Spatial Analyst toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Abs
Version
3.6
An input raster with rectangular cells will be processed so that the output raster cells will be square with sides equal to the average of the rectangular length and width.
2.3
New environment added: cellSizeProjectionMethod
1.0
Ported from ArcMap 10.3
ACos
Version
2.3
1.0
ACosH
Version
2.3
1.0
Add Surface Information
Version
3.1
Parameter in_surface has new data type: Image Service
2.7
Existing 3D Analyst tool now available to Spatial Analyst at this release
Adjust Raster to Stream
Version
3.7
New at this version
Adjust Stream to Raster
Version
3.6
New at this version
Aggregate
Version
2.5
Multi-core support added. Use the Parallel Processing Factor environment to control the number of cores used by the tool.
The median option of the aggregation_type parameter will now always produce an output raster of type float.
2.3
1.0
Aggregate Multidimensional Raster
Version
2.8
3 new parameters added:
  • percentile_interpolation_type
  • dimensionless
  • percentile_value
Parameter aggregation_method had new option added: PERCENTILE
2.6
New environment added: pyramid
2.5
Parameter in_multidimensional_raster has 3 new data types:
  • Mosaic Dataset
  • Image Service
  • Raster Dataset
Parameter interval_keyword has 6 new options:
  • RECURRING_MONTHLY
  • PENTADLY
  • DEKADLY
  • RECURRING_WEEKLY
  • RECURRING_QUARTERLY
  • RECURRING_DAILY
2.4
New at this version
Area Solar Radiation
Version
2.3
1.0
ASin
Version
2.3
1.0
ASinH
Version
2.3
1.0
Aspect
Version
3.7
Parameter z_unit has new option added: FOOT_US
3.6
New environments added:
  • gpuID
  • processor_type
3.1
New parameter added: analysis_target_device
2.6
New parameter added: project_geodesic_azimuths.
2.3
2.0
Two new parameters added:
  • method
  • z_unit
The method parameter allows you choose between the traditional planar method for performing the calculations, and the new geodesic method.
When using the geodesic option:
  • A new z_unit parameter is available, which allows you to specify the linear unit of the vertical z-values if it is not already defined in the coordinate system of the input.
  • If a suitable GPU device is available on your system, greater performance will come as a result of the calculations being GPU accelerated.
The behavior for how NoData cells and boundary cells are handled was changed. At least seven of the eight cells neighboring the processing cell must have a value, otherwise the output will be NoData. Cells in the outermost rows and columns of the output raster will be NoData.
1.0
ATan
Version
2.3
1.0
ATan2
Version
2.3
1.0
ATanH
Version
2.3
1.0
Band Collection Statistics
Version
3.6
4 new parameters added:
  • out_histogram
  • number_bins
  • compute_histogram
  • out_histogram_table
1.0
Basin
Version
3.7
2.3
1.0
Bitwise And
Version
2.3
1.0
Bitwise Left Shift
Version
2.3
1.0
Bitwise Not
Version
2.3
1.0
Bitwise Or
Version
2.3
1.0
Bitwise Right Shift
Version
2.3
1.0
Bitwise XOr
Version
2.3
1.0
Block Statistics
Version
3.0
When the neighborhood type is NbrWeight, the algorithms for the MEAN and STD statistics were improved. The MEDIAN and MINORITY options for the statistics_type parameter are no longer supported.
For the MAJORITY and MINORITY statistics, when there is a tie, the lowest value is now returned.
2.3
1.0
Boolean And
Version
2.3
1.0
Boolean Not
Version
2.3
1.0
Boolean Or
Version
2.3
1.0
Boolean XOr
Version
2.3
1.0
Boundary Clean
Version
2.7
2.3
1.0
Calculate Kernel Density Ratio
Version
3.0
New at this version
Cell Statistics
Version
3.6
2.9
  • percentile_value
Parameter statistics_type had new option added: PERCENTILE
2.5
New parameter added: process_as_multiband
This parameter has two options: SINGLE_BAND for processing as single band and MULTI_BAND for processing as multiband. The default is SINGLE_BAND.
2.3
1.0
Class Probability
Version
2.3
1.0
Classify Raster
Version
2.6
Parameter in_raster has two new data types:
  • Mosaic Dataset
  • Raster Dataset
Parameter in_additional_raster has two new data types:
  • Mosaic Dataset
  • Raster Dataset
2.2
  • Image Service
  • String
  • Image Service
  • String
1.0
New at this version
Combinatorial And
Version
2.3
1.0
Combinatorial Or
Version
2.3
1.0
Combinatorial XOr
Version
2.3
1.0
Combine
Version
2.3
1.0
Compute Confusion Matrix
Version
1.1
New at this version
Compute Segment Attributes
Version
2.2
1.0
Con
Version
3.6
2.3
1.0
Contour
Version
3.6
2.4
2.3
2.2
  • contour_type
  • max_vertices_per_feature
1.0
Contour List
Version
3.7
New parameter added: contour_type
2.4
2.3
1.0
Contour with Barriers
Version
1.0
Corridor
Version
2.3
1.0
Cos
Version
2.3
1.0
CosH
Version
2.3
1.0
Cost Allocation
Version
2.3
2.2
There was a change in default environment behavior in which the processing extent and spatial reference now default to that of the in_cost_raster.
1.3
New parameter added: source_direction
1.2
Four new parameters added:
  • source_cost_multiplier
  • source_start_cost
  • source_resistance_rate
  • source_capacity
1.0
Cost Back Link
Version
2.3
2.2
1.3
1.2
  • source_start_cost
  • source_capacity
1.0
Cost Connectivity
Version
2.3
2.2
1.2
New at this version
Cost Distance
Version
2.3
2.2
1.3
1.2
  • source_start_cost
  • source_capacity
1.0
Cost Path
Version
2.5
New parameter added: force_flow_direction_convention
1.0
Cost Path As Polyline
Version
2.5
2.1
New at this version
Create Accuracy Assessment Points
Version
3.5
New parameter added: min_point_distance
2.9
New parameter added: polygon_dimension_field
1.1
New at this version
Create Constant Raster
Version
2.8
Parameter extent has new data type: Envelope
2.3
1.0
Create Normal Raster
Version
2.8
2.3
1.0
Create Random Raster
Version
2.8
2.3
1.0
Create Signatures
Version
2.3
1.0
Curvature
Version
2.3
1.0
Cut Fill
Version
2.3
1.0
Darcy Flow
Version
2.3
1.0
Darcy Velocity
Version
2.3
1.0
Deep Learning Model To Ecd
Version
2.3
Deprecated
This is a deprecated tool. This functionality has been replaced by the Export Training Data For Deep Learning tool that creates classification information for use in the deep learning model.
2.1
New at this version
Dendrogram
Version
1.0
Derive Continuous Flow
Version
3.6
3.0
New at this version
Derive Stream As Line
Version
3.0
New at this version
Derive Stream As Raster
Version
3.0
New at this version
Diff
Version
2.3
1.0
Dimensional Moving Statistics
Version
2.9
New at this version
Distance Accumulation
Version
3.4
For the in_cost_raster parameter, while values that are negative or zero are considered invalid, they will now be treated as small positive cost values.
3.3
Parameter vertical_factor has two new options:
  • VFHikingTime
  • VFBidirHikingTime
2.5
New at this version
Distance Allocation
Version
3.4
3.3
  • VFHikingTime
  • VFBidirHikingTime
2.5
New at this version
Divide
Version
2.3
1.0
Edit Signatures
Version
2.3
1.0
Equal To
Version
2.3
1.0
Equal To Frequency
Version
2.6
New parameter added: process_as_multiband.
2.3
1.0
Euclidean Allocation
Version
2.4
  • in_barrier_data
  • out_back_direction_raster
2.3
Multi-core support disabled. The parallelProcessingFactor environment no longer applies to this tool.
2.2
New parameter added: distance_method
This parameter has two options: the traditional planar method for performing the calculations and a new geodesic method. The default is planar.
1.0
Euclidean Back Direction
Version
2.4
New at this version
Euclidean Direction
Version
2.4
  • in_barrier_data
2.3
2.2
1.0
Euclidean Distance
Version
2.4
  • in_barrier_data
2.3
2.2
1.0
Exp
Version
2.3
1.0
Exp10
Version
2.3
1.0
Exp2
Version
2.3
1.0
Expand
Version
2.4
New parameter added: expand_method. The MORPHOLOGICAL option for this parameter generates the same results as with previous releases, and is the default. With the DISTANCE method, a different algorithm is used that is distance-based, and will yield smoother results with larger settings for the number_of_cells parameter.
Multi-core support is added, but only when the DISTANCE option is selected. Use the parallelProcessingFactor environment to control the number of cores used by the tool.
2.3
1.0
Version
3.0
Three new parameters added:
  • in_instance_data
  • instance_class_value_field
  • min_polygon_overlap_ratio
Parameter metadata_format had new option added: Panoptic_Segmentation
New environment added: parallelProcessingFactor.
2.9
Parameter metadata_format had new option added: Imagenet
2.8
New parameter added: in_raster2
Parameter metadata_format had new option added: CycleGAN
2.7
Parameter metadata_format had two options added:
  • MultiLabeled_Tiles
  • Export_Tiles
2.6
Default value for parameter metadata_format changed from KTTI_rectangles to PASCAL_VOC_rectangles.
Parameter reference_system had IMAGE_SPACE option removed
2.5
  • blacken_around_feature
  • crop_mode
  • reference_system
  • processing_mode
2.4
  • in_mask_polygons
  • rotation_angle
Parameter metadata_format had new option added: Labeled_Tiles
Parameter in_raster has new data type: Folder
2.3
  • buffer_radius
  • class_value_field
Parameter in_raster has four new data types:
  • Internet Tiled Layer
  • Map Server Layer
  • Raster Dataset
  • MapServer
Parameter metadata_format had new option added: RCNN_Masks
Parameter in_class_data has two new data types:
  • Feature Class
  • Raster Dataset
2.2
New parameter added: start_index
2.1
New at this version
Extract by Attributes
Version
2.3
1.0
Extract by Circle
Version
2.3
1.0
Extract by Mask
Version
3.6
3.0
  • extraction_area
  • analysis_extent
2.3
2.2
There were some changes in the default environment behavior, as follows:
  • The tool will now use the in_raster as the default snap raster. This will improve the accuracy of the output by ensuring the correct alignment of the feature mask with the value raster.
  • If the Mask input is a feature, the in_raster will be used for setting the cell size and the snap raster for the analysis environment.
  • If the Mask input is a raster, the tool will compare the cell size of it to that of the in_raster, and use the one with the largest value as the cell size of the operation.
1.0
Extract by Points
Version
2.3
1.0
Extract by Polygon
Version
2.3
1.0
Extract by Rectangle
Version
2.3
1.0
Extract Multi Values to Points
Version
1.2
Better handling of conditions when NoData cells are sampled.
Some performance optimizations for faster execution with larger point datasets.
1.0
Extract Values to Points
Version
1.2
1.0
Feature Preserving Smoothing
Version
3.7
3.6
  • gpuID
  • processor_type
3.4
New at this version
Feature Solar Radiation
Version
3.6
  • gpuID
  • processor_type
3.3
New parameter added: sunmap_grid_level
3.2
New at this version
Fill
Version
2.3
2.2
1.0
Filter
Version
2.3
1.0
Float
Version
2.3
1.0
Flow Accumulation
Version
2.3
2.2
New parameter added: flow_direction_type
This parameter allows you to specify the type of input flow direction raster (D8, MFD, or DINF).
2.1
Added new DOUBLE option to data_type parameter choices.
1.0
Flow Direction
Version
3.7
New parameter added: method
3.6
2.3
2.2
2.1
New parameter added: flow_direction_type.
This parameter allows you to specifies the type of flow method to use while computing flow directions. The available options are D8, MFD, or DINF.
1.0
Flow Distance
Version
2.3
New parameter added: statistics_type
2.2
2.1
New at this version
Flow Length
Version
2.3
1.0
Focal Flow
Version
2.3
1.0
Focal Statistics
Version
3.0
For the NbrWeight neighborhood type, the algorithms for the MEAN and STD statistics were improved.
For the MAJORITY and MINORITY statistics, when there is a tie, the lowest value is returned, unless the processing cell is one of the ties. In that case, the output will be the processing cell value.
2.4
New option for the statistics_type parameter: PERCENTILE
New parameter added: percentile_value. This parameter is only supported when the statistics type is set to percentile.
The median option of statistics_type now supports float rasters as input. The output from median is now always Float.
2.3
1.0
Fuzzy Membership
Version
2.3
1.0
Fuzzy Overlay
Version
2.3
1.0
Generate Multidimensional Anomaly
Version
2.6
New parameter added: reference_mean_raster
Parameter calculation_interval has new option added: EXTERNAL_RASTER
2.5
New parameter added: calculation_interval
Parameter removed: temporal_interval
Parameter order changed at parameter five:
  • Old parameter: temporal_interval
  • New parameter: calculation_interval
  • Mosaic Dataset
  • Image Service
  • Raster Dataset
Parameter method has four new options:
  • PERCENT_OF_MEDIAN
  • DIFFERENCE_FROM_MEDIAN
  • Z_SCORE
  • PERCENT_DIFFERENCE_FROM_MEDIAN
2.4
New at this version
Generate Training Samples From Seed Points
Version
2.0
New at this version
Generate Breach Lines
Version
3.7
New at this version
Generate Weighted Voronoi
Version
3.7
New at this version
Geodesic Flow Direction
Version
3.7
New at this version
Geodesic Viewshed
Version
3.6
  • gpuID
  • processor_type
3.1
2.8
Tool label changed from Viewshed 2 to Geodesic Viewshed.
2.3
1.1
New parameter added: analysis_method.
This parameter allows you choose the method by which the visibility will be calculated. The option allows you to trade some accuracy for increased performance.
1.0
Geomorphon Landforms
Version
3.7
3.1
New at this version
Greater Than
Version
2.3
1.0
Greater Than Equal
Version
2.3
1.0
Greater Than Frequency
Version
2.6
2.3
1.0
Highest Position
Version
2.3
1.0
Hillshade
Version
2.3
1.0
IDW
Version
2.3
1.0
InList
Version
2.3
1.0
Inspect Training Samples
Version
2.2
2.0
New at this version
Interpolate Shape
Version
3.7
New parameter added: interpolate_m_value
2.7
Int
Version
2.3
1.0
Is Null
Version
2.3
1.0
Iso Cluster
Version
2.3
1.0
Iso Cluster Unsupervised Classification
Version
2.3
1.0
Kernel Density
Version
2.6
New parameter added: in_barriers.
2.3
1.0
Kriging
Version
2.3
1.0
Least Cost Corridor
Version
3.1
New at this version
Less Than
Version
2.3
1.0
Less Than Equal
Version
2.3
1.0
Less Than Frequency
Version
2.6
2.3
1.0
Line Density
Version
2.3
1.0
Line Statistics
Version
2.3
1.0
Linear Spectral Unmixing
Version
3.6
New parameter added: remove_continuum
The in_spectral_profile_file parameter supports two additional file formats, an Esri spectral library file (.esl), and an ENVI spectral library file (.sli).
2.5
New at this version
Ln
Version
2.3
1.0
Locate Depressions
Version
3.7
3.6
New at this version
Locate Regions
Version
3.2
In the output raster, cells that do not belong to any regions will now be assigned to NoData, instead of 0 as was done previously.
2.3
1.2
New at this version
Log10
Version
2.3
1.0
Log2
Version
2.3
1.0
Lookup
Version
2.3
1.0
Lowest Position
Version
2.3
1.0
Maximum Likelihood Classification
Version
2.3
1.0
Majority Filter
Version
2.3
1.0
Minus
Version
2.3
1.0
Mod
Version
2.3
1.0
Multicriteria Overlay
Version
3.7
New at this version
Multiscale Surface Deviation
Version
3.6
  • gpuID
  • processor_type
3.5
New at this version
Multiscale Surface Difference
Version
3.6
  • gpuID
  • processor_type
3.4
New at this version
Multiscale Surface Percentile
Version
3.6
  • gpuID
  • processor_type
3.4
New at this version
Natural Neighbor
Version
2.3
1.0
Negate
Version
2.3
1.0
Nibble
Version
2.3
2.2
2.1
  • nibble_nodata
  • in_zone_raster
1.0
Not Equal
Version
2.3
1.0
Observer Points
Version
2.3
1.0
Optimal Corridor Connections
Version
3.4
3.2
New at this version
Optimal Path As Line
Version
2.7
New parameter added: create_network_paths
2.5
New at this version
Optimal Path As Raster
Version
2.5
New at this version
Optimal Region Connections
Version
3.4
For the inputCostRaster parameter, while values that are negative or zero are considered invalid, they will now be treated as small positive cost values.
3.3
2.6
New parameter added: connections_within_regions
2.5
New at this version
Over
Version
2.3
1.0
Particle Track
Version
1.0
Path Distance
Version
2.3
2.2
1.3
1.2
  • source_start_cost
  • source_capacity
1.0
Path Distance Allocation
Version
2.3
2.2
1.3
1.2
  • source_start_cost
  • source_capacity
1.0
Path Distance Back Link
Version
2.3
2.2
1.3
1.2
  • source_start_cost
  • source_capacity
1.0
Pick
Version
3.6
2.5
This parameter has two options: unchecked (SINGLE_BAND in Python) for processing as single band and checked (MULTI_BAND in Python) for processing as multiband. The default is SINGLE_BAND processing.
2.3
1.0
Plus
Version
3.6
2.3
1.0
Point Density
Version
2.3
1.0
Point Statistics
Version
2.3
1.0
Points Solar Radiation
Version
2.3
1.0
Popularity
Version
2.6
2.3
1.0
Porous Puff
Version
2.3
1.0
Power
Version
2.3
1.0
Principal Components
Version
2.3
1.0
Rank
Version
2.6
2.3
1.0
Raster Calculator
Version
2.3
1.0
Raster Solar Radiation
Version
3.6
  • gpuID
  • processor_type
3.3
3.2
New at this version
Raster to Weighted Points
Version
3.7
New at this version
Reclass by ASCII File
Version
2.3
1.0
Reclass by Table
Version
2.3
1.0
Reclassify
Version
3.6
2.3
1.0
Region Group
Version
2.3
1.0
Remove Raster Segment Tiling Artifacts
Version
2.2
1.4
Parameter in_segmented_raster has four new data types:
  • Raster Dataset
  • Mosaic Dataset
  • String
  • Image Service
1.2
New at this version
Rescale by Function
Version
2.3
1.0
Round Down
Version
2.3
1.0
Round Up
Version
2.3
1.0
Sample
Version
2.6
New parameter added: generate_feature_class.
2.5
5 new parameters added:
  • acquisition_definition
  • statistics_type
  • percentile_value
  • buffer_distance
  • layout
New environment added: parallelProcessingFactor. This environment is honored only when the process_as_multidimensional parameter is set to ALL_SLICES.
1.2
1.0
Segment Mean Shift
Version
2.6
New parameter added: max_segment_size
2.2
1.0
Set Null
Version
2.3
1.0
Shrink
Version
2.4
New parameter added: shrink_method. The MORPHOLOGICAL option for this parameter generates the same results as with previous releases, and is the default. With the DISTANCE method, a different algorithm is used that is distance-based, and will yield smoother results with larger settings for the number_of_cells parameter.
2.3
1.0
Sin
Version
2.3
1.0
SinH
Version
2.3
1.0
Sink
Version
3.7
2.3
2.2
1.0
Slice
Version
3.6
2.9
  • nodata_to_value
  • class_interval_size
Parameter slice_type has four new options:
  • STANDARD_DEVIATION_MEAN_CENTERED
  • GEOMETRIC_INTERVAL
  • DEFINED_INTERVAL
  • STANDARD_DEVIATION_MEAN_BREAK
Parameter number_zones changed from Required to Optional
2.3
1.0
Slope
Version
3.7
3.6
  • gpuID
  • processor_type
3.1
2.3
2.0
  • method
  • z_unit
1.0
Snap Pour Point
Version
2.3
1.0
Solar Radiation Graphics
Version
2.3
1.0
Space Time Kernel Density
Version
3.7
Parameter elevation_field_unit has new option added: FOOT_US
Parameter elevation_unit has new option added: FOOT_US
3.4
New parameter added: out_voxel_layer
3.2
New at this version
Spline
Version
2.3
1.0
Spline with Barriers
Version
2.0
Ported from ArcMap 10.5
Square
Version
2.3
1.0
Square Root
Version
2.3
1.0
Storage Capacity
Version
3.7
2.7
New at this version
Stream Link
Version
2.3
2.2
1.0
Stream Order
Version
2.3
1.0
Stream to Feature
Version
1.0
Surface Area Ratio
Version
3.7
New at this version
Surface Parameters
Version
3.7
3.6
3.1
New parameter added: in_analysis_mask
2.9
Parameter parameter_type had four new options:
  • CONTOUR_CURVATURE
  • CONTOUR_GEODESIC_TORSION
  • GAUSSIAN_CURVATURE
  • CASORATI_CURVATURE
2.7
New at this version
Tabulate Area
Version
2.6
New parameter added: classes_as_rows.
2.3
2.2
There was a change in default environment behavior for this tool.
  • If both the inputs are raster, the cell size of the operation will be the larger of the two.
  • If one input is a raster and the other a feature, the raster input will be used for setting the cell size and the snap raster for the analysis environment.
1.0
Tan
Version
2.3
1.0
TanH
Version
2.3
1.0
Test
Version
2.3
1.0
Thin
Version
2.3
1.0
Times
Version
2.3
1.0
Top Hat Transform
Version
3.7
New at this version
Topo to Raster
Version
2.3
1.0
Topo to Raster by File
Version
1.0
Topographic Position Index
Version
3.6
New at this version
Train ISO Cluster Classifier
Version
2.2
1.4
Environments added:
  • Remote Processing Server
  • Remote Processing User Name
  • Remote Processing Password
The in_raster parameter has two new data types:
  • Image Service
  • String
The in_additional_raster parameter has two new data types:
  • Image Service
  • String
1.2
  • max_merge_per_iter—Max Number of Cluster Merges Per Iteration
  • max_merge_distance
1.0
Train K-Nearest Neighbor Classifier
Version
2.9
New at this version
Train Maximum Likelihood Classifier
Version
2.6
New parameter added: dimension_value_field
1.4
  • Image Service
  • String
  • Image Service
  • String
1.0
Train Random Trees Classifier
Version
2.6
1.4
  • Image Service
  • String
  • Image Service
  • String
1.2
New at this version
Train Support Vector Machine Classifier
Version
2.6
Default value for parameter max_samples_per_class changed from 500 to 1000
2.2
1.4
  • Image Service
  • String
  • Image Service
  • String
1.3
Default value for parameter max_samples_per_class changed from 100 to 500
1.0
Trend
Version
2.3
1.0
Update Accuracy Assessment Points
Version
2.9
  • polygon_dimension_field
  • point_dimension_field
1.1
New at this version
Validate Flow Direction
Version
3.7
New at this version
Value Percentile Contours
Version
3.7
New parameter added: smooth_outputs
3.6
New at this version
Viewshed
Version
2.3
1.0
Visibility
Version
2.3
1.0
Volume Percentile Contours
Version
3.7
3.6
New at this version
Watershed
Version
2.3
2.2
1.0
Weighted Overlay
Version
2.3
1.0
Weighted Sum
Version
2.3
1.0
Zonal Characterization
Version
3.4
New at this version
Zonal Fill
Version
2.3
1.0
Zonal Geometry
Version
2.3
1.0
Zonal Geometry as Table
Version
2.3
1.0
Zonal Histogram
Version
2.6
New parameter added: zones_as_rows.
2.3
2.2
There was a change in the default environment behavior when the zone input is a feature. The in_value_raster is now used as the snap raster.
1.0
Zonal Statistics
Version
3.2
Parameter statistics_type has 4 new options:
  • MAJORITY_COUNT
  • MINORITY_COUNT
  • MAJORITY_PERCENT
  • MINORITY_PERCENT
3.0
  • circular_calculation
  • circular_wrap_value
2.7
New parameter added: percentile_interpolation_type
2.6
2.5
New parameter added: process_as_multidimensional
This parameter has two options: SINGLE_SLICE (Unchecked) for processing a single slice and ALL_SLICES (Checked) for processing multiple slices. The default is SINGLE_SLICE.
2.3
2.2
1.0
Zonal Statistics as Table
Version
3.2
New parameter added: out_join_layer
Parameter statistics_type has 6 new options:
  • MINORITY_VALUE_COUNT_PERCENT
  • MINORITY_PERCENT
  • MAJORITY_PERCENT
  • MAJORITY_COUNT
  • MAJORITY_VALUE_COUNT_PERCENT
  • MINORITY_COUNT
3.0
2.7
2.6
New parameter added: percentile_values.
2.5
2.3
2.2
1.0
