Utility Network toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Add Angle Directed Layout
Version |
Description |
2.5 |
Deprecated Tool removed or moved to another toolbox. Now installed with the Network Diagram toolbox. |
2.1 |
New at this version |
Add Collapse Container By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.3 |
New parameter added: |
2.1 |
Add Collapse Container Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Add Compression Layout
Version |
Description |
2.5 |
2.1 |
Add Connectivity Associations Rule
Version |
Description |
2.5 |
2.1 |
Add Diagram Feature Capability By Attribute Rule
Version |
Description |
3.4 |
4 new parameters added:
Parameter
2.5 |
2.4 |
Add Diagram Template
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.1 |
Add Expand Container By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Add Expand Container Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Add Force Directed Layout
Version |
Description |
2.5 |
2.2 |
2 new parameters added:
2.1 |
Add Grid Layout
Version |
Description |
2.5 |
2.1 |
Add Linear Dispatch Layout
Version |
Description |
2.5 |
2.1 |
Add Main Ring Layout
Version |
Description |
2.5 |
2.2 |
Add Mainline Tree Layout
Version |
Description |
2.5 |
2.2 |
2.1 |
Version |
Description |
3.3 |
Parameter |
2.1 |
Version |
Description |
2.1 |
Add Partial Overlapping Edges Layout
Version |
Description |
2.5 |
2.1 |
Add Radial Tree Layout
Version |
Description |
2.5 |
2.1 |
Add Reduce Edge By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.3 |
2.1 |
Add Reduce Junction By Attribute Rule
Version |
Description |
3.4 |
2.5 |
2.4 |
Parameter |
2.1 |
Add Reduce Junction Rule
Version |
Description |
3.4 |
2.5 |
2.4 |
Parameter |
2.1 |
Add Relative Mainline Layout
Version |
Description |
2.5 |
2.3 |
Add Remove Feature By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Add Remove Feature Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Add Reshape Diagram Edges Layout
Version |
Description |
2.5 |
2.3 |
Parameter |
2.1 |
Version |
Description |
2.1 |
Add Set Root Junction By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.1 |
Add Set Starting Point By Attribute Rule
Version |
Description |
2.5 |
2.4 |
Parameter |
2.3 |
Add Smart Tree Layout
Version |
Description |
2.5 |
2.2 |
2.1 |
Add Spatial Dispatch Layout
Version |
Description |
2.5 |
2.1 |
Add Spatial Query Rule
Version |
Description |
2.5 |
2.3 |
Add Start Iteration Rule
Version |
Description |
2.5 |
2.1 |
Add Stop Iteration Rule
Version |
Description |
2.5 |
2.1 |
Add Structural Attachments Rule
Version |
Description |
2.5 |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
3.3 |
2.7 |
Version |
Description |
2.6 |
2.2 |
Add Trace Rule
Version |
Description |
2.5 |
2.1 |
Version |
Description |
3.7 |
Alter Diagram Properties
Version |
Description |
2.5 |
2.1 |
Alter Diagram Template
Version |
Description |
2.5 |
2.2 |
3 new parameters added:
2.1 |
Version |
Description |
3.5 |
Append to Diagram
Version |
Description |
2.5 |
2.1 |
Apply Angle Directed Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Compression Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Version |
Description |
3.5 |
Apply Force Directed Layout
Version |
Description |
2.5 |
2.4 |
2.2 |
2.1 |
Apply Geo Positions Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Grid Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Linear Dispatch Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Main Ring Layout
Version |
Description |
2.5 |
2.4 |
2.2 |
Apply Mainline Tree Layout
Version |
Description |
2.5 |
2.4 |
2.2 |
2.1 |
Apply Partial Overlapping Edges Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Radial Tree Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Relative Mainline Layout
Version |
Description |
2.5 |
2.4 |
2.3 |
Apply Rotate Tree Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Smart Tree Layout
Version |
Description |
2.5 |
2.4 |
2.2 |
2.1 |
Apply Spatial Dispatch Layout
Version |
Description |
2.5 |
2.4 |
2.1 |
Apply Template Layouts
Version |
Description |
2.5 |
2.1 |
Version |
Description |
3.5 |
Change Diagrams Owner
Version |
Description |
2.5 |
2.4 |
Create Diagram
Version |
Description |
2.5 |
2.1 |
Create Diagram Layer Definition
Version |
Description |
2.5 |
2.1 |
Version |
Description |
3.5 |
2.1 |
Version |
Description |
3.7 |
Delete Diagram
Version |
Description |
2.5 |
2.1 |
Delete Diagram Template
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.7 |
Version |
Description |
2.1 |
Version |
Description |
3.5 |
Version |
Description |
2.1 |
Version |
Description |
2.6 |
Parameter
2.1 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Export Diagram Content
Version |
Description |
2.5 |
2.4 |
Parameter |
2.3 |
Export Diagram Layer Definition
Version |
Description |
2.5 |
2.1 |
Export Diagram Template Definitions
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
3.5 |
New parameter added: Parameter |
2.9 |
2.6 |
Parameter
2.3 |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.7 |
Extend Diagram
Version |
Description |
2.5 |
2.2 |
2.1 |
Get Diagram Template Names
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.6 |
Parameter
2.1 |
Version |
Description |
3.7 |
Import Diagram Template Definitions
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.7 |
Make Diagram Layer
Version |
Description |
3.4 |
2.5 |
2.1 |
Version |
Description |
3.5 |
Overwrite Diagram
Version |
Description |
2.5 |
2.1 |
Purge Temporary Diagrams
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.7 |
Version |
Description |
3.3 |
Version |
Description |
2.5 |
2.4 |
2.3 |
Parameter |
2.1 |
Version |
Description |
2.2 |
New parameter added: Parameter order changed at parameter 9:
2.1 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.7 |
5 new parameters added:
2.6 |
8 new parameters added:
Parameter Parameter Parameter Parameter |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
Store Diagram
Version |
Description |
2.5 |
2.1 |
Version |
Description |
3.7 |
3.5 |
3.3 |
3.1 |
Parameter
2.9 |
Parameter
2.7 |
2.6 |
7 new parameters added:
2.4 |
2.3 |
2.2 |
Parameter
2.1 |
Update Diagram
Version |
Description |
2.5 |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
3.2 |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
2.7 |
