ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class
    StandaloneTable Class Methods
    For a list of all members of this type, see StandaloneTable members.
    Public Methods
     NameDescription
    Public Method Gets if the mapMember supports time filtering and can clear the time filter. Clearing the time filter ensures that data is always shown. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public MethodReturns true if the data can be edited.
    Public Method Gets if the mapMember supports time filtering. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Check if the standalone table's data source can be replace with this table. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets if the mapMember supports time filtering and if the specified time parameters are valid. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Clears the current selection. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Clears the time filter for the mapMember. Clearing the time filter ensures that data is always shown. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Exports the MapMember's current popup configuration to a .pop file. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Performs a find and replace of workspace path for the table. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets whether the StandaloneTable metadata can be edited or not. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a CIMDataConnection value object. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Gets the time extent of the data for the specified fieldName - that is the minimum and maximum dates present in the data. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Gets the set of time intervals for the specified field name present in the data. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Returns the standalone table's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the display expressions of the given set of objects. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Returns fields of the standalone table including joined fields, if any. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets the StandaloneTable metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the path of the dataset underneath the MapMember as a Uri. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Gets the current selection of the table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Returns the underlying table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the current time parameters for the mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Gets whether or not the MapMember stores its own metadata or uses metadata retrieved from its source. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Imports a .pop file and sets the popup configuration for the MapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public MethodInsert a list of DefinitionQuery. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodInserts a DefinitionQuery. If makeActive is true, makes it the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets if time is supported for this mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Removes the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Remove all definition queries. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Removes the definition queries specified by the list of names. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Removes the definition query at the specified index. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Replace the standalone table's data source. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Executes a query to the underlying data source and returns rows matching the search criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Selects rows based upon the specified criteria and combination method. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodSets the definition query matching the specified queryName to be the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Updates a MapMember's data source. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Updates the standalone table's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the where clause of the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the display expression info with an arcade expression that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the name of the attribute field that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Enables or disables editing on a standalone table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Applies updates to the editable properties of fields. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Sets the StandaloneTable metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the display name for the MapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Toggles the selectability. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the current selection of the table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Toggles the SelectRelatedData of a MapMember. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Toggles enabling pop-ups for the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Sets the specified time parameters for the mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Sets whether or not the MapMember will use its own metadata or the metadata from its underyling source (if it has one). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Public Method Returns the display name of the MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember)
    Top
    Protected Methods
     NameDescription
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
    Extension Methods
     NameDescription
    Public Extension Method Gets whether templates have been loaded for the specified map member.
    Public Extension Method Generate feature templates for a layer or standalone-table. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodOverloaded.
    Public Extension MethodGet the time zone for a specific field of a MapMember.
    Public Extension Method Gets a template by name for a map member. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets all templates for a map member. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets all templates for a map member, including templates for any children. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension MethodLoads a row into a new inspector instance. This method must be called on the MCT. Use QueuedTask.Run.
    Top
