ArcGIS Business Analyst Desktop equivalency
Available with Business Analyst license.
Business Analyst functionalities in ArcGIS Desktop and the equivalent tools and workflows in ArcGIS Pro are listed.
Evaluate Site
ArcGIS Business Analyst Desktop |
ArcGIS Business Analyst Pro |
Evaluate Site |
Custom Data Setup
BDS (Business Analyst Data Source) layers |
Add Business Listing
Add Business Listings |
In Business Analyst Pro, the equivalent functionality is also available as a workflow. Points of Interest Search is available from the Business Analysis drop-down menu on the Analysis tab.
Trade Area
Customer Derived Trade Areas |
Static/Simple Rings |
Drive Time Areas |
Threshold Data Driven Ring |
Threshold Trade Areas |
Measure Cannibalization |
Remove Trade Area Overlap |
Create Trade Area from Geography Levels/Online Geography Levels/Sub-geography layer |
Analysis
Append Data |
Determine Market Penetration |
Proximity Analysis (Locator Report) |
Create Spider Diagram (Desire Lines) |
Assign by closest store location |
Benchmark Report |
Reports
Run Summary/Demographic Reports or Quick Reports |
Wind Rose (Analytical Reports) |
Maps
Color Coded Maps toolbar |
Sales Potential Modeling
Original Huff Model |
Huff Model Calibration |
Target Marketing
Create Profiles: Create Customer Profile |
Create Profiles: Create Geographic Profile |
Create Profiles: Create Survey Profile |
Generate Survey Report for Profile and Generate Survey Report for Targets |
Create Profiles: Import Profile |
Target Groups |
Target Map |
Target Penetration |
Tapestry Profile |
Market Potential |
Market Area and Gap Analysis |
In Business Analyst Pro, the equivalent functionality is also available as a workflow. The Target Marketing Wizard is available from the Business Analysis drop-down menu on the Analysis tab. The Four Quadrant (Game Plan) Map functionality is also available in Business Analyst Pro, but it is only in the Target Marketing Wizard.
Territory Solution
Create Territory Solution |
Balance Territories |
Add Territory Level |
Manage External Variables |
Setup Barriers |
Export Territories |
Reports |
Import territories from a database |
Setup Level Capacity Constraints |
Setup Level Distance Constraints |
In Business Analyst Pro, the equivalent functionality is also available through tools on the ribbon on the Territory Design tab.
ArcGIS Pro tools
Some ArcGIS Business Analyst Desktop tools and workflows do not have complete equivalents in ArcGIS Business Analyst Pro. The following table lists ArcGIS Pro tools that provide similar functionality:
ArcGIS Pro |
Create a store/customer layer with address data |
Setup store/customers using XY data |
Create an empty store/customer layer |
Thematic Mapping |
Summarize Points |
