| Name | Description | |
![]() | ApplyStyle | (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | CanApplyStyle | Overridden. Gets whether the StyleItem can be applied |
![]() | CompareTo | Compare Elements by name. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | ConvertToGraphics | Convert the element to graphics. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | Equals | Overloaded. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetAnchor | Gets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetAnchorPoint | Get the element anchor point location. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetBounds | Gets the bounding box for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetCustomProperty | Gets a Custom Property value for the element. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetDefinition | Returns the element's CIM definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetGeometry | (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetHashCode | Serves as the default hash function. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetHeight | Gets the height of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetLockedAspectRatio | Gets the locked aspect ratio value of the element. If This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetParent | Gets the parent of this element. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetRotation | Gets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetWidth | Gets the width of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetX | Gets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | GetY | Gets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetAnchor | Sets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetAnchorPoint | Sets the element anchor point to the X and Y location specified. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetCustomProperties | Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetCustomProperty | Overloaded. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetDecorative | Sets whether the element is decorative in an accessible PDF. Decorative elements are not read by assistive technologies. This setting will be ignored for elements that do not support the decorative flag. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetDefinition | Applies the changes made to a modified CIMElement back to the element on the page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetGeometry | (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetHeight | Sets the height of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetLocked | Sets the locked state of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetLockedAspectRatio | Sets the locked aspect ratio value of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetMapFrame | Sets a MapFrame to the MapSurround. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.MapSurround) |
![]() | SetName | Sets the name of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetRotation | Sets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetTOCPositionAbsolute | Sets the position of an element either at the top or bottom of the layout TOC or a group element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetTOCPositionRelative | Overloaded. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetVisible | Sets the visibility of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetWidth | Sets the width of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetX | Sets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
![]() | SetY | Sets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element) |
