ArcGIS.Desktop.Layouts Namespace / Element Class
    Element Class Methods
    For a list of all members of this type, see Element members.
    Public Methods
     NameDescription
    Public Method Apply the given style to the element. This method must be called on the MCT. Use QueuedTask.Run
    Public Method Gets whether the StyleItem can be applied
    Public Method Compare Elements by name.
    Public Method Convert the element to graphics. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Public Method Gets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Get the element anchor point location. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the bounding box for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a Custom Property value for the element.
    Public Method Returns the element's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodReturns a Geometry which is a CIM representation of the GraphicElement shape. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Serves as the default hash function.
    Public Method Gets the height of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the locked aspect ratio value of the element. If This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the parent of this element.
    Public Method Gets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the width of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the element anchor point to the X and Y location specified. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodApplies the changes made to a modified CIMElement back to the element on the page layout. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodApplies the changes made to a CIMGraphic back to the GraphicElement. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the height of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the locked state of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the locked aspect ratio value of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the name of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the position of an element either at the top or bottom of the layout TOC or a group element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the visibility of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the width of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Protected Methods
