Topographic Production toolbox licensing
Toolset/Tool
Basic
Standard
Advanced
Cartography/Banding toolset
Generate Elevation Bands
Not included
Not included
Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry and Spatial Analyst
Generate Elevation Bands From Features
Not included
Not included
Cartography/Cartographic Refinement toolset
Apply Building Offsets
Not included
Not included
Apply Masks From Rules
Not included
Apply Visual Specification To Map
Not included
Calculate Bridge Offsets
Not included
Make Masks From Rules
Not included
Thin Spot Heights
Not included
Not included
Cartography/Features toolset
Apply Element Values
Not included
Calculate Magnetic Components
Not included
Calculate Max Elevation Figures
Not included
Generate Adjoining Sheets Features
Not included
Not included
Generate Elevation Guide Features
Not included
Not included
Requires Topographic Mapping and Spatial Analyst
Generate Isogonic Lines
Not included
Not included
Generate Location Diagram Features
Not included
Not included
Generate Spot Heights
Not included
Not included
Generate Topographic Contours
Not included
Not included
Identify Contours
Not included
Not included
Validate Spot Heights
When the Use Input Rasters for Validation parameter is unchecked, the tool will run with Named User Licensing using ArcGIS Enterprise as a licensing portal with a Professional user type that has the ArcGIS Topographic Mapping extension enabled.
Not included
Not included
Cartography/Layout toolset
Generate Product Layout
Not included
Not included
Make Grids And Graticules Layer
Not included
Populate Map Sheet Info
Not included
Data Management/Features toolset
Apply Feature Level Metadata
Not included
Calculate Default Values
Not included
Calculate Metrics
Some parameters require the Spatial Analyst extension—see the tool reference page for more detail.
Not included
Not included
Merge Lines By Pseudo Node
Not included
Remove Cutback Vertices
Not included
Not included
Repair Self Intersection
Not included
Split Features
Not included
Update GeoNames
Not included
Data Management/Generalization toolset
Eliminate Polygon
Not included
Export Generalized Data
Not included
Fill Gaps
Not included
Not included
Identify Narrow Polygons
Not included
Not included
Import Generalization Data
Not included
Polygon To Centerline
Not included
Remove Small Lines
Not included
Not included
Set Line Direction
Not included
Not included
Thin Hydrology Lines
Not included
Data Management/Geodatabase toolset
Create Cross-Reference Geodatabase
Not included
Export MGCP Metadata
Not included
Extract Data By Feature
Not included
Generate Excel From Geodatabase
Not included
Generate Geodatabase From Excel
Not included
Geodatabase To Shape
Not included
GeoNames To Geodatabase
Not included
Import MGCP Metadata
Not included
Load Data
Not included
Unzip MGCP Cell And Import
Not included
Update Topographic Production Service Database
Not included
Data Management/Topology toolset
Export Topology
Not included
Import Topology
Not included
Data Management/Validation toolset
GAIT
Not included
Workflow toolset
Download Job Files
Not included
Upload Job Files
Not included
