Raster Analysis toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Calculate Density
Version
3.1
2 linear units added to the searchDistance and outputCellSize parameters:
  • MilesInt
  • FeetInt
2.9
New environment added: pyramid
2.7
New parameter added: inBarriers
1.4
New at this version
Calculate Distance
Version
3.1
3 linear units added to the maximumDistance and outputCellSize parameters:
  • MilesInt
  • YardsInt
  • FeetInt
2.9
2.4
4 new parameters added:
  • distanceMethod
  • outputBackDirectionRaster
  • inputBarrierRasterOrFeatures
  • outputBackDirectionName
2.1
New at this version
Calculate Travel Cost
Version
2.9
2.1
New at this version
Classify Objects Using Deep Learning
Version
2.7
New at this version
Classify Pixels Using Deep Learning
Version
2.3
New at this version
Convert Feature To Raster
Version
3.1
2 linear units added to the outputCellSize parameter:
  • MilesInt
  • FeetInt
2.9
1.4
New at this version
Convert Raster To Feature
Version
1.4
New at this version
Cost Path As Polyline
Version
2.4
New at this version
Create Viewshed
Version
3.3
6 new parameters added:
  • verticalError
  • refractivityCoefficient
  • horizontalStartAngle
  • horizontalEndAngle
  • verticalUpperAngle
  • verticalLowerAngle
3.1
3 linear units added to the maximumViewingDistance, minimumViewingDistance, observersElevation, observersHeight, and targetHeight tool parameters:
  • MilesInt
  • YardsInt
  • FeetInt
2.9
1.4
New at this version
Detect Objects Using Deep Learning
Version
2.3
New at this version
Determine Optimum Travel Cost Network
Version
2.4
Parameter outputOptimumNetworkFeatures has new data type: Feature Layer
Parameter outputOptimumNetworkFeatures had data type removed: Raster Layer
Parameter outputNeighborNetworkFeatures has new data type: Feature Layer
Parameter outputNeighborNetworkFeatures had data type removed: Feature Class
2.1
New at this version
Determine Travel Cost Path As Polyline
Version
2.4
New parameter added: destinationField
This parameter can be used to obtain values for the destination locations.
Parameter outputPolylineFeatures has new data type: Feature Layer
Parameter outputPolylineFeatures had data type removed: Feature Class
2.2
New at this version
Determine Travel Cost Paths To Destinations
Version
2.9
2.1
New at this version
Distance Accumulation
Version
3.4
For the inputCostRaster parameter, while values that are negative or zero are considered invalid, they will now be treated as small positive cost values.
3.3
Parameter vertical_factor has two new options:
  • VFHikingTime
  • VFBidirHikingTime
2.9
2.6
New at this version
Distance Allocation
Version
3.4
3.3
  • VFHikingTime
  • VFBidirHikingTime
2.9
2.6
New at this version
Fill
Version
2.9
2.1
New at this version
Flow Accumulation
Version
2.9
2.2
New parameter added: flowDirectionType
This parameter allows you to specify which types the input flow direction raster is (D8, MFD, or DINF).
2.1
New at this version
Flow Direction
Version
2.9
2.1
New at this version
Flow Distance
Version
2.9
2.3
New parameter added: statisticsType
2.2
2.1
New at this version
Interpolate Points
Version
3.1
  • MilesInt
  • FeetInt
2.9
2.0
Parameter outputPredictionError has two new options:
  • NO_OUTPUT_ERROR
  • OUTPUT_ERROR
Parameter transformData has two new options:
  • TRANSFORM
  • NO_TRANSFORM
1.4
New at this version
Nibble
Version
2.9
2.1
New at this version
Optimal Path As Line
Version
2.7
New parameter added: createNetworkPaths
2.6
New at this version
Optimal Path As Raster
Version
2.9
2.6
New at this version
Optimal Region Connections
Version
3.4
2.6
New at this version
Stream Link
Version
2.9
2.1
New at this version
Summarize Raster Within
Version
3.4
Parameter statisticType has four new options:
  • MAJORITY_COUNT
  • MAJORITY_PERCENT
  • MINORITY_COUNT
  • MINORITY_PERCENT
3.0
Two new parameters added:
  • circularCalculation
  • circularWrapValue
2.9
2.7
New parameter added: percentileInterpolationType
2.6
  • processAsMultidimensional
  • percentileValue
New option for the statisticType parameter: PERCENTILE
1.4
New at this version
Surface Parameters
Version
3.3
New parameter added: inputAnalysisMask
3.0
New at this version
Zonal Statistics As Table
Version
3.4
Parameter statisticType has six new options:
  • MAJORITY_COUNT
  • MAJORITY_PERCENT
  • MAJORITY_VALUE_COUNT_PERCENT
  • MINORITY_COUNT
  • MINORITY_PERCENT
  • MINORITY_VALUE_COUNT_PERCENT
3.0
  • circularWrapValue
2.7
2.6
New at this version
Watershed
Version
2.9
2.1
New at this version
