Spatial Statistics toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Version |
Description |
3.4 |
New at this version |
Version |
Description |
1.0 |
Ported from ArcMap 10.3 |
Version |
Description |
3.4 |
Version |
Description |
3.7 |
2 parameters added:
Parameter |
2.5 |
Parameter Parameter Default value for parameter Parameter Default value for parameter |
2.4 |
Version |
Description |
1.0 |
Version |
Description |
3.1 |
Version |
Description |
3.3 |
Version |
Description |
3.2 |
Version |
Description |
1.3 |
This tool now honors the 3D nature of your data and will use x, y and z values in its calculations if z values are available. |
1.0 |
Version |
Description |
2.5 |
New parameter added: Parameter Default value for parameter |
1.3 |
Environment added: Random number generator 2 new parameters added:
Parameter removed: Parameter order changed at parameter 10:
1.0 |
Version |
Description |
1.0 |
Version |
Description |
2.5 |
Version |
Description |
3.5 |
3.4 |
Version |
Description |
3.2 |
Version |
Description |
1.0 |
Version |
Description |
3.5 |
New parameter added: |
3.4 |
Version |
Description |
3.4 |
Version |
Description |
2.8 |
2.1 |
Version |
Description |
3.1 |
Version |
Description |
2.8 |
Parameter |
2.7 |
Version |
Description |
1.4 |
Environment added: Output Z Domain |
1.3 |
1.0 |
Version |
Description |
3.4 |
Version |
Description |
3.5 |
Version |
Description |
3.7 |
4 parameters added:
3.6 |
Version |
Description |
3.6 |
Evaluate Variable Influence for Predictions
Version |
Description |
3.7 |
Version |
Description |
1.0 |
Version |
Description |
2.6 |
Parameter |
1.0 |
Version |
Description |
3.3 |
3.2 |
11 new parameters added:
3.1 |
2.4 |
2.2 |
Version |
Description |
3.5 |
3.4 |
Version |
Description |
3.1 |
2.3 |
Version |
Description |
2.6 |
Generate Network Spatial Weights
Version |
Description |
2.6 |
Deprecated This is a deprecated tool. An enhanced version of this tool has been created with enhancements and new functionality including accepting networks from portal services. See the updated Generate Network Spatial Weights Matrix tool. |
1.2 |
Version |
Description |
3.6 |
7 new parameters added:
1.4 |
New parameter added: This new parameter allows neighborhood relationships to be defined in three-dimensions. |
1.0 |
Version |
Description |
3.0 |
2.4 |
Parameter Parameter |
2.3 |
Geographically Weighted Regression
Version |
Description |
2.3 |
Deprecated This is a deprecated tool. This functionality has been replaced by an enhanced Geographically Weighted Regression tool. |
1.0 |
Grouping Analysis
Version |
Description |
2.2 |
Deprecated This is a deprecated tool. The algorithm behind this tool has been enhanced and new functionality has been added to these methods. To simplify the features and methods, this tool has been replaced by two tools. Use the Spatially Constrained Multivariate Clustering tool if you would like to create spatially constrained groups. Use the Multivariate Clustering tool to create groups with no spatial constraints. |
2.1 |
The algorithm behind the this tool has been enhanced and new functionality has been added to these methods. To simplify the new features and methods, two new tools have been created to replace the Grouping Analysis tool. Use the Spatially Constrained Multivariate Clustering tool if you would like to create spatially contiguous groups. Use the Multivariate Clustering tool to create groups with no spatial constraints. |
1.0 |
Version |
Description |
2.5 |
1.0 |
Version |
Description |
2.5 |
1.0 |
Version |
Description |
3.1 |
Version |
Description |
3.3 |
The |
1.0 |
Version |
Description |
1.4 |
1.0 |
Version |
Description |
2.5 |
Parameter order changed at parameter 4:
2.4 |
Version |
Description |
1.3 |
1.0 |
Version |
Description |
1.3 |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
3.1 |
Parameter Parameter
3.0 |
Version |
Description |
3.7 |
2.1 |
Version |
Description |
2.7 |
Version |
Description |
1.4 |
Environments removed:
1.3 |
Parameter |
1.0 |
Version |
Description |
1.4 |
Version |
Description |
1.0 |
Version |
Description |
3.6 |
3.1 |
Version |
Description |
3.6 |
Version |
Description |
3.1 |
2.9 |
Version |
Description |
3.1 |
Version |
Description |
3.7 |
1.0 |
Version |
Description |
2.7 |
Version |
Description |
3.4 |
2.5 |
1.0 |
Version |
Description |
3.5 |
Version |
Description |
2.9 |
3 new parameters added:
2.7 |
Version |
Description |
3.7 |
2.1 |
Version |
Description |
1.4 |
1.3 |
1.0 |
Version |
Description |
2.8 |
