ArcGIS.Desktop.Layouts Namespace / ElevationGuideBar Class
Properties Methods Events
    ElevationGuideBar Class Members
    The following tables list the members exposed by ElevationGuideBar.
    Public Properties
     NameDescription
    Public Property Gets whether the given element can be converted to graphics (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets the Custom Properties for the element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets whether the element fits the frame. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets or sets if a group element is expanded in the contents pane. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets the locked state of an element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets the visibility of an element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public PropertyGets the MapFrame associated with the MapSurround. (Inherited from ArcGIS.Desktop.Layouts.MapSurround)
    Public Property Gets the name of the element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Property Gets the Z order of the element relative to its parent (Inherited from ArcGIS.Desktop.Layouts.Element)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets whether the StyleItem can be applied (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Compare Elements by name. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Convert the element to graphics. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public MethodOverloaded.  (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Get the element anchor point location. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the bounding box for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets a Custom Property value for the element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Returns the element's CIM definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Serves as the default hash function. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the height of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the locked aspect ratio value of the element. If This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the parent of this element. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the width of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Gets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the anchor position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the element anchor point to the X and Y location specified. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public MethodApplies the changes made to a modified CIMElement back to the element on the page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the height of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the locked state of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the locked aspect ratio value of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public MethodSets a MapFrame to the MapSurround. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.MapSurround)
    Public Method Sets the name of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the position of an element either at the top or bottom of the layout TOC or a group element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the visibility of an element on a page layout. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the width of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the X position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Public Method Sets the Y position of the element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Layouts.Element)
    Top
    Protected Methods
     NameDescription
    Protected MethodOverridden.  Get the style element
    Protected MethodOverridden.  Get the style type
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
