ArcGIS.Desktop.Core Namespace / Project Class
    Project Class Methods
    For a list of all members of this type, see Project members.
    Public Methods
     NameDescription
    Public MethodAdds the item to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Indicates if metadata is editable for the item.
    Public Methodstatic (Shared in Visual Basic)Checks if the specified project or project package can be opened
    Public Methodstatic (Shared in Visual Basic) Clears the list of pinned projects.
    Public Methodstatic (Shared in Visual Basic) Clears the list of recent project templates.
    Public Methodstatic (Shared in Visual Basic) Clears the list of recent projects.
    Public Method Copy metadata from Item. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Creates a new project with properties determined by CreateProjectSettings
    Public Method Delete certain content from the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodDiscards all unsaved data edits in the project.
    Public MethodOverloaded.
    Public Method Find the item identified by the physical path.
    Public Methodstatic (Shared in Visual Basic) Gets the active catalog view or null if no catalog view is active
    Public Methodstatic (Shared in Visual Basic)Gets the catalog dockpane. If createIfNecessary = true and the catalog dockpane has not been created, the pane will be created. Otherwise, if the catalog dockpane has not been created and createIfNecessary = false, null will be returned.
    Public Methodstatic (Shared in Visual Basic) Get the default project settings
    Public MethodGets a collection of a specific type of items within the project
    Public Methodstatic (Shared in Visual Basic) Retrieves the list of pinned projects.
    Public Methodstatic (Shared in Visual Basic) Retrieves the list of pinned project templates.
    Public Method Get the container with the given key. Container keys are not localized. A container is needed only in those situations where you want to select a specific item that occurs in more than one container.
    Public Methodstatic (Shared in Visual Basic) Retrieves the list of recently opened projects
    Public Methodstatic (Shared in Visual Basic) Retrieves the list of recently opened project templates
    Public Method Gets the item’s metadata XML document as a string. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Opens an existing project or project package
    Public Methodstatic (Shared in Visual Basic) Pins a project.
    Public Methodstatic (Shared in Visual Basic) Pins a project template.
    Public Method If this project is a portal project, this method updates the project on the portal to match the local version. Local changes and new items will be pushed to the portal. Differences on the portal will be overwritten. New items on the portal will be deleted.
    Public MethodRestores the last data edit that was reversed in the project.
    Public MethodRefreshes the project item specified by path.
    Public MethodRemoves the project item from the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodRemoves project items from the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Removes the project entry corresponding to the given input path from the recent list of projects
    Public Methodstatic (Shared in Visual Basic) Removes the project template entry corresponding to the given input path from the recent list of project templates
    Public Method
    Public Method Saves a copy of the current project file (*.aprx) to the specified location with the specified file name, then opens the new project file
    Public Method Saves the project
    Public MethodSave all unsaved data edits in the project.
    Public Method Creates a new project from an untitled session
    Public Method Save the metadata of the current item as HTML. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Save the metadata of the current item as XML. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodSearches the project for items that match the provided criteria
    Public Method Sets the project's default geodatabase. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the current project's default toolbox. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the dirty state of the project
    Public Method Sets the current project's home folder. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value that indicates if editing is to be enabled or disabled within the application.
    Public Method Sets the item’s metadata to the XML document provided as a string. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Updates metadata with the current properties of the item. Metadata is created for the item if it doesn't already exist. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodReverses the last data edit in the project.
    Public Methodstatic (Shared in Visual Basic) Unpins a project.
    Public Methodstatic (Shared in Visual Basic) Unpins a project template.
    Public Method Upgrade the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Protected Methods
     NameDescription
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
    Extension Methods
     NameDescription
    Public Extension Method Adds the specified style to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Creates a new mobile style file (.stylx) on disk and adds the mobile style to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Creates a new style file (.stylx) on disk and adds the style to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Returns the project's collection of bookmarks. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodGets the current datastore being edited. This method will only return non-null values when the project is configured for single workspace editing; that is EditingOptions.IsSingleWorkspaceEditSession is true. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Removes the specified style from the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodOverloaded.
    Top
