| Name | Description | |
![]() | GaussianSplatLayer Constructor |
The following tables list the members exposed by GaussianSplatLayer.
![]() | AllowDrapingOnIntegratedMesh | (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | BlendingMode | Gets the blending mode of a layer. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanConfigurePopups | Gets a value indicating whether the MapMember's pop-ups can be configured. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | ConnectionStatus | Gets a value indicating the MapMember's connection status. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | DepthPriority | Gets the depth priority of a layer. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | DisplayCacheType | Gets the layer's display cache type. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ElevationType | Returns the elevation type of the layer. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | HasJoins | Gets whether the layer has any joins (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | HasRelates | Gets whether the layer has any relates (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | IsExpanded | Gets whether the layer is expanded or collapsed on the TOC. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | IsVisible | Gets the layer's visibility state. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | LegendGroups | Gets a read only collection of legend groups. Check the LegendStatus property before accessing this collection. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | LegendStatus | Gets the status of the layer's legend. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | Map | Get the map which the MapMember belongs to. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | MapLayerType | Gets map layer type. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | MaxDisplayCacheAge | Gets the duration of display cache for the layer. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | MaxDistance | Gets the maximum distance (in meter) at which the layer is visible in a 3D scene or globe view. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | MaxScale | Gets the layer's maximum scale (representative fraction) at which the layer is visible in a 2D map view. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | MinDistance | Gets the minimum distance (in meter) at which the layer is visible in a 3D scene or globe view. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | MinScale | Gets the layer's minimum scale (representative fraction) at which the layer is visible in a 2D map view. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | Name | Gets the display name of the MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | Parent | Gets the parent of the layer. It is either the group layer it belongs to, or the map for layers that do not belong in any group layers. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | RasterizeOnExport | Gets and sets the rasterize on export flag. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SavedMaxScale | Gets and sets the maximum scale saved when ShowLayerAtAllScales is set to true. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SavedMinScale | Gets and sets the minimum scale saved when ShowLayerAtAllScales is set to true. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SceneLayerType | Gets the scene layer type. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ShowLayerAtAllScales | Gets and sets whether the layer is visible at all scales. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ShowPopups | Gets a value indicating whether the MapMember is configured to show pop-ups when a feature is clicked. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | SupportsMetadata | Gets whether the MapMember supports metadata (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | Transparency | Gets the transparency value set to the layer. 100 being fully transparent and 0 means opaque. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | URI | Gets the unique path of this MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | CanClearTime | Gets if the mapMember supports time filtering and can clear the time filter. Clearing the time filter ensures that data is always shown. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | CanGetTime | Gets if the mapMember supports time filtering. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | CanGetZs | Determines whether the layer can be used as an elevation source to retrieve Z values for geometries. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanGetZsAsync | Determines whether the layer can be used as an elevation source to retrieve Z values for geometries. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanReplaceDataSource | Check if the layer's data source can be replace with this dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanSetBlendingMode | Check if blending mode can be set on this layer. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanSetElevationTypeDefinition | Gets whether the elevation type definition can be set on the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | CanSetTime | Gets if the mapMember supports time filtering and if the specified time parameters are valid. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | ClearDisplayCache | Refreshes the layer drawing and clears the feature cache (for layer types supporting it). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ClearTime | Clears the time filter for the mapMember. Clearing the time filter ensures that data is always shown. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | ExportPopupConfiguration | Exports the MapMember's current popup configuration to a .pop file. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | FindAndReplaceWorkspacePath | Performs a find and replace of workspace path for the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetCanEditMetadata | Gets whether the Layer metadata can be edited or not. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetDataConnection | Gets a CIMDataConnection value object. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetDataTimeExtent | Gets the time extent of the data for the specified fieldName - that is the minimum and maximum dates present in the data. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetDataTimeIntervals | Gets the set of time intervals for the specified field name present in the data. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetDefinition | Returns the layer's CIM definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetEffectiveMaxScale | Returns computed effective maximum scale considering all its parent group layers. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetEffectiveMinScale | Returns computed effective minimum scale considering all its parent group layers. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetElevationTypeDefinition | Gets the elevation type definition for the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetMetadata | Gets the Layer metadata. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetPath | Gets the path of the dataset underneath the MapMember as a Uri. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetSpatialReference | Returns the layer spatial reference. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetTime | Gets the current time parameters for the mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetUseSourceMetadata | Gets whether or not the MapMember stores its own metadata or uses metadata retrieved from its source. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | GetZs | Overloaded. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | GetZsAsync | Overloaded. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ImportPopupConfiguration | Imports a .pop file and sets the popup configuration for the MapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | IsTimeSupported | Gets if time is supported for this mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | IsVisibleInView | (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | LoadLegend | Loads the layer's legend. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | QueryExtent | Returns extent of the layer optionally taking symbol size in account. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ReplaceDataSource | Replace the layer's data source. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetBlendingMode | Sets the layer's blending mode. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetCacheOptions | Sets the layer's caching options. If the layer's feature class supports feature caching, then both the display cache and feature cache are set otherwise just the display cache is set. This method must be called on the MCT. Use QueuedTask.Run (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetDataConnection | Updates a MapMember's data source. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | SetDefinition | Updates the layer's CIM definition. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetDisplayCacheMaxAge | Sets the duration after which the layer's display cache will be refreshed in the local storage. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetElevationTypeDefinition | Sets the elevation type definition for the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetExpanded | Sets whether the layer appears expanded i.e. showing legends on the TOC. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetMaxDistance | Sets the maximum distance (in meter) at which the layer is visible in a 3D scene or globe view. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetMaxScale | Sets the layer's maximum scale (representative fraction) at which the layer is visible in a 2D map view. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetMetadata | Sets the Layer metadata. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetMinDistance | Sets the minimum distance (in meter) at which the layer is visible in a 3D scene or globe view. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetMinScale | Sets the layer's minimum scale (representative fraction) at which the layer is visible in a 2D map view. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetName | Sets the display name for the MapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | SetShowLayerAtAllScales | Sets whether the layer is visible at all scales. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetShowPopups | Toggles enabling pop-ups for the layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | SetTime | Sets the specified time parameters for the mapMember. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | SetTransparency | Sets the transparency of the layer. 100 being fully transparent and 0 means opaque. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetUseSourceMetadata | Sets whether or not the Layer will use its own metadata or the metadata from its underlying source (if it has one). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | SetVisibility | Sets the layer visibility. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | ToString | Returns the display name of the MapMember. (Inherited from ArcGIS.Desktop.Mapping.MapMember) |
![]() | NotifyPropertyChanged | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | SetProperty | Overloaded. (Inherited from ArcGIS.Desktop.Mapping.Layer) |
![]() | AreTemplatesLoaded | Gets whether templates have been loaded for the specified map member. |
![]() | AutoGenerateTemplates | Generate feature templates for a layer or standalone-table. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | CanEditData | Checks if the data represented by the map member can be edited. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | CreatePresetTemplate | Creates a new preset template from the specified set of features. |
![]() | CreateTemplate | Overloaded. |
![]() | GetFieldTimeZone | Get the time zone for a specific field of a MapMember. |
![]() | GetTemplate | Gets a template by name for a map member. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | GetTemplates | Gets all templates for a map member. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | GetTemplatesAsFlattenedList | Gets all templates for a map member, including templates for any children. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | Inspect | Loads a row into a new inspector instance. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | IsControlledByParcelFabricAsync | Gets whether the layer is controlled by a parcel fabric of the specified type. |
![]() | RemoveTemplate | Overloaded. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
