| Name | Description | |
![]() | CanEdit | Indicates if metadata is editable for the item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | Clone | Make a clone of the online item (Inherited from ArcGIS.Desktop.Core.Portal.OnlineItem) |
![]() | CopyMetadataFromItem | Copy metadata from Item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | DeleteMetadataContent | Delete certain content from the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | Equals | Determines if the given object is identical to this object. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | ExportMetadata | Overloaded. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | GetHashCode | Gets a hash code associated with this item. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | GetItems | Browses the contents of an item. Returns a snapshot collection of of the item's children. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | GetXml | Gets the item’s metadata XML document as a string. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | ImportMetadata | Overloaded. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | OnCurrentRoot | Called when the Item becomes the current root item in the Catalog View. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | OnExpanded | Override to implement any custom logic when your item is expanded (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | Refresh | Refreshes the collection of children. Use ArcGIS.Desktop.Core.Item.IsMainThreadRequired to determine the correct thread for performing a refresh. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | Repair | Repair the path (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SaveMetadataAsHTML | Save the metadata of the current item as HTML. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SaveMetadataAsUsingCustomXSLT | Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SaveMetadataAsXML | Save the metadata of the current item as XML. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SearchItem | Search (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SetAlias | Changes the alias value on the given item. This method will return false if the item is not a folder connection. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | SetXml | Sets the item’s metadata to the XML document provided as a string. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | Synchronize | Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | ToString | Override the default ToString() method. (Inherited from ArcGIS.Desktop.Core.Item) |
![]() | UpgradeMetadata | Upgrade the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Core.Item) |
