Spatial Statistics toolbox licensing
Toolset/Tool
Basic
Standard
Advanced
Analyzing Patterns toolset
Average Nearest Neighbor
Included
Included
Included
High/Low Clustering (Getis-Ord General G)
Included
Included
Included
Incremental Spatial Autocorrelation
Included
Included
Included
Multi-Distance Spatial Cluster Analysis (Ripley's K Function)
Included
Included
Included
Spatial Autocorrelation (Global Moran's I)
Included
Included
Included
Assessing Sensitivity toolset
Assess Sensitivity to Attribute Uncertainty
Included
Included
Included
Evaluate Bin Sizes for Point Aggregation
Included
Included
Included
Mapping Clusters toolset
Build Balanced Zones
Included
Included
Included
Calculate Composite Index
Included
Included
Included
Cluster and Outlier Analysis (Anselin Local Moran's I)
Included
Included
Included
Density-based Clustering
Included
Included
Included
*Hot Spot Analysis (Getis-Ord Gi)**
Included
Included
Included
Hot Spot Analysis Comparison
Included
Included
Included
Multivariate Clustering
Included
Included
Included
Optimized Hot Spot Analysis
Included
Included
Included
Optimized Outlier Analysis
Included
Included
Included
Similarity Search
Advanced license is required to use Collapse Output To Points parameter.
Limited
Limited
Included
Spatial Outlier Detection
Spatial Analyst is required to use the Output Prediction Raster parameter.
Limited
Limited
Limited
Spatially Constrained Multivariate Clustering
Included
Included
Included
Measuring Geographic Distributions toolset
Central Feature
Included
Included
Included
Directional Distribution (Standard Deviational Ellipse)
Included
Included
Included
Directional Trend
Included
Included
Included
Linear Directional Mean
Included
Included
Included
Mean Center
Included
Included
Included
Median Center
Included
Included
Included
Neighborhood Summary Statistics
Advanced license is required to use Delaunay triangulation neighborhood type.
Limited
Limited
Included
Standard Distance
Included
Included
Included
Modeling Spatial Relationships toolset
Bivariate Spatial Association (Lee's L)
Included
Included
Included
Causal Inference Analysis
Included
Included
Included
Colocation Analysis
Included
Included
Included
Estimate Time to Event
Included
Included
Included
Evaluate Predictions with Cross-validation
Spatial Analyst is required to use rasters.
Limited
Limited
Limited
Evaluate Variable Influence for Predictions
Limited
Limited
Limited
Exploratory Regression
Included
Included
Included
Forest-based and Boosted Classification and Regression
Limited
Limited
Limited
Generalized Linear Regression
Included
Included
Included
Generate Network Spatial Weights
Requires Network Analyst
Generate Spatial Weights Matrix
Included
Included
Included
Geographically Weighted Regression (GWR)
Advanced license is required to generate coefficient rasters.
Limited
Limited
Included
Local Bivariate Relationships
Included
Included
Included
Multiscale Geographically Weighted Regression (MGWR)
Limited
Limited
Included
Ordinary Least Squares (OLS)
Included
Included
Included
Predict Using Spatial Statistics Model File
Limited
Limited
Limited
Prepare Data for Prediction
Limited
Limited
Limited
Presence-only Prediction (MaxEnt)
Included
Included
Included
Spatial Association Between Zones
Spatial Analyst is required to use rasters as input or output.
Limited
Limited
Limited
Spatial Autoregression
Included
Included
Included
Spatial Component Utilities (Moran Eigenvectors) toolset
Compare Neighborhood Conceptualizations
Included
Included
Included
Create Spatial Component Explanatory Variables
Included
Included
Included
Decompose Spatial Structure (Moran Eigenvectors)
Included
Included
Included
Filter Spatial Autocorrelation From Field
Included
Included
Included
Utilities toolset
Calculate Distance Band from Neighbor Count
Included
Included
Included
Calculate Rates
Included
Included
Included
Collect Events
Included
Included
Included
Convert Spatial Statistics Popup Charts for Web Display
Included
Included
Included
Convert Spatial Weights Matrix to Table
Included
Included
Included
Describe Spatial Statistics Model File
Included
Included
Included
Dimension Reduction
Included
Included
Included
Export Feature Attribute To ASCII
Included
Included
Included
Set Spatial Statistics Model File Properties
Included
Included
Included
Time Series Smoothing
Included
Included
Included
