Image Analyst toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Version |
Description |
3.6 |
An input raster with rectangular cells will be processed so that the output raster cells will be square with sides equal to the average of the rectangular length and width. |
2.3 |
New environment added: |
2.1 |
New at this version |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.8 |
3 new parameters added:
Parameter |
2.6 |
2.5 |
Parameter
Parameter
2.4 |
Version |
Description |
2.6 |
Version |
Description |
2.7 |
Version |
Description |
3.6 |
Version |
Description |
3.6 |
Parameter |
3.4 |
Version |
Description |
3.0 |
Version |
Description |
3.3 |
New parameter added: |
3.0 |
Version |
Description |
3.0 |
Version |
Description |
3.0 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.6 |
Version |
Description |
3.6 |
2.9 |
2 new parameters added:
Parameter |
2.5 |
New parameter added: This parameter has two options: |
2.3 |
2.1 |
Version |
Description |
3.5 |
Some deep learning models support Gradient-weighted Class Activation Mapping (Grad-CAM). |
2.9 |
2.6 |
Parameter
2.5 |
Version |
Description |
3.3 |
3.2 |
3.1 |
New parameter added: Parameter |
2.7 |
2.5 |
2.3 |
Version |
Description |
2.6 |
Parameter
Parameter
2.2 |
Parameter
Parameter
2.1 |
Version |
Description |
3.6 |
Parameter
3.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.7 |
Version |
Description |
3.5 |
Version |
Description |
3.0 |
Parameter
2.9 |
2.7 |
Version |
Description |
3.4 |
Version |
Description |
2.1 |
Version |
Description |
3.2 |
Version |
Description |
2.1 |
Version |
Description |
3.6 |
2.3 |
2.1 |
Version |
Description |
3.6 |
Parameter |
3.2 |
Parameter |
3.1 |
Parameter
Parameter
3.0 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.5 |
2.9 |
2.1 |
Version |
Description |
3.2 |
Version |
Description |
3.0 |
Version |
Description |
3.3 |
Deep Learning Model To Ecd
Version |
Description |
2.3 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Export Training Data For Deep Learning tool that creates classification information for use in the deep learning model. |
2.1 |
Version |
Description |
3.0 |
Version |
Description |
3.2 |
Version |
Description |
2.8 |
6 new parameters added:
2.7 |
11 new parameters added:
Parameter
2.6 |
Version |
Description |
2.8 |
Version |
Description |
3.4 |
Version |
Description |
3.2 |
Version |
Description |
3.5 |
Version |
Description |
3.4 |
3.3 |
3.2 |
Parameter |
3.1 |
2.6 |
Parameter
2.5 |
2.3 |
Version |
Description |
3.6 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.9 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.3 |
3.1 |
Parameter Parameter |
3.0 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.0 |
Parameter New environment setting added: |
2.9 |
Parameter |
2.8 |
2.7 |
Parameter
2.6 |
Default value for parameter |
2.5 |
Moved from the Segmentation and Classification toolset to the Deep Learning toolset. 4 new parameters added:
2.4 |
Two new parameters added:
Parameter |
2.3 |
Parameter
Parameter Parameter
2.2 |
2.1 |
Version |
Description |
3.3 |
Parameter |
3.1 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Version |
Description |
3.3 |
2.9 |
Parameter |
2.3 |
Version |
Description |
3.3 |
Version |
Description |
3.0 |
Parameter |
2.6 |
2.5 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.0 |
For the For the |
2.4 |
New option for the New parameter added: The |
2.3 |
Multi-core support added. Use the Parallel Processing Factor environment to control the number of cores used by the tool. New environment added: |
2.1 |
Version |
Description |
3.6 |
Version |
Description |
3.6 |
Version |
Description |
2.6 |
New parameter added: Parameter New environment added: |
2.5 |
New parameter added: Parameter removed: Parameter order changed at parameter 5:
Parameter
Parameter
2.4 |
Version |
Description |
3.6 |
Version |
Description |
3.6 |
3.5 |
Version |
Description |
2.1 |
Version |
Description |
2.7 |
2.6 |
5 new parameters added:
2.5 |
Generate Video Metadata (Stationary)
Version |
Description |
3.7 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
New parameter added: New environment added: |
2.1 |
Version |
Description |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.2 |
Parameter Tool moved from the Multidimensional toolset to the Interpolation toolset. |
3.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.6 |
2.5 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.0 |
Parameter |
2.9 |
Version |
Description |
3.3 |
Version |
Description |
3.2 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.6 |
2.5 |
New parameter added: This parameter has two options: unchecked ( |
2.3 |
2.1 |
Version |
Description |
3.6 |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.8 |
Version |
Description |
2.6 |
2.5 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
Version |
Description |
3.0 |
Version |
Description |
3.7 |
Image Analyst extension license requirement removed. |
3.6 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.6 |
2.6 |
Version |
Description |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.7 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.7 |
Parameter
3.6 |
Parameter |
3.5 |
3.4 |
Parameter Parameter
3.3 |
Parameter Parameter
3.2 |
Parameter
3.1 |
Parameter |
3.0 |
Parameter
2.9 |
Parameter
Parameter Parameter
2.8 |
Parameter
2.7 |
Parameter
. Parameter Parameter |
2.6 |
Parameter
2.5 |
Version |
Description |
2.1 |
Version |
Description |
2.9 |
Version |
Description |
2.6 |
2.1 |
Version |
Description |
2.6 |
New parameter added: Default value for parameter |
2.1 |
Version |
Description |
2.9 |
2.8 |
Version |
Description |
2.6 |
2.1 |
Version |
Description |
3.1 |
Translate Pixels Using Deep Learning
Version |
Description |
3.7 |
Version |
Description |
3.6 |
Version |
Description |
2.9 |
2.1 |
Version |
Description |
3.4 |
The |
3.3 |
2.3 |
Version |
Description |
3.4 |
3.3 |
Parameter |
3.0 |
Output file supports |
2.2 |
Version |
Description |
2.3 |
2.1 |
Version |
Description |
3.2 |
Parameter
3.0 |
2.7 |
2.6 |
New option for the New parameter added: |
2.5 |
2.3 |
2.2 |
There was a change in the default environment behavior when the zone input is a feature. The |
2.1 |
Version |
Description |
3.2 |
3.0 |
2.7 |
2.6 |
