ArcGIS Business Analyst Desktop equivalency
Доступно с лицензией Image Analyst.
Business Analyst functionalities in ArcGIS Desktop and the equivalent tools and workflows in ArcGIS Pro are listed.
Evaluate Site
ArcGIS Business Analyst Pro
Evaluate Site
Evaluate Site
Custom Data Setup
BDS (Business Analyst Data Source) layers
Statistical Data Collection
Add Business Listing
Add Business Listings
Generate Points From Business Listings
In Business Analyst Pro, the equivalent functionality is also available as a workflow. Points of Interest Search is available from the Business Analysis drop-down menu on the Analysis tab.
Trade Area
Customer Derived Trade Areas
Generate Customer Derived Trade Areas
Static/Simple Rings
Generate Trade Area Rings
Drive Time Areas
Generate Drive Time Trade Area
Threshold Data Driven Ring
Generate Threshold Rings
Threshold Trade Areas
Generate Threshold Drive Times
Measure Cannibalization
Remove Trade Area Overlap
Remove Overlap and Remove Overlap (multiple)
Create Trade Area from Geography Levels/Online Geography Levels/Sub-geography layer
Generate Standard Geography Trade Areas
Analysis
Append Data
Enrich Layer
Determine Market Penetration
Calculate Market Penetration
Proximity Analysis (Locator Report)
Find Nearby Locations
Create Spider Diagram (Desire Lines)
Generate Desire Lines
Assign by closest store location
Assign Customers By Distance
Benchmark Report
Benchmark Comparisons
Reports
Run Summary/Demographic Reports or Quick Reports
Summary Reports
Wind Rose (Analytical Reports)
Maps
Color Coded Maps toolbar
Color Coded Layer
Sales Potential Modeling
Original Huff Model
Huff Model
Huff Model Calibration
Target Marketing
Create Profiles: Create Customer Profile
Generate Customer Segmentation Profile
Create Profiles: Create Geographic Profile
Generate Market Area Segmentation Profile
Create Profiles: Create Survey Profile
Generate Survey Report for Profile and Generate Survey Report for Targets
Create Profiles: Import Profile
Import Segmentation Profile
Target Groups
Create Target Group Layer
Target Map
Generate Target Layer
Target Penetration
Generate Target Penetration Layer
Tapestry Profile
Generate Segmentation Profile Report
Market Potential
Analyze Market Potential
Market Area and Gap Analysis
Analyze Market Area Gap
In Business Analyst Pro, the equivalent functionality is also available as a workflow. The Target Marketing Wizard is available from the Business Analysis drop-down menu on the Analysis tab. The Four Quadrant (Game Plan) Map functionality is also available in Business Analyst Pro, but it is only in the Target Marketing Wizard.
Territory Solution
Create Territory Solution
Balance Territories
Set Balance Variables
Add Territory Level
Add Territory Level
Manage External Variables
Load Territory Records
Setup Barriers
Add Territory Barriers
Export Territories
Export Territory Solution
Reports
Generate Territory Report
Import territories from a database
Import Territory Solution
Setup Level Capacity Constraints
Set Territory Attribute Constraints
Setup Level Distance Constraints
Set Territory Distance Parameters
In Business Analyst Pro, the equivalent functionality is also available through tools on the ribbon on the Territory Design tab.
ArcGIS Pro tools
Some ArcGIS Business Analyst Desktop tools and workflows do not have complete equivalents in ArcGIS Business Analyst Pro. The following table lists ArcGIS Pro tools that provide similar functionality:
ArcGIS Pro
Create a store/customer layer with address data
Geocode a table of addresses
Setup store/customers using XY data
Display XY data
Create an empty store/customer layer
Create a point feature class
Thematic Mapping
Symbolize feature layers
Summarize Points
Summarize Within
