Utility network upgrade history
To keep a utility network current with the latest functionality, an upgrade may be necessary. This applies schema changes to the utility network dataset, network feature classes, and other related geodatabase objects. Use the Upgrade Dataset tool to perform the upgrade.
Learn more about requirements for the upgrade process
An upgrade of the utility network dataset is needed to take advantage of new functionality introduced through schema changes in the information model. The version of the ArcGIS Pro client and current Utility Network Version determines whether an upgrade is available for the utility network dataset. The upgrade process increments the Utility Network Version number.
When working with an enterprise geodatabase, the version of ArcGIS Pro and ArcGIS Enterprise determines the version of the utility network dataset that is created or upgraded. To learn more, see Utility network compatibility.
Keep in mind that not every ArcGIS Pro and ArcGIS Enterprise release introduce schema changes, and an upgrade of the utility network dataset is not required when moving to a new release. Upgrading is only required to take advantage of functionality introduced in a new version of the utility network.
Upgrades are cumulative between versions and include changes from skipped versions. For example, if you update the utility network from Utility Network Version 4 to Utility Network Version 7, all schema changes for versions 5 through 7 are included. When upgrading a utility network dataset from version 3 or earlier, additional steps are required after the upgrade process. Review steps for each version included in the upgrade path.
Tip:
The version and upgrade history for a utility network can be viewed in the General section of the Network Properties tab.
Upgrade to Utility Network Version 8
Utility Network Version 8 introduces fields to support optimizations to tracing when working with nonspatial objects, enhancements to attribute propagation, and support for the telecom domain network. Upgrading is not required unless you want to use propagation resetters or the telecom domain network.
Additional steps are required before upgrading a utility network to version 8:
- When working with an enterprise geodatabase, ensure the geodatabase is upgraded. Utility Network Version 7 introduced schema modifications that include the addition of 64-bit object IDs and big integer fields. 11.2.0 is the minimum enterprise geodatabase version to support 64-bit object ID and big integer fields.
When upgrading a utility network to Utility Network Version 8, the following change occurs:
A new system-maintained field,
PARTITIONID, is added to all classes in the domain and structure networks to support future enhancements to tracing and network management.A new system network category, Propagator Resetter, is available to support attribute propagation. During propagation, if features with this category are discovered, the value of the resetter feature resets the propagated attribute values.
New fields are added to the diagram classes to support the creation of diagrams along telecom domain networks using Trace rules with the path or circuit trace types:
A new field,
ELEMENTUNIT, is added to theTMP_JUNCTIONSandJUNCTIONSclasses.Four new fields,
FROMELEMENTFIRSTUNIT,ELEMENTFIRSTUNIT,ELEMENTLASTUNIT, andTOELEMENTFIRSTUNIT, are added to theTMP_EDGESandEDGESclasses.
Additional steps are required after upgrading a utility network to version 8:
- When upgrading a utility network dataset from version 3 or earlier, additional steps are required to incorporate cumulative changes made with utility network version 4. For more information, see the Additional steps required after upgrading a utility network to version 4 section below.
Upgrade to Utility Network Version 7
Utility Network Version 7 introduces support for 64-bit Object IDs and big integer fields, the ability to perform directional traces using the Flow direction field, and a new field to support joins and advanced labeling and rendering workflows with network diagrams. Upgrading a utility network to version 7 performs additional tasks, including dropping and re-creating indexes on all utility network tables to support 64-bit Object ID and big integer fields. As a result, this process may take longer to complete.
Additional steps are required before upgrading a utility network to version 7:
- When working with an enterprise geodatabase, ensure the geodatabase is upgraded. Utility Network Version 7 introduces schema modifications that include the addition of 64-bit object IDs and big integer fields. 11.2.0 is the minimum enterprise geodatabase version to support 64-bit object ID and big integer fields.
When upgrading a utility network to Utility Network Version 7, the following changes occur:
The
Object IDfield for all utility network classes are migrated to use 64-bit object IDs.A new field,
FLOWDIRECTION, is added to theLineandEdgeObjectclasses in the domain network and theStructureLineandStructureEdgeObjectclasses in the structure network. This supports the Use Digitized Direction parameter on the Trace and Add Trace Configuration tools to respect the digitized direction of the line, the From and To global ID on edge objects, and theFlow directionattribute value when performing upstream and downstream trace operations.A new text field,
Info, is added to theTMP_JUNCTIONS,TMP_EDGES,TMP_CONTAINERS,JUNCTIONS,EDGES, andCONTAINERSdiagram classes to support joins and advanced labeling and rendering workflows.The domain and coded value descriptions for the
UN_<ID>_IsDirtydomain are updated to communicate whether a subnetwork is (0: Clean), (1: Dirty), or (2: Invalid).An alias of
Statusis set for theISDIRTYattribute field in theSubnetLinefeature class andSubnetworkstable.The
ERRORCODEfield in the dirty areas and associations tables is updated from a Double to a Big integer field data type.
Additional steps are required after upgrading a utility network to version 7:
Upgrade to Utility Network Version 6
Utility Network Version 6 introduces various internal updates that benefit users working with Network Diagrams.
When upgrading a utility network to Utility Network Version 6, the following changes occur:
- The
ASSOCIATIONTYPEfield on the Associations table is set as a subtype field to improve performance when displaying diagrams and editing associations.
Additional steps are required after upgrading a utility network to version 6:
Upgrade to Utility Network Version 5
Utility Network Version 5 introduces the ability to create and work with named trace configurations and exposes additional options for configuring the subnetwork definition for a tier. For more information, see Set Subnetwork Definition.
When upgrading a utility network to Utility Network Version 5, the following changes occur:
A new field,
SUPPORTINGSUBNETWORKNAME, is added to all domain network classes with the exception of theAssemblyfeature class.A new table,
UN_<ID>_TRACECONFIGURATIONS, is added to the utility network schema to support the creation, usage, and sharing of named trace configurations.
Additional steps are required after upgrading a utility network to version 5:
Review the service settings for existing utility network services after the upgrade. In the operations allowed section for the Utility Network capability, ensure all operations allowed are checked to include operations specific for ArcGIS Enterprise 10.9.
Upgrade to Utility Network Version 4
Utility Network Version 4 introduces a new dirty area model that incorporates error management and enables the ability to create and work with nonspatial junction and edge objects. Additional options are also exposed to configure the subnetwork definition for a tier. For more information, see Set Subnetwork Definition.
When upgrading a utility network to Utility Network Version 4, the following changes occur:
The point, line, and polygon error sublayers are removed and are no longer available as sublayers of the utility network layer.
The schema of the dirty areas and associations tables are modified to store error information.
The
UPDATETYPEfield is removed from the dirty areas table.The
STATUSfield is now used in the dirty areas table to indicate the type of dirty area. This field is added to the associations table.The
ERRORCODEandERRORMESSAGEfields are added to the dirty areas and associations tables.A
PERCENTALONGfield is added to the associations table.
All dirty areas in named versions are truncated. This step is necessary to incorporate schema changes made to the dirty areas table. New dirty areas are generated after upgrade in the default version by enabling the network topology and performing a reconcile in all named versions.
The
AssociationStatusdomain is updated to include changes with the built-in feature restrictions of a utility network.A nonunique attribute index is added on the
SUBNETWORKNAMEandSUBNETWORKCONTROLLERNAMEfields of the Subnetworks table.A new field,
SUPPORTEDSUBNETWORKNAME, is added to all domain network classes. This field is used to store the subnetwork of features supported by features in theAssemblyfeature class.The update subnetwork operation no longer updates the
SUBNETWORKNAMEfield to store the subnetwork for features in theAssemblyfeature class.During the upgrade, the
SUBNETWORKNAMEfield is updated to no longer be system maintained; however, it is not deleted. While not required, this can be removed from theAssemblyfeature class to avoid confusion.
Additional subnetwork properties are stored for each tier:
Valid Junctions.
Valid Junction Objects.
Valid Edge Objects.
Valid Subnetwork Controllers now lists devices and junction objects that are set as valid subnetwork controllers.
A new code and description value are added to the system-provided UN_<ID>_IsDirty coded value domain (2: Invalid). This supports a new subnetwork status of Invalid on the Is dirty attribute when updating a subnetwork beginning with ArcGIS Pro 3.1, to indicate that conditions are present that prevent a subnetwork from being updated.
To model and work with a large number of real-world features that share a common geographical space, nonspatial junction and edge objects are introduced as part of the utility network schema:
For the structure network, the following tables are created:
StructureJunctionObject
StructureEdgeObject
For each domain network, the following tables are created:
<domain_network>JunctionObject
<domain_network>EdgeObject
The system-provided
UN_<ID>_FeatureSourceIDcoded value domain is updated with the addition of the following code and description values for the structure network and each domain network:<ID>—Structure Junction Object
<ID>—Structure Edge Object
<ID>—<domain_name> Junction Object
<ID>—<domain_name> Edge Object
Register the feature dataset that contains the utility network as branch versioned to version the new junction and edge objects. To learn more, see Register a dataset as branch versioned.
Enable the network topology.
Remove and re-add the utility network layer in existing maps to reflect the updated dirty area and error symbology.
Publish new services with an updated map that includes the nonspatial junction and edge object tables. You can do this by publishing new web feature layers or overwriting existing web feature layers.
Reconcile all named versions to regenerate dirty areas based on schema changes made during upgrade.
