Location Referencing toolbox licensing
Toolset/Tool
Basic
Standard
Advanced
Append Events
Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
Append Routes
Apply Event Behaviors
Calculate Intersecting Route Measures
Calculate Route Concurrencies
Delete Routes
Derive Event Measures
Generate Calibration Points
Generate Events
Generate Intersections
Generate Routes
Overlay Events
Remove Overlapping Centerlines
Reverse Line Orders
Translate Event Measures
Update Measures From LRS
Configuration toolset
Configure Address Feature Classes
Configure Utility Network Feature Class
Configure Utility Network Feature Classes
Remove LRS Entity
Configuration/LRS toolset
Create LRS
Create LRS From Existing Dataset
Modify LRS
Configuration/LRS Event toolset
Configure External Event Behaviors With LRS
Configure External Event With LRS
Create LRS Event
Create LRS Event From Existing Dataset
Disable Derived Measure Fields
Disable Referent Fields
Disable Stationing Fields
Enable Derived Measure Fields
Enable Referent Fields
Enable Stationing Fields
Modify Event Behavior Rules
Modify LRS Event
Configuration/LRS Intersection toolset
Create LRS Intersection
Create LRS Intersection From Existing Dataset
Modify LRS Intersection
Configuration/LRS Network toolset
Configure Lookup Table
Configure Route Dominance Rules
Create LRS Network
Create LRS Network From Existing Dataset
Modify LRS Network
Modify Network Calibration Rules
Modify Route ID Padding
Data Products toolset
Generate Linear Referenced Feature Count
Generate Linear Referenced Length Summary
Generate Linear Referenced Route Log
Generate LRS Data Product
