List of ArcGIS Image Analyst geoprocessing tools
The ArcGIS Image Analyst extension provides a suite of geoprocessing tools in ArcGIS Pro.
Geoprocessing tools
A large number of geoprocessing tools are provided with the Image Analyst extension. These tools are grouped into categories of related functionality in the following tables and associated toolsets.
Change Detection
The Change Detection toolset contains tools that perform change detection between raster datasets.
Tool
Analyze Changes Using CCDC
Evaluates changes in pixel values over time using the Continuous Change Detection and Classification (CCDC) method and generates a change analysis raster containing the model results.
Analyze Changes Using LandTrendr
Evaluates changes in pixel values over time using the Landsat-based detection of trends in disturbance and recovery (LandTrendr) method and generates a change analysis raster containing the model results.
Compute Change Raster
Calculates the absolute, relative, categorical, or spectral difference between two raster datasets.
Detect Change Using Change Analysis Raster
Generates a raster containing pixel change information using the output change analysis raster from the Analyze Changes Using CCDC tool or the Analyze Changes Using LandTrendr tool.
Tools in the Change Detection toolset
Classification and Pattern Recognition
The tools in the Classification and Pattern Recognition toolset find, identify, and quantify patterns in imagery data. You can perform classic statistical and advanced machine learning image classification and regression analysis on segmented and pixel-based raster datasets. Additional tools are provided to perform training set and classification accuracy and refinement of class maps. The following table lists the Classification and Pattern Recognition tools and provides a brief description of each:
Tool
Classify Raster
Classifies a raster dataset based on an Esri classifier definition file (.ecd) and raster dataset inputs.
The .ecd file contains all the information needed to perform a specific type of Esri-supported classification. The inputs to this tool must match the inputs used to generate the required .ecd file.
Classify Raster Using Spectra
Classifies a multiband raster dataset using spectral matching techniques. The input spectral data can be provided as a point feature class or a .json file.
Compute Confusion Matrix
Computes a confusion matrix with errors of omission and commission and derives a kappa index of agreement, Intersection over Union (IoU), and an overall accuracy between the classified map and the reference data.
Compute Segment Attributes
Computes a set of attributes associated with the segmented image. The input raster can be a single-band or 3-band, 8-bit segmented image.
Create Accuracy Assessment Points
Creates randomly sampled points for postclassification accuracy assessment.
Generate Training Samples From Seed Points
Generates training samples from seed points, such as accuracy assessment points or training sample points. A typical use case is generating training samples from an existing source, such as a thematic raster or a feature class.
Inspect Training Samples
Estimates the accuracy of individual training samples. The cross validation accuracy is computed using the previously generated classification training result in an .ecd file and the training samples. Outputs include a raster dataset containing the misclassified class values and a training sample dataset with the accuracy score for each training sample.
Linear Spectral Unmixing
Performs subpixel classification and calculates the fractional abundance of different land-cover types for individual pixels.
Predict Using Regression Model
Predicts data values using the output from the Train Random Trees Regression Model tool.
Remove Raster Segment Tiling Artifacts
Corrects segments or objects cut by tile boundaries during the segmentation process performed as a raster function. This tool is helpful for some regional processes, such as image segmentation, that have inconsistencies near image tile boundaries.
This processing step is included in the Segment Mean Shift tool. It should only be used on a segmented image that was not created from that tool.
Segment Mean Shift
Groups adjacent pixels that have similar spectral characteristics into segments.
Train Iso Cluster Classifier
Generates an Esri classifier definition file (.ecd) using the Iso Cluster classification definition.
Train K-Nearest Neighbor Classifier
Generates an Esri classifier definition file (.ecd) using the K-Nearest Neighbor classification method.
Train Maximum Likelihood Classifier
Generates an Esri classifier definition file (.ecd) using the Maximum Likelihood Classifier (MLC) classification definition.
Train Random Trees Classifier
Generates an Esri classifier definition file (.ecd) using the Random Trees classification method.
Models the relationship between explanatory variables and a target dataset using random trees analysis.
Train Support Vector Machine Classifier
Generates an Esri classifier definition file (.ecd) using the Support Vector Machine (SVM) classification definition.
Update Accuracy Assessment Points
Updates the Target field in the attribute table to compare reference points to the classified image.
Tools of the Classification and Pattern Recognition toolset
Deep Learning
The tools in the Deep Learning toolset detect features in imagery using multiple layers of artificial neural networks in which each layer is capable of extracting one or more unique features in the image. The following table lists the Deep Learning tools and provides a brief description of each;
Tool
Classify Objects Using Deep Learning
Runs a trained deep learning model on an input raster and an optional feature class to produce a feature class or table in which each input object or feature has an assigned class or category label.
Classify Pixels Using Deep Learning
Runs a trained deep learning model on an input raster to produce a classified raster, with each valid pixel having an assigned class label.
Compute Accuracy For Object Detection
Calculates the accuracy of a deep learning model by comparing the detected objects from the Detect Objects Using Deep Learning tool to ground truth data.
Compute Accuracy For Pixel Classification
Computes a confusion matrix, based on errors of omission and commission, and the Intersection over Union (IoU) score. The accuracy is computed between the output from the Classify Pixels Using Deep Learning tool and the ground truth data.
Detect Change Using deep Learning
Runs a trained deep learning model to detect change between two rasters.
Detect Control Points
Detects ground control points in a mosaic dataset.
Runs a trained deep learning model on an input raster to produce a feature class containing the objects it finds. The features can be bounding boxes or polygons around the objects found or points at the centers of the objects.
Export Training Data For Deep Learning
Converts labeled vector or raster data to deep learning training datasets using a remote sensing image. The output is a folder of image chips and a folder of metadata files in the specified format.
Extract Features Using AI Models
Runs one or more pretrained deep learning models on an input raster to extract features and automate the postprocessing of the inferenced outputs.
Non Maximum Suppression
Identifies duplicate features from the output of the Detect Objects Using Deep Learning tool as a postprocessing step and creates an output with duplicates removed.
Train Deep Learning Model
Trains a deep learning model using the output from the Export Training Data For Deep Learning tool.
Train Using AutoDL
Trains a deep learning model by building training pipelines and automating much of the training process, including data augmentation, model selection, hyperparameter tuning, and batch size deduction.
Transform Image Shapes
Transforms features from image space to map space.
Translate Pixels Using Deep Learning
Runs a trained deep learning model to enhance pixels within an image.
Tools in the Deep Learning toolset
Extraction
The tool in the Extraction toolset extracts a subset of pixels from a raster by the pixels' attributes or their spatial location. The following table lists the Extraction tool and provides a brief description of it:
Tool
Sample
Creates a table or a point feature class that shows the values of cells from a raster, or a set of rasters, for defined locations. The locations are defined by raster cells, points, polylines, or polygons.
Tool in the Extraction toolset
Interpolation
The tools in the Interpolation toolset interpolate different types of data. The following table lists the Interpolation tools and provides a brief description of each:
Tool
Interpolate From Spatiotemporal Points
Interpolates temporal point data into a multidimensional raster.
Optimal Interpolation
Statistically assimilates data combined from multiple sources to produce an interpolated output raster.
Tools in the Interpolation toolset
Map Algebra
Map algebra is a way to perform raster analysis by creating expressions in an algebraic language. Expressions are created with the Raster Calculator tool, which allows you to build expressions that output a raster dataset. The Raster Calculator tool builds and runs a single map algebra expression using Python syntax.
For details about the Raster Calculator tool, refer to An overview of the Map Algebra toolset in Image Analyst.
Math
More than 60 Math tools are provided for performing mathematical operations on raster datasets. These tools are grouped into the following functional areas:
  • General
  • Conditional
  • Logical
    • Bitwise
    • Boolean
    • Combinatorial
    • Logical
    • Relational
  • Trigonometric
Math (general)
The tools in the general Math toolset apply a mathematical operation to the input. These tools fall into several categories. The arithmetic tools perform basic mathematical operations, such as addition and multiplication. There are tools that perform various types of exponentiation operations, which includes exponentials and logarithms in addition to the basic power operations. The remaining tools are used either for sign conversion or for conversion between integer and floating point data types. The following table lists the general Math tools and provides a brief description of each:
Tool
Abs
Calculates the absolute value of the cells in a raster.
Divide
Divides the values of two rasters on a cell-by-cell basis.
Exp
Calculates the base e exponential of the cells in a raster.
Exp10
Calculates the base 10 exponential of the cells in a raster.
Exp2
Calculates the base 2 exponential of the cells in a raster.
Float
Converts each cell value of a raster into a floating-point representation.
Int
Converts each cell value of a raster to an integer by truncation.
Ln
Calculates the natural logarithm (base e) of cells in a raster.
Log10
Calculates the base 10 logarithm of cells in a raster.
Log2
Calculates the base 2 logarithm of cells in a raster.
Minus
Subtracts the value of the second input raster from the value of the first input raster on a cell-by-cell basis.
Mod
Finds the remainder (modulo) of the first raster when divided by the second raster on a cell-by-cell basis.
Negate
Changes the sign (multiplies by -1) of the cell values of the input raster on a cell-by-cell basis.
Plus
Adds (sums) the values of two rasters on a cell-by-cell basis.
Power
Raises the cell values in a raster to the power of the values found in another raster.
Round Down
Returns the next lower integer value, just represented as a floating point, for each cell in a raster.
Round Up
Returns the next higher integer value, just represented as a floating point, for each cell in a raster.
Square
Calculates the square of the cell values in a raster.
Square Root
Calculates the square root of the cell values in a raster.
Times
Multiplies the values of two rasters on a cell-by-cell basis.
Tools in the general Math toolset
Math (Conditional)
The tools in the Conditional Math toolset control the output values based on the conditions placed on the input values. The conditions that can be applied are of two types: queries on the attributes or a condition based on the position of the conditional statement in a list. The following table lists the Conditional Math tools and provides a brief description of each:
Tool
Con
Performs a conditional if/else evaluation on each of the input cells of an input raster.
Pick
Uses the value from a position raster to determine the input raster that will be used for the output cell value.
Set Null
Sets identified cell locations to NoData based on a specified criteria. It returns NoData if a conditional evaluation is true, and returns the value specified by another raster if it is false.
Tools in the Conditional Math toolset
Math (Logical)
The tools in the Logical Math toolset evaluate the values of the inputs and determine the output values based on Boolean logic. These tools process raster datasets in five main categories: Bitwise, Boolean, Combinatorial, Relational, and Logical. The following tables list the Logical Math tools and provide a brief description of each:
Tool
Bitwise And
Performs a Bitwise And operation on the binary values of two input rasters.
Bitwise Left Shift
Performs a Bitwise Left Shift operation on the binary values of two input rasters.
Bitwise Not
Performs a Bitwise Not (complement) operation on the binary value of an input raster.
Bitwise Or
Performs a Bitwise Or operation on the binary values of two input rasters.
Bitwise Right Shift
Performs a Bitwise Right Shift operation on the binary values of two input rasters.
Bitwise XOr
Performs a Bitwise eXclusive Or operation on the binary values of two input rasters.
Bitwise tools in the Logical Math toolset
Tool
Boolean And
Performs a Boolean And operation on the cell values of two input rasters.
If both input values are true (non-zero), the output value is 1. If one or both inputs are false (zero), the output is 0.
Boolean Not
Performs a Boolean Not (complement) operation on the cell values of the input raster.
If the input values are true (non-zero), the output value is 0. If the input values are false (zero), the output is 1.
Boolean Or
Performs a Boolean Or operation on the cell values of two input rasters.
If one or both input values are true (non-zero), the output value is 1. If both input values are false (zero), the output is 0.
Boolean XOr
Performs a Boolean eXclusive Or operation on the cell values of two input rasters.
If one input value is true (non-zero) and the other false (zero), the output is 1. If both input values are true or both are false, the output is 0.
Boolean tools in the Logical Math toolset
Tool
Combinatorial And
Performs a Combinatorial And operation on the cell values of two input rasters.
If both input values are true (non-zero), the output is a different value for each unique combination of input values. If one or both inputs are false (zero), the output value is 0.
Combinatorial Or
Performs a Combinatorial Or operation on the cell values of two input rasters.
If either input value is true (non-zero), the output is a different value for each unique combination of input values. If both inputs are false (zero), the output value is 0.
Combinatorial XOr
Performs a Combinatorial eXclusive Or operation on the cell values of two input rasters.
If one input value is true (non-zero) and the other false (zero), the output is a different value for each unique combination of input values. If both inputs are true or both are false, the output value is 0.
Combinatorial tools in the Logical Math toolset
Tool
Equal To
Performs a Relational equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster equals the second raster and 0 for cells where it does not.
Greater Than
Performs a Relational greater-than operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is greater than the second raster and 0 for cells if it is not.
Greater Than Equal
Performs a Relational greater-than-or-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is greater than or equal to the second raster and 0 if it is not.
Less Than
Performs a Relational less-than operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is less than the second raster and 0 if it is not.
Less Than Equal
Performs a Relational less-than-or-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is less than or equal to the second raster and 0 where it is not.
Not Equal
Performs a Relational not-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is not equal to the second raster and 0 for cells where it is equal.
Relational tools in the Logical Math toolset
Tool
Diff
Determines which values from the first input are logically different from the values of the second input on a cell-by-cell basis.
If the values on the two inputs are different, the value on the first input is output. If the values on the two inputs are the same, the output is 0.
InList
Determines which values from the first input are contained in a set of other inputs, on a cell-by-cell basis.
For each cell, if the value of the first input raster is found in any of the list of other inputs, that value will be assigned to the output raster. If it is not found, the output cell will be NoData.
Is Null
Determines which values from the input raster are NoData on a cell-by-cell basis.
Returns a value of 1 if the input value is NoData and 0 for cells that are not.
Over
For the cell values in the first input that are not 0, the output value will be that of the first input. Where the cell values are 0, the output will be that of the second input raster.
Test
Performs a Boolean evaluation of the input raster using a logical expression.
When the expression evaluates to true, the output cell value is 1. If the expression is false, the output cell value is 0.
Logical tools in the Logical Math toolset
Math (Trigonometric)
The tools in the Trigonometric Math toolset perform various trigonometric calculations on the values in an input raster. The following table lists the Trigonometric Math tools and provides a brief description of each:
Tool
ACos
Calculates the inverse cosine of cells in a raster.
ACosH
Calculates the inverse hyperbolic cosine of cells in a raster.
ASin
Calculates the inverse sine of cells in a raster.
ASinH
Calculates the inverse hyperbolic sine of cells in a raster.
ATan
Calculates the inverse tangent of cells in a raster.
ATan2
Calculates the inverse hyperbolic tangent of cells in a raster.
ATanH
Cos
Calculates the cosine of cells in a raster.
CosH
Calculates the hyperbolic cosine of cells in a raster.
Sin
Calculates the sine of cells in a raster.
SinH
Calculates the hyperbolic sine of cells in a raster.
Tan
Calculates the tangent of cells in a raster.
TanH
Calculates the hyperbolic tangent of cells in a raster.
Tools in the Trigonometric Math toolset
Motion Imagery
The tools in the Motion Imagery toolset manage, process, and analyze motion imagery, including full motion video data. The following table lists the Motion Imagery tools and provides a brief description of each:
Tool
Convert Video Metadata
Prepares a video metadata file for further processing in geospatial video workflows by field matching and converting unit types.
Extract Frames To Images
Extracts video frame images and associated metadata from an FMV-compliant video stream and saves the data to a directory.
Generate Video Metadata (Stationary)
Creates a geospatially enabled video file from a pre-recorded video without metadata.
Video Metadata To Feature Class
Extracts the platform, frame center, frame outline, and attributes metadata from an FMV-compliant video and saves the feature data to a directory.
Video Multiplexer
Creates a video file that combines an archived video stream file and an associated metadata file synchronized by a time stamp.
Tools in the Motion Imagery toolset
Multidimensional Analysis
The tools in the Multidimensional Analysis toolset perform analysis on scientific data across multiple variables and dimensions. The following table lists the Multidimensional Analysis tools and provides a brief description of each:
Tool
Aggregate Multidimensional Raster
Generates a multidimensional raster dataset by combining existing multidimensional raster variables along a dimension.
Dimensional Moving Statistics
Calculates statistics over a moving window on multidimensional data along a specified dimension.
Find Argument Statistics
Extracts the dimension value or band index at which a given statistic is attained for each pixel in a multidimensional or multiband raster.
Generate Multidimensional Anomaly
Computes the anomaly for each slice in an existing multidimensional raster to generate a new multidimensional raster.
Generate Trend Raster
Estimates the trend for each pixel along a dimension for one or more variables in a multidimensional raster.
Multidimensional Principal Components
Reduces the number of components that can account for the variance of the whole multidimensional raster so that spatial and temporal patterns can be easily identified.
Multidimensional Raster Correlation
Analyzes correlations between two variables in one or two multidimensional rasters.
Predict Using Trend Raster
Computes a forecasted multidimensional raster using the output trend raster from the Generate Trend Raster tool.
Summarize Categorical Raster
Generates a table containing the pixel count for each class, in each slice of an input categorical raster.
Tools in the Multidimensional Analysis toolset
Overlay
The tool in the Overlay toolset performs various operations on multiple overlaid rasters. The following table lists the Overlay tool and provides a brief description of it.
Tool
Weighted Sum
Overlays several rasters, multiplying each by their given weight and summing them together.
Tool in the Overlay toolset
Spectral Analysis
The tools in the Spectral Analysis toolset contains tools for performing spectral analysis on multiband and hyperspectral imagery.
Tool
Detect Image Anomalies
Processes a multiband or hyperspectral image and creates an anomaly score raster. An anomaly score raster is a single band raster, with values between 0 and 1.
Detect Target Using Spectra
Identifies pixels in an image that match a spectral signature.
Extract Spectra from Image
Extracts spectral signatures from input feature data using imagery to create an Esri Spectral Library (.esl) file.
Reduce Spectral Bands
Reduces the number of spectral bands in multiband imagery using Minimum Noise Fraction and Principal Components Analysis analytical methods.
Tools in the Spectral Analysis toolset
Statistics
The tools in the Statistics toolset perform statistical raster operations on a local, neighborhood, or zonal basis. The following table lists the Statistics tools and provides a brief description of each:
Tool
Cell Statistics
Calculates a per-cell statistic from multiple rasters.
The available statistics are Majority, Maximum, Mean, Median, Minimum, Minority, Percentile, Range, Standard deviation, Sum, and Variety.
Extracts the dimension value (for example the date, height, or depth) at which a specific statistic is reached in the stack of rasters in a multidimensional raster dataset.
Focal Statistics
Calculates for each input cell location a statistic of the values within a specified neighborhood around it.
Zonal Statistics
Summarizes the values of a raster within the zones of another dataset.
Zonal Statistics as Table
Summarizes the values of a raster within the zones of another dataset and reports the results as a table.
Tools in the Statistics toolset
Synthetic Aperture Radar
The tools in the Synthetic Aperture Radar toolset correct, process, and enable analysis synthetic aperture radar (SAR) data. The following table lists the Synthetic Aperture Radar tools and provides a brief description of each:
Tool
Apply Complex Data Filter
Smooths the phase component of the complex input synthetic aperture radar (SAR) data and outputs complex radar data.
Apply Coregistration
Resamples the secondary single look complex (SLC) data to the reference SLC grid using a digital elevation model (DEM) and orbit state vector metadata.
Apply Geometric Terrain Correction
Orthorectifies the input synthetic aperture radar (SAR) data using a range-Doppler backgeocoding algorithm.
Apply Orbit Correction
Updates the orbital information in the Sentinel-1 synthetic aperture radar (SAR) data using a more accurate orbit state vector (OSV) file.
Apply Radiometric Calibration
Converts the input synthetic aperture radar (SAR) reflectivity into physical units of normalized backscatter by normalizing the reflectivity using a reference plane.
Apply Radiometric Terrain Flattening
Corrects the input synthetic aperture radar (SAR) data for radiometric distortions due to topography.
Compute Coherence
Computes the similarity between the reference and secondary input complex radar data.
Compute SAR Indices
Computes various synthetic aperture radar (SAR) indices for SAR data, such as Radar Vegetation Index (RVI), Radar Forest Degradation Index (RFDI), and Canopy Structure Index (CSI).
Convert SAR Units
Converts the scaling of the input synthetic aperture radar (SAR) data.
Create Color Composite
Creates a three-band raster dataset from a multiband raster dataset.
Deburst
Merges the multiple bursts from the input Sentinel-1 Single Look Complex (SLC) synthetic aperture radar (SAR) data and outputs a single, seamless subswath raster.
Despeckle
Corrects the input synthetic aperture radar (SAR) data for speckle, which is a result of coherent illumination that resembles a grainy or salt and pepper effect.
Detect Bright Ocean Objects
Detects potential bright human-made objects—such as ships, oil rigs, and windmills—while masking out the synthetic aperture radar (SAR) data outside the region of interest.
Detect Dark Ocean Areas
Identifies potential dark pixels belonging to oil spills or algae, and clusters these pixels, while masking out the synthetic aperture radar (SAR) data outside the region of interest.
Download Orbit File
Downloads the updated orbit files for Sentinel-1 synthetic aperture radar (SAR) data.
Extract Ocean Winds
Estimates wind direction and magnitude on the ocean surface.
Extract Water
Finds water bodies using input synthetic aperture radar (SAR) data and a digital elevation model (DEM).
Generate Interferogram
Creates an interferogram by differencing the phase of the reference and secondary single look complex (SLC) inputs.
Generate Masked SAR Raster
Generates an output synthetic aperture radar (SAR) dataset that preserves radar measurements for the entire original input extent, while masking out a specified region of interest.
Generate Multitemporal Coherence
Generates a false color composite image using ground range detected and the coherence products. Each band in the composite is composed of different synthetic aperture radar (SAR) acquisitions, which are derived from complex radar products.
Multilook
Averages the input synthetic aperture radar (SAR) data by looks in range and azimuth to approximate square pixels, mitigates speckle, and reduces SAR tool processing time.
Remove Thermal Noise
Corrects backscatter disturbances caused by thermal noise in the input synthetic aperture radar (SAR) data, resulting in a more seamless image.
Unwrap Phase
Removes the phase ambiguities and solves for continuous phase values for single look complex (SLC) data.
Tools in the Synthetic Aperture Radar toolset
Utilities
The tool in the Utilities toolset performs preprocessing and postprocessing on imagery and derived products. The following table lists the Utilities tool and provides a brief description of it:
Tool
Create Binary Mask
The Utilities toolset contains tools for preprocessing and postprocessing imagery and derived products.
Tool in the Utilities toolset
