List of ArcGIS Spatial Analyst raster functions
Available with Spatial Analyst license.
The Spatial Analyst extension provides a rich suite of raster functions in ArcGIS Pro.
Raster functions
Raster functions that require a Spatial Analyst extension license are organized into related groupings in the following categories: Analysis, Classification, Data Management, Distance, Distance (Legacy), Hydrology, Math, Math: Conditional, Math: Logical, Math: Trigonometrical, Reclass, Surface, and Statistical.
Each function is linked within the table to a detailed description.
Analysis functions
Use these functions to perform density analysis or to combine several rasters into a single output.
Function name
Kernel Density
Calculates a magnitude-per-unit area from point or polyline features, using a kernel function to fit a smoothly tapered surface to each point or polyline.
Process Raster Collection
Processes each slice in a multidimensional raster layer or each item in a mosaic layer.
Weighted Overlay
Overlays several rasters using a common measurement scale and weights each according to its importance.
Weighted Sum
Weights and adds an array of rasters on a cell-by-cell basis.
Classification functions
Use these functions to prepare segmented rasters or pixel-based raster datasets to use in creating classified raster datasets.
Function name
Classify
Applies the appropriate classifier and associated training data specified in the .ecd training file to a raster dataset or segmented raster.
Linear Spectral Unmixing
Performs subpixel classification and calculates the fractional abundance of different land-cover types for individual pixels.
Maximum Likelihood Classify
Performs a maximum likelihood classification on a raster dataset or mosaic dataset.
Segment Mean Shift
Groups pixels that are adjacent and have similar spectral characteristics into segments. This can be used as a second raster in the Classify function.
Data Management functions
Use these to either clean up small erroneous data in the raster or generalize the data to get rid of unnecessary detail for a more general analysis.
Function name
Aggregate
Generates a reduced-resolution version of a raster.
Boundary Clean
Smooths the boundary between zones.
Expand
Expands specified zones of a raster by zones by a specified number of cells.
Nibble
Replaces selected cells of a raster with the value of their nearest neighbor. This is useful for editing areas of a raster in which the data may be erroneous.
Region Group
Records, for each cell in the output, the identity of the connected region to which that cell belongs. A unique number is assigned to each region.
Shrink
Shrinks specified zones of a raster by a specified number of cells.
Distance functions
These functions allow you to perform analysis that accounts for either straight-line (Euclidean) or weighted distance. Distance can be weighted by a simple cost (friction) surface, or in ways that account for vertical and horizontal restrictions to movement.
Function name
Distance Accumulation
Calculates accumulated distance for each cell to sources, allowing for straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Distance Allocation
Calculates distance allocation for each cell to the provided sources based on straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Least Cost Corridor
Calculates the sum of two accumulative cost distance rasters with the option to apply a threshold based on percentage or accumulative cost.
Optimal Path As Raster
Calculates the optimal path from destinations to sources.
Distance (Legacy) functions
These functions allow you to access the distance analysis raster functions available in previous releases of ArcGIS. These functions perform analysis that accounts for either straight-line (Euclidean) or weighted distance. Distance can be weighted by a simple cost (friction) surface, or in ways that account for vertical and horizontal restrictions to movement. The Legacy Distance functions utilize the original method of computing distance from earlier releases. To take advantage of the more accurate distance calculations now available, use the distance functions outside of the Legacy function category.
Function name
Corridor
Calculates the sum of accumulative costs for two input accumulative cost rasters.
The Least Cost Corridor function provides enhanced functionality or performance.
Cost Allocation
Calculates, for each cell, its least-cost source based on the least accumulative cost over a cost surface.
The Distance Allocation function provides enhanced functionality or performance.
Cost Back Link
Defines the neighbor that is the next cell on the least-accumulative cost path to the least-cost source.
The Distance Accumulation function provides enhanced functionality or performance.
Cost Distance
Calculates the least-accumulative cost distance for each cell from or to the least-cost source over a cost surface.
Cost Path
Calculates the least-cost path from a source to a destination.
The Optimal Path As Raster function provides enhanced functionality or performance.
Euclidean Allocation
Calculates, for each cell, the nearest source based on Euclidean distance.
Euclidean Back Direction
Calculates, for each cell, the direction, in degrees, to the neighboring cell along the shortest path back to the closest source while avoiding barriers.
Euclidean Direction
Calculates, for each cell, the direction, in degrees, to the nearest source.
Euclidean Distance
Calculates, for each cell, the Euclidean distance to the closest source.
Least Cost Path
Calculates the least-cost path from a source to a destination. The least accumulative cost distance is calculated for each cell over a cost surface to the nearest source. This produces an output raster that records the least-cost path, or paths, from selected locations to the closest source cells defined within the accumulative cost surface, in terms of cost distance.
The Distance Accumulation and Optimal Path As Raster functions provide enhanced functionality or performance.
Path Distance
Calculates, for each cell, the least accumulative cost distance from or to the least-cost source, while accounting for surface distance along with horizontal and vertical cost factors.
Path Distance Allocation
Calculates the least-cost source for each cell based on the least accumulative cost over a cost surface, while accounting for surface distance along with horizontal and vertical cost factors.
Path Distance Back Link
Defines the neighbor that is the next cell on the least accumulative cost path to the least-cost source, while accounting for surface distance along with horizontal and vertical cost factors.
Hydrology functions
These functions are used to model the flow of water across a surface. These functions can be applied individually or used in sequence to create a stream network or delineate watersheds.
Function name
Fill
Fills sinks and peaks in an elevation surface raster to remove small imperfections in the data.
Flow Accumulation
Creates a raster layer of accumulated flow into each cell. A weight factor can optionally be applied.
Flow Direction
Creates a raster layer of flow direction from each cell to its steepest downslope neighbor.
Flow Distance
Computes the minimum downslope horizontal or vertical distance to cell(s) on a stream or river into which they flow.
Flow Length
Creates a raster layer of upstream or downstream distance, or weighted distance, along the flow path for each cell.
Sink
Creates a raster layer identifying all sinks or areas of internal drainage.
Snap Pour Point
Snaps pour points to the cell of highest flow accumulation within a specified distance.
Stream Link
Assigns unique values to sections of a raster linear network between intersections.
Stream Order
Creates a raster layer that assigns a numeric order to segments of a raster representing branches of a linear network.
Watershed
Determines the contributing area above a set of cells in a raster.
Math functions
The general math functions apply a mathematical function to the input raster(s). These tools fall into several categories. The arithmetic tools perform basic mathematical operations, such as addition and multiplication. There are tools that perform various types of exponentiation operations, which include exponentials and logarithms, in addition to the basic power operations. The remaining functions are used either for sign conversion or for conversion between integer and floating point data types.
Function name
Abs
Calculates the absolute value of the pixels in a raster.
Arithmetic
Uses the pixel values to calculate mathematical operations on overlapping rasters.
Band Arithmetic
Calculates indexes using the predefined formulas or user-defined expressions.
Calculator
Computes a raster from a mathematical expression based on the raster bands.
Divide
Divides the values of two rasters on a pixel-by-pixel basis.
Exp
Calculates the base e exponential of the pixels in a raster.
Exp10
Calculates the base 10 exponential of the pixels in a raster.
Exp2
Calculates the base 2 exponential of the pixels in a raster.
Float
Converts each pixel value of a raster into a floating-point representation.
Int
Converts each pixel value of a raster to an integer by truncation.
Ln
Calculates the natural logarithm (base e) of each pixel in a raster.
Log10
Calculates the base 10 logarithm of each pixel in a raster.
Log2
Calculates the base 2 logarithm of each pixel in a raster.
Minus
Subtracts the value of the second input raster from the value of the first input raster on a pixel-by-pixel basis.
Mod
Finds the remainder (modulo) of the first raster when divided by the second raster on a pixel-by-pixel basis.
Negate
Changes the sign (multiplies by -1) of the pixel values of the input raster on a pixel-by-pixel basis.
Plus
Adds (sums) the values of two rasters on a pixel-by-pixel basis.
Power
Raises the pixel values in a raster to the power of the values found in another raster.
Round Down
Returns the next lower integer, as a floating-point value, for each pixel in a raster.
Round Up
Returns the next higher integer, as a floating-point value, for each pixel in a raster.
Square
Calculates the square of the pixel values in a raster.
Square Root
Calculates the square root of the pixel values in a raster.
Times
Multiplies the values of two rasters on a pixel-by-pixel basis.
Math: Conditional
These functions allow you to control the output values based on the conditions placed on the input values.
Function name
Con
Performs a conditional if/else evaluation on each of the input cells of an input raster.
Set Null
Sets identified pixel locations to NoData based on the specified criteria. Returns NoData if a conditional evaluation is true, and returns the value specified by another raster if it is false.
Math: Logical
These functions evaluate the values of the inputs and determine the output values based on Boolean logic. These functions process raster datasets in three main areas: Bitwise, Boolean, and Relational.
Function name
Bitwise And
Performs a Bitwise And operation on the binary values of two input rasters.
Bitwise Left Shift
Performs a Bitwise Left Shift operation on the binary values of two input rasters.
Bitwise Not
Performs a Bitwise Not (complement) operation on the binary value of an input raster.
Bitwise Or
Performs a Bitwise Or operation on the binary values of two input rasters.
Bitwise Right Shift
Performs a Bitwise Right Shift operation on the binary values of two input rasters.
Bitwise Xor
Performs a Bitwise eXclusive Or operation on the binary values of two input rasters.
Boolean And
Performs a Boolean And operation on the pixel values of two input rasters.
If both input values are true (nonzero), the output value is 1. If one or both input values are false (zero), the output value is 0.
Boolean Not
Performs a Boolean Not (complement) operation on the pixel values of the input raster.
If the input values are true (nonzero), the output value is 0. If the input values are false (zero), the output value is 1.
Boolean Or
Performs a Boolean Or operation on the cell values of two input rasters.
If one or both input values are true (nonzero), the output value is 1. If both input values are false (zero), the output value is 0.
Boolean Xor
Performs a Boolean eXclusive Or operation on the cell values of two input rasters.
If one input value is true (nonzero) and the other value is false (zero), the output value is 1. If both input values are true or both are false, the output value is 0.
Equal To
Performs an equal-to operation on two rasters on a pixel-by-pixel basis.
Greater Than
Performs a Relational greater-than operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is greater than the second raster and a value of 0 for pixels where the first raster is not greater than the second raster.
Greater Than Equal
Performs a Relational greater-than-or-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is greater than or equal to the second raster and a value of 0 for pixels where the first raster is not greater than or equal to the second raster.
Is Null
Determines which values from the input raster are NoData on a pixel-by-pixel basis.
Returns a value of 1 if the input value is NoData and a value of 0 for pixels that are not NoData.
Less Than
Performs a Relational less-than operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is less than the second raster.
Less Than Equal
Performs a Relational less-than-or-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is less than or equal to the second raster and a value of 0 where it is not less than or equal to the second raster.
Not Equal
Performs a Relational not-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is not equal to the second raster and a value of 0 for pixels where it is equal to the second raster.
Math: Trigonometric
Use these functions perform various trigonometric calculations on the values in an input raster.
Function name
ACos
Calculates the inverse cosine of the pixels in a raster.
ACosH
Calculates the inverse hyperbolic cosine of the pixels in a raster.
ASin
Calculates the inverse sine of the pixels in a raster.
ASinH
Calculates the inverse hyperbolic sine of the pixels in a raster.
ATan
Calculates the inverse tangent of the pixels in a raster.
ATan2
Calculates the inverse tangent (based on x,y) of the pixels in a raster.
ATanH
Calculates the inverse hyperbolic tangent of the pixels in a raster.
Cos
Calculates the cosine of the pixels in a raster.
CosH
Calculates the hyperbolic cosine of the pixels in a raster.
Sin
Calculates the sine of the pixels in a raster.
SinH
Calculates the hyperbolic sine of the pixels in a raster.
Tan
Calculates the tangent of the pixels in a raster.
TanH
Calculates the hyperbolic tangent of the pixels in a raster.
Reclass functions
Use this function to create an output based on an attribute of the input raster.
Function name
Lookup
Creates a new raster by looking up values found in another field in the table of the input raster.
Surface functions
Use these functions to derive terrain characteristics or visibility from a digital elevation model.
Function name
Surface Parameters
Determines parameters of a raster surface such as aspect, slope, and curvature using geodesic methods.
Viewshed
Determines the raster surface locations visible to a set of observer features using geodesic methods.
Statistical functions
Use these functions to perform statistical raster operations on a local, neighborhood, or zonal basis.
Function name
Cell Statistics
Calculates statistics from multiple rasters on a pixel-by-pixel basis.
Dimensional Moving Statistics
Calculates statistics over a moving window on multidimensional data along a specified dimension.
Focal Statistics
Calculates statistics on the cells within a neighborhood around each cell of an input raster. Several shapes of neighborhood are available.
Zonal Statistics
Summarizes the values of a raster within the zones of another dataset.
