Attribute rules
Disponible con una licencia de representación cartográfica topográfica de ArcGIS.
The product data files for the ArcGIS Topographic Mapping extension include schema geodatabases with preconfigured attribute rules that can be applied to Multinational Geospatial Co-production Program (MGCP) and Topographic Data Store (TDS) data using ArcGIS Data Reviewer checks. The schema geodatabases include support for MGCP and TDS data beginning at the following versions:
MGCP TRD 4.6
TDS 7.1
Supported rule types
The schema geodatabases for the Topographic Mapping extension include constraint attribute rules and validation attribute rules.
Nota:
The preconfigured constraint attribute rules are not enabled by default. When enabled, feature edits that violate constraint rules cannot be saved and are rolled back, which may be an unintended consequence.
Error layers
The schema geodatabases include attribute rule error layers that store the error features identified by validation rules. These layers consist of three feature classes and a table that store and manage the errors that are found during attribute rule evaluation.
You can manage attribute rule errors using the error inspector table in ArcGIS Pro.
Preconfigured rules
The table below contains information about the preconfigured attribute rules that are included with the schema geodatabases.
Nota:
Constraint attribute rules are configured to be applied when an Insert or Update action takes place.
Rule name |
Geometry types |
Rule types |
Details |
Data model type |
Areas Lines Points |
Validation |
Identifies features with invalid geometry. |
MGCP TDS |
Areas Lines |
Constraint Validation |
Identifies cutbacks with an angle size of less than 10 degrees. |
MGCP TDS |
Validation |
Identifies rows or features that violate domain constraints. |
MGCP TDS |
Validation |
Identifies features that are duplicated in geometry, feature type, and attribution. |
MGCP TDS |
Areas Lines |
Identifies features that have consecutive duplicate vertices. |
MGCP TDS |
Areas Lines |
Identifies polygon or polyline features with more or less than one part. |
MGCP TDS |
Areas |
Identifies polygons with a perimeter that is less than 5 meters. |
MGCP TDS |
Validation |
Identifies polyline features that contain a segment with a length less than 0.02 meters. |
MGCP TDS |
Lines |
Identifies polyline features with a length less than 5 meters. |
MGCP TDS |
Identifies features that contain a segment with a length less than 0.02 meters. |
MGCP TDS |
Lines |
Validation |
Identifies polyline features that have nodes that are within 10 meters, but are not connected to other polyline or polygon features. |
MGCP TDS |
Areas Lines |
Validation |
Identifies nonlinear segment geometries from polygon or polyline features that have nonlinear segments. |
MGCP TDS |
Areas |
Validation |
Identifies area features that have an area to perimeter ratio less than 0.09. |
MGCP TDS |
Validation |
Identifies features that have invalid subtypes. |
TDS |
Validation |
Identifies features with identifier field (GFID or UID) values that are not unique. |
MGCP TDS |
Lines |
Identifies node—if database topology exists—or polyline—if no database topology exists—geometries that share a node and have identical attribution on editable fields. Sugerencia:Running this check with a database topology improves performance. |
MGCP TDS |
Areas |
Identifies area features that border another area feature with the same attribution. |
MGCP TDS |
