Network Analyst toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Version |
Description |
3.2 |
Parameter
1.0 |
Ported from ArcMap 10.3 |
Version |
Description |
3.5 |
The tool's display name changed from Add Vehicle Routing Problem Breaks to Add Fleet Routing Breaks. 4 new parameters added:
2.6 |
New at this version |
Version |
Description |
3.5 |
The tool's display name changed from Add Vehicle Routing Problem Routes to Add Fleet Problem Routes. |
3.3 |
New parameter added: |
2.6 |
Version |
Description |
3.0 |
2.6 |
Parameter Parameter |
1.0 |
Version |
Description |
3.2 |
1.0 |
Version |
Description |
3.0 |
New parameter added: Parameter |
2.6 |
1.4 |
New parameter added: Default value for parameter |
1.0 |
Version |
Description |
3.0 |
Version |
Description |
1.0 |
Version |
Description |
2.5 |
Version |
Description |
1.2 |
Version |
Description |
1.2 |
Version |
Description |
1.0 |
Version |
Description |
3.3 |
Required extension changed from Network Analyst to none |
3.1 |
Version |
Description |
1.3 |
Parameter
1.0 |
Version |
Description |
1.0 |
Version |
Description |
3.7 |
Version |
Description |
1.0 |
Version |
Description |
3.7 |
2 new parameters added:
2.9
New parameter added: ignore_invalid_locations
2.4
New parameter added: generate_directions_on_solve
Parameter order changed at parameter 12:
Old parameter:
out_network_analysis_layerNew parameter:
1.2
New at this version
Make Closest Facility Layer
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make Closest Facility Analysis Layer tool. |
1.0 |
Version |
Description |
3.7 |
3.3 |
Version |
Description |
3.7 |
2.9 |
1.2 |
Make Location-Allocation Layer
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make Location-Allocation Analysis Layer tool. |
1.0 |
Version |
Description |
2.1 |
Version |
Description |
3.7 |
2.9 |
1.2 |
Make OD Cost Matrix Layer
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make OD Cost Matrix Analysis Layer tool. |
1.0 |
Version |
Description |
3.7 |
2.9 |
2.7 |
Parameter order changed at parameter 10:
2.6 |
New parameter added: Parameter order changed at parameter 10:
2.4 |
New parameter added: Parameter order changed at parameter 9:
1.2 |
Make Route Layer
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make Route Analysis Layer tool. |
1.0 |
Version |
Description |
3.7 |
2.9 |
1.2 |
Make Service Area Layer
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make Service Area Analysis Layer tool. |
1.0 |
Version |
Description |
3.7 |
2.9 |
2.6 |
Version |
Description |
3.7 |
3.5 |
Version |
Description |
1.0 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
Version |
Description |
1.4 |
1.0 |
Solve Vehicle Routing Problem
Version |
Description |
2.7 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Make Vehicle Routing Problem Analysis Layer tool and the Vehicle Routing Problem button in the Network Analysis drop-down menu on the Analysis ribbon. |
2.2 |
Parameter |
1.4 |
Version |
Description |
1.0 |
Update Analysis Layer Attribute Parameter
Version |
Description |
1.2 |
Deprecated This is a deprecated tool. Instead of updating your network analysis layer's attribute parameter values individually at analysis time, you should instead set attribute parameter values in advance by configuring travel modes on your network data source. At analysis time, simply choose the correct travel mode. |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
1.0 |
Update Fleet Routing Assignments
Version |
Description |
3.7 |
Version |
Description |
3.7 |
