Server toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Convert Map Server Cache Storage Format
Version
2.9
New at this version
Create Map Server Cache
Version
3.4
New parameter added: ready_to_serve_format
2.4
New at this version
Delete Map Server Cache
Version
1.4
Ported from ArcMap 10.5
Export Map Server Cache
Version
3.5
2.3
Parameter storage_format_type had new option added: COMPACT_V2
1.4
Export Web Map
Version
3.2
2 new parameters added:
  • Report_Template
  • Report_Item_ID
3.1
New parameter added: Layout_Item_ID
2.8
Parameter Format had new option added: TIFF
2.6
Parameter Format had new option added: AIX
2.1
New at this version
Extract Data
Version
1.0
Ported from ArcMap 10.3
Extract Data and Email Task
Version
1.0
Extract Data Task
Version
1.2
Parameter Feature_Format has 15 new options:
  • Autodesk AutoCAD - DXF_R2010 - .dxf
  • Autodesk AutoCAD - DWG_R2010 - .dwg
  • Autodesk AutoCAD - DXF_R2005 - .dxf
  • Autodesk AutoCAD - DWG_R14 - .dwg
  • Autodesk AutoCAD - DWG_R2013 - .dwg
  • Autodesk AutoCAD - DXF_R14 - .dxf
  • Autodesk AutoCAD - DXF_R2004 - .dxf
  • Autodesk AutoCAD - DWG_R2004 - .dwg
  • Autodesk AutoCAD - DXF_R2000 - .dxf
  • Autodesk AutoCAD - DWG_R2007 - .dwg
  • Bentley Microstation Design (V8) - DGN_V8 - .dgn
  • Autodesk AutoCAD - DXF_R2007 - .dxf
  • Autodesk AutoCAD - DXF_R2013 - .dxf
  • Autodesk AutoCAD - DWG_R2005 - .dwg
  • Autodesk AutoCAD - DWG_R2000 - .dwg
1.0
Generate Map Server Cache Tiling Scheme
Version
3.4
  • output_folder
  • ready_to_serve_format
1.1
Ported from ArcMap 10.3.1
Get Layout Templates Info
Version
3.1
2.1
New at this version
Get Report Templates Info
Version
3.2
New at this version
Import Map Server Cache
Version
3.5
Recognizes caches that have been created in a ready-to-serve format.
1.4
Manage Map Server Cache Scales
Version
2.9
New at this version
Manage Map Server Cache Status
Version
1.4
Manage Map Server Cache Tiles
Version
1.0
Replace Web Layer
Version
2.6
Parameter target_layer has new data type: Scene Layer
Parameter update_layer has new data type: Scene Layer
2.5
Parameter target_layer has new data type: Internet Tiled Layer
Parameter update_layer has new data type: Internet Tiled Layer
2.4
New at this version
Send Email With Zip File Attachment
Version
1.0
Stage Service
Version
1.2
Removed parameter staging_version
1.0
Upload Service Definition
Version
3.6
New parameter added: out_item_id
3.5
New parameter added: in_item_id
1.4
  • out_vectorTileServiceURL
  • out_vectorTileServiceID
1.2
New parameter added: out_standaloneTableIDMap
1.0
