GeoAnalytics Server toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
Legacy:
The ArcGIS GeoAnalytics Server extension is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3. These tools are available through ArcGIS Enterprise 11.3 and earlier versions.
For more information about how to interpret and use these tables, see Toolbox history topics.
Aggregate Points
Version
3.2
New parameter added: bin_resolution
Parameter bin_type had new option added: H3
2.0
New parameter added: data_store
1.4
New at this version
Append Data
Version
2.2
New at this version
Calculate Density
Version
3.1
Parameter area_unit_scale_factor has 4 new options:
  • SQUARE_YARDS_US
  • SQUARE_MILES_US
  • SQUARE_FEET_US
  • ACRES_US
2.7
Default value for parameter weight changed from KERNEL to UNIFORM
2.0
1.4
New at this version
Calculate Field
Version
2.4
2 new parameters added:
  • time_boundary_reference
  • time_boundary_split
2.1
New at this version
Calculate Motion Statistics
Version
3.1
Parameter elevation_unit has 4 new options:
  • NAUTICAL_MILES_INT
  • MILES_INT
  • YARDS_INT
  • FEET_INT
Parameter distance_unit has 4 new options:
  • MILES_INT
  • YARDS_INT
  • FEET_INT
2.7
New at this version
Clip Layer
Version
2.4
Parameter clip_layer has new data type: Feature Set
Parameter clip_layer had data type removed: Record Set
2.3
New at this version
Copy To Data Store
Version
1.4
New at this version
Create Buffers
Version
2.1
Parameter buffer_expression has new data type: Calculator Expression
Parameter buffer_expression had data type removed: String
2.0
1.4
New at this version
Create Space Time Cube
Version
1.4
New at this version
Describe Dataset
Version
2.4
New at this version
Detect Incidents
Version
2.4
2.1
New at this version
Dissolve Boundaries
Version
2.3
New at this version
Find Dwell Locations
Version
2.5
New at this version
Find Hot Spots
Version
2.4
Parameter bin_size changed from Required to Optional
Parameter neighborhood_size changed from Required to Optional
2.0
1.4
New at this version
Find Point Clusters
Version
2.5
  • use_time
  • search_duration
2.4
Parameter clustering_method changed from Required to Optional
2.3
New parameter added: clustering_method
Parameter search_distance changed from Required to Optional
2.2
New at this version
Find Similar Locations
Version
2.0
1.4
New at this version
Forest-based Classification and Regression
Version
2.4
New at this version
Generalized Linear Regression
Version
2.7
Parameter coefficient_table has new data type: Record Set
Parameter coefficient_table had data type removed: String
2.4
New at this version
Group By Proximity
Version
3.0
New parameter added: attribute_relationship
2.9
New at this version
Join Features
Version
3.2
  • include_distance
  • distance_unit
2.7
New parameter added: keep_all_target_features
2.5
Default value for parameter spatial_relationship changed from INTERSECTS to (blank)
2.4
Parameter spatial_relationship had new option added: NEAR_GEODESIC
2.2
Parameter temporal_relationship has 2 new options:
  • NEAR_AFTER
  • NEAR_BEFORE
2.0
1.4
New at this version
Merge Layers
Version
2.3
New at this version
Overlay Layers
Version
2.4
Parameter overlay_type has 3 new options:
  • IDENTITY
  • SYMMETRICAL_DIFFERENCE
  • UNION
2.3
Parameter include_overlaps has 2 new options:
  • OVERLAPPING
  • NOT_OVERLAPPING
2.2
New at this version
Reconstruct Tracks
Version
2.7
  • split_type
  • split_expression
2.4
2.1
New parameter added: distance_split
2.0
1.4
New at this version
Snap Tracks
Version
3.1
4 new parameters added:
  • distance_split
  • time_split
3.0
New at this version
Summarize Attributes
Version
2.7
3 new parameters added:
  • time_step_repeat
  • time_step_reference
  • time_step_interval
2.0
1.4
New at this version
Summarize Center and Dispersion
Version
2.7
New at this version
Summarize Within
Version
3.1
Parameter shape_units has 9 new options:
  • YARDS_INT
  • SQUARE_FEET_US
  • NAUTICAL_MILES
  • MILES_INT
  • ACRES_US
  • SQUARE_YARDS_US
  • SQUARE_MILES_US
  • FEET_INT
2.9
2 new weighted statistics added:
  • Variance
  • Standard Deviation
2.2
  • group_by_field
  • add_minority_majority
  • add_percentages
  • group_by_summary
2.0
1.4
New at this version
Trace Proximity Events
Version
2.7
New at this version
