Analysis toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Apportion Polygon
Version
3.4
Parameter apportion_fields has new data type: Value Table
Parameter apportion_fields had data type removed: Field
2.8
Parameter method has 2 new options:
  • POINTS
  • LENGTH
2.7
New at this version
Assign Weights By Pairwise Comparison
Version
3.5
New at this version
Buffer
Version
1.0
Ported from ArcMap 10.3
Clip
Version
3.0
Parameter in_features has new data type: Building Scene Layer
2.8
Parameter in_features has 2 new data types:
  • Scene Layer
  • File
Parameter out_feature_class has new data type: File
1.3
Environment added: Parallel Processing Factor
1.0
Count Overlapping Features
Version
2.5
New at this version
Create Thiessen Polygons
Version
2.0
The algorithm used to generate Thiessen polygons was rewritten. The new algorithm delivers significant improvement in performance while requiring less memory.
1.0
Enrich
Version
2.2
New at this version
Enrich Layer
Version
2.2
Deprecated
This is a deprecated tool. This functionality has been replaced by the Enrich tool.
1.1
Parameter buffer_type has 5 new options:
  • WALKING_TIME
  • TRUCKING_DISTANCE
  • DRIVING_DISTANCE
  • WALKING_DISTANCE
  • TRUCKING_TIME
1.0
New at this version
Erase
Version
3.7
License changed from Standard to Basic
1.3
1.0
Frequency
Version
2.7
License changed from Advanced to Basic
1.0
Generate Near Table
Version
3.5
New parameter added: match_fields
3.1
New parameter added: distance_unit
2.7
1.0
Generate Origin-Destination Links
Version
2.6
New at this version
Graphic Buffer
Version
1.4
New at this version
Identity
Version
1.3
1.0
Intersect
Version
1.3
1.0
Multiple Ring Buffer
Version
2.9
New parameter added: Method
1.0
Near
Version
3.5
3.1
2.7
2.6
New parameter added: field_names
1.0
Pairwise Buffer
Version
1.3
New at this version
Pairwise Clip
Version
3.6
New parameter added: precision
2.7
New at this version
Pairwise Dissolve
Version
3.7
New parameter added: out_lineage_table
3.0
New parameter added: concatenation_separator
1.1
New at this version
Pairwise Erase
Version
2.7
New at this version
Pairwise Integrate
Version
2.7
New at this version
Pairwise Intersect
Version
3.5
1.0
New at this version
Pairwise Polygon Neighbors
Version
3.6
New at this version
Polygon Neighbors
Version
3.5
Parameter out_area_units has 2 new options:
  • SQUARE_NAUTICAL_MILES
  • SQUARE_NAUTICAL_MILES_US
3.2
Parameter out_area_units has 5 new options:
  • SQUARE_MILES_US
  • ACRES_US
  • SQUARE_YARDS_US
  • SQUARE_FEET_US
  • SQUARE_INCHES_US
Parameter out_linear_units has 5 new options:
  • INCHES_INTERNATIONAL
  • NAUTICAL_MILES_INTERNATIONAL
  • MILES_INTERNATIONAL
  • YARDS_INTERNATIONAL
  • FEET_INTERNATIONAL
1.0
Remove Overlap (multiple)
Version
2.7
New at this version
Select
Version
1.0
Spatial Join
Version
3.6
Parameter join_features has new data type: Value Table
Parameter join_features had data type removed: Feature Layer
3.2
2.9
Parameter match_option had new option added: LARGEST_OVERLAP
1.0
Split
Version
1.3
1.0
Split By Attributes
Version
2.4
Parameter Target_Workspace2 has new data type: Feature Dataset
Parameter Target_Workspace has new data type: Feature Dataset
1.3
New at this version
Summary Statistics
Version
3.4
Parameter statistics_fields has 9 new options:
  • DBMS_COUNT
  • DBMS_MAX
  • DBMS_MEAN
  • DBMS_MEDIAN
  • DBMS_MIN
  • DBMS_STD
  • DBMS_SUM
  • DBMS_VARIANCE
  • MODE
3.0
Parameter statistics_fields has new option added: CONCATENATE
2.6
Parameter statistics_fields has new option added: UNIQUE
2.1
Parameter statistics_fields has 2 new options:
  • MEDIAN
  • VARIANCE
1.0
Summarize Nearby
Version
1.1
Parameter distance_units changed from Optional to Required
1.0
New at this version
Summarize Within
Version
1.0
New at this version
Symmetrical Difference
Version
1.0
Table Select
Version
1.0
Tabulate Intersection
Version
3.5
Parameter out_units has 2 new options:
3.2
Parameter out_units has 10 new options:
  • SQUARE_MILES_US
  • ACRES_US
  • SQUARE_YARDS_US
  • SQUARE_INCHES_US
  • SQUARE_FEET_US
1.0
Union
Version
1.3
1.0
Update
Version
1.3
1.0
