tools
Coverages are a legacy format that is not supported in ArcGIS Pro, so the entire toolbox has been removed.
Cartography tools
Grids and graticules
Delete Grids And Graticules
Make Grids and Graticules Layer has been replaced by the Make Grids and Graticules Layer tool in the Topographic Production toolbox.
Grids and graticules can be converted to graphics layers and feature classes using the Convert To Graphics and Convert To Features commands on a grid element in a layout.
Learn more about working with grids and graticules in ArcGIS Pro
Representation Management
Add Representations
Calculate Representation Rule
Drop Representation
Remove Override
Select Feature By Override
Set Layer Representation
Set Representation Control Point At Intersect
Set Representation Control Point By Angle
Update Override
Learn how to convert representations for use in ArcGIS Pro
Conversion tools
CAD
- Import CAD Annotation
Access CAD text from the CAD feature dataset as an annotation feature class or a point feature class that can be labeled.
The CAD annotation feature class can be copied to a geodatabase in the same way that any other feature class can be copied. Alternatively, use the CAD To Geodatabase tool to add a CAD annotation feature class to a geodatabase.
Learn about annotation in ArcGIS Pro
Coverage
Feature Class To Coverage
Import Coverage Annotation
Import From E00
Coverages are not supported in ArcGIS Pro.
Geodatabase
- The Copy Runtime Geodatabase to File Geodatabase tool has been replaced by the Mobile Geodatabase To File Geodatabase tool.
Metadata
Esri Metadata Translator
Export Metadata
Export Metadata Multiple
Import Metadata
Metadata Importer
Metadata Publisher
Synchronize Metadata
Upgrade Metadata
USGS MP Metadata Translator
Validate Metadata
Validate Metadata multiple
XML Schema Validation
XSLT Transformation
Metadata geoprocessing tools are not available in ArcGIS Pro; however, you can automate metadata workflows using the arcpy.metadata module.
Learn more about migrating metadata workflows to ArcGIS Pro
Raster
- Raster To Video
Data Management tools
Distributed Geodatabase
- Create Replica Footprints
Feature Class
Update Annotation Feature Class
Annotation feature classes can be updated for use in ArcGIS Pro using the Upgrade Dataset tool.
Geodatabase Administration
- Upgrade Spatial Reference
The Upgrade Spatial Reference tool is primarily used with personal geodatabase feature classes, which are not supported in ArcGIS Pro.
Geometric Network
Add Edge-Edge Connectivity Rule To Geometric Network
Add Edge-Junction Connectivity Rule To Geometry Network
Create Geometric Network
Find Disconnected Features in Geometric Network
Rebuild Geometric Network
Remove Connectivity Rule From Geometric Network
Remove Empty Feature Class From Geometric Network
Set Flow Direction
Trace Geometric Network
Verify And Repair Geometric Network Connectivity
Geometric networks are a read-only dataset in ArcGIS Pro. ArcGIS Pro includes two capabilities you can use to manage, model, and analyze network systems: the Trace Network and the Utility Network.
Graph
Make Graph
Save Graph
Graphing and charting capabilities in ArcGIS Pro have been redesigned. Graphs and graph templates created in ArcMap are not supported in ArcGIS Pro.
Use the ArcPy Chart class to automate the creation of charts in ArcGIS Pro.
Additionally, you can create a layer with charts, save the layer as a layer file, and set that layer file as the Symbology property for custom script tool or model tool output parameters. When the script or model tool is run, the charts are automatically created for the new output datasets.
Package
Consolidate Result—Related ArcGIS Pro tools include Package Result and Consolidate Toolbox.
Create Runtime Content
Learn about sharing mobile map packages from ArcGIS Pro for use in other ArcGIS applications
Raster Catalog
Copy Raster Catalog Items
Create Raster Catalog
Delete Raster Catalog Items
Export Raster Catalog Paths
Make Raster Catalog Layer
Raster Catalog To Raster Dataset
Repair Raster Catalog Paths
Workspace To Raster Catalog
Raster catalogs are a read-only dataset in ArcGIS Pro.
Learn about migrating raster catalogs to mosaic datasets
Workspace
Create ArcInfo Workspace—ArcInfo workspaces are not supported in ArcGIS Pro.
Create ArcSDE Connection File—This tool has been replaced by the Create Database Connection tool.
Create Personal GDB—Personal geodatabases are not supported in ArcGIS Pro.
Data Reviewer tools
- Geodatabase Schema Compare
Location Referencing tools
The Location Referencing toolbox in ArcGIS Pro combines many of the tools available in the Pipeline Referencing and Roads and Highways toolboxes in ArcMap.
Convert M-Value Units Of Measure
Convert Table To CSV File
Detect Gaps For Linear Events
Detect Measures Out Of Range
Detect Non-Monotonic Routes
Detect Overlaps For Linear Events
Maritime tools
- Convert AML Format
ArcGIS Maritime supports workflows for managing and producing hydrographic data in compliance with International Hydrographic Organization (IHO) standards.
Network Analyst tools
Server
Find Closest Facilities
Find Routes
Generate Service Areas
Make Vehicle Routing Problem Layer
Solve Location-Allocation
Update Traffic Data
Update Traffic Incidents
ArcGIS Pro provides the same enhanced network analysis capabilities available in the Server toolset through other tools in the Network Analyst toolbox, and the interactive network analysis workflow.
Parcel Fabric tools
The legacy parcel fabric for ArcMap is supported as a read-only dataset in ArcGIS Pro. You cannot create new or edit existing parcel fabrics for ArcMap in ArcGIS Pro, so the entire toolbox has been replaced.
ArcGIS Pro includes an enhanced parcel fabric that provides a comprehensive framework for managing, editing, and sharing parcel data in ArcGIS Enterprise, including the Parcel Tools toolbox.
Schematics tools
Legacy schematics are not supported in ArcGIS Pro, so the entire toolbox has been removed.
Utility Network schematic diagrams allow you to generate symbolic and simplified representations of the geographic features in a network.
Server tools
Caching
Delete Globe Server Cache
Manage Globe Server Cache Tiles
Upgrade Map Server Cache Storage Format
Publishing
MXD To Web Map
Sign In To Portal—Use the ArcPy
SignInToPortalfunction to automate signing in to a portal.Sign Out From Portal
Tracking Analyst tools
The ArcGIS Tracking Analyst extension is not available or on the road map for ArcGIS Pro.
Workflow Manager (Classic) tools
ArcGIS Workflow Manager (Classic) was deprecated after ArcGIS Pro 3.4. The Workflow Manager (Classic) toolbox is no longer supported.
Learn more about the deprecation of ArcGIS Workflow Manager (Classic)
