Network diagram management tasks
Network diagram configuration and management tasks are dependent on many factors, including the type of workspace connection and its permission level, the diagram type, the capabilities enabled on the diagram templates, and the connected database or portal account.
The following sections provide an overview of the dependencies that exist when working with a utility network or trace network.
Network diagram workflow tasks
The following tables summarize types of actions with the following details:
Action—The tool or type of action being performed.
Workspace—Specifies the required data source.
Service—The action must be performed against a feature layer from a utility network service.
Database connection—The action must be performed using a database connection to a utility network with an enterprise geodatabase. In this case, always ensure the workspace is set to branch for the versioning type.
File geodatabase—The action must be performed using a utility network or trace network with a file geodatabase.
Mobile geodatabase—The action must be performed using a utility network or trace network with a mobile geodatabase.
Diagram type—The type of diagram supported by the operation.
Temporary—The diagram is temporary.
Stored—The diagram is stored.
System—The diagram is a subnetwork system diagram.
Portal connection—Specifies the portal account that must be connected when performing the operation:
Any user—Any user who has a suitable access rights level on the diagram can perform the operation.
Diagram owner—The operation must be performed by the diagram owner.
Network owner—The operation must be performed by the network owner.
When running operations using a file or mobile geodatabase, the network diagram workflow tasks below can be run without being connected to a portal. However, there are differences for the following tools:
Store Diagram—When this tool runs without being connected, a user can only store diagrams as public diagrams. When the tool is run while connected, a user can also store diagrams as protected, or private diagrams, and prevent other connected users that work on the same database from editing or accessing them.
Alter Diagram Properties—When this tool runs without being connected, any user can access all public and protected diagrams that exist in the dataset—even those the user doesn't own—but can't alter the access rights level currently set for any of these diagrams. When connected, users can access all public and protected diagrams in the dataset, plus their private diagrams. In this case, users can alter the access rights level set for their own diagrams.
Diagram template restriction—Specifies whether the action can be locked at the diagram template level.
Usual editing operations on network diagrams
Action |
Workspace |
Diagram type |
Portal connection |
Diagram template restriction |
Service | Database connection | File | Mobile geodatabase |
Temporary |
Any user |
No |
Service | File | Mobile geodatabase |
Temporary | Stored | System |
Any user |
No |
Any user |
No |
Any user |
No |
Temporary |
Any user |
Yes |
Temporary |
Any user |
Yes |
Any user |
Yes |
Temporary |
Any user |
No |
Any user |
No |
Any user |
Yes |
Any user |
No |
Stored |
Diagram owner | Network owner |
No |
Stored |
Any user |
No |
Common nonediting operations on network diagrams
Action |
Workspace |
Diagram type |
Portal connection |
Any user |
No |
Stored | System |
Any user |
No |
Stored | System |
Any user |
No |
Any user |
No |
Any user |
No |
Temporary |
Any user |
No |
Maintenance tasks on network diagrams
Action |
Workspace |
Diagram type |
Portal connection |
Template restriction |
Service |
System |
Network owner |
NA |
Stored | System |
Network owner |
NA |
Temporary |
Network owner |
NA |
Network diagram configuration tasks
Service—The action must be performed using a feature layer from a utility network service.
File geodatabase—The action must be performed using a utility network or a trace network with a file geodatabase.
Mobile geodatabase—The action must be performed using a utility network or a trace network with a mobile geodatabase.
Any user—Any user with the appropriate rights on the diagram or network dataset can perform the operation.
When running operations using a file or mobile geodatabase, all network diagram configuration tasks can be run without being connected to a portal.
Diagram template management tasks
Action |
Workspace |
Portal connection |
Network owner |
Network owner |
Network owner |
Network owner |
Network owner |
Network owner |
Any user |
Any user |
Network owner |
Network owner |
