Data Management toolbox licensing
Toolset/Tool
Basic
Standard
Advanced
3D Objects toolset
Add 3D Formats To Multipatch
Not included
Included
Included
Export 3D Objects
Not included
Included
Included
Import 3D Objects
Not included
Included
Included
Remove 3D Formats From Multipatch
Not included
Included
Included
Archiving toolset
Disable Archiving
Not included
Included
Included
Enable Archiving
Not included
Included
Included
Trim Archive History
Not included
Included
Included
Attachments toolset
Add Attachments
Included
Included
Included
Disable Attachments
Included
Included
Included
Downgrade Attachments
Included
Included
Included
Enable Attachments
Included
Included
Included
Export Attachments
Included
Included
Included
Generate Attachment Match Table
Included
Included
Included
Remove Attachments
Included
Included
Included
Upgrade Attachments
Included
Included
Included
Attribute Rules toolset
Add Attribute Rule
Not included
Included
Included
Alter Attribute Rule
Not included
Included
Included
Delete Attribute Rule
Not included
Included
Included
Disable Attribute Rules
Not included
Included
Included
Enable Attribute Rules
Not included
Included
Included
Evaluate Rules
Supported for branch versioning when using ArcGIS Enterprise named user licensing with a member that has the ArcGIS Advanced Editing user type extension.
Limited
Included
Included
Export Attribute Rules
Not included
Included
Included
Import Attribute Rules
Not included
Included
Included
Reorder Attribute Rule
Not included
Included
Included
Attribute Rules/Templates toolset
Calculate Geometry Fields Attribute Rule
Not included
Included
Included
Generate ID Attribute Rule
Not included
Included
Included
Generate Spatial Join Attribute Rule
Not included
Included
Included
Generate Symbol Rotation Attribute Rule
Not included
Included
Included
Generate Update Related Attribute Rule
Not included
Included
Included
Catalog Dataset toolset
Add Items To Catalog Dataset
Included
Included
Included
Add Portal Items To Catalog Dataset
Included
Included
Included
Create Catalog Dataset
Included
Included
Included
Contingent Values toolset
Add Contingent Value
Included
Included
Included
Alter Field Group
Included
Included
Included
Create Field Group
Included
Included
Included
Delete Field Group
Included
Included
Included
Export Contingent Values
Included
Included
Included
Generate Contingent Values
Included
Included
Included
Import Contingent Values
Included
Included
Included
Remove Contingent Value
Included
Included
Included
Data Comparison toolset
Detect Feature Changes
Not included
Not included
Included
Feature Compare
Included
Included
Included
File Compare
Included
Included
Included
Raster Compare
Included
Included
Included
Table Compare
Included
Included
Included
TIN Compare
Included
Included
Included
Data Loading toolset
Create Data Loading Workspace
Included
Included
Included
Generate Mapping Table
Included
Included
Included
Load Data To Preview
Included
Included
Included
Load Data Using Workspace
Included
Included
Included
Update Data Loading Workspace Schema
Included
Included
Included
Distributed Geodatabase toolset
Compare Replica Schema
Not included
Included
Included
Create Replica
Not included
Included
Included
Create Replica From Server
Not included
Included
Included
Disable Replica Tracking
Not included
Included
Included
Enable Replica Tracking
Not included
Included
Included
Export Acknowledgement Message
Not included
Included
Included
Export Data Change Message
Not included
Included
Included
Export Replica Schema
Not included
Included
Included
Import Message
Not included
Included
Included
Import Replica Schema
Not included
Included
Included
Re-export Unacknowledged Messages
Not included
Included
Included
Synchronize Changes
Not included
Included
Included
Unregister Replica
Not included
Included
Included
Domains toolset
Add Coded Value To Domain
Included
Included
Included
Alter Coded Value Description
Included
Included
Included
Alter Domain
Included
Included
Included
Assign Domain To Field
Included
Included
Included
Create Domain
Included
Included
Included
Delete Coded Value From Domain
Included
Included
Included
Delete Domain
Included
Included
Included
Domain To Table
Included
Included
Included
Remove Domain From Field
Included
Included
Included
Set Value For Range Domain
Included
Included
Included
Sort Coded Value Domain
Included
Included
Included
Table To Domain
Included
Included
Included
Feature Binning toolset
Disable Feature Binning
Included
Included
Included
Enable Feature Binning
Included
Included
Included
Manage Feature Bin Cache
Included
Included
Included
Feature Class toolset
Append Annotation Feature Classes
Included
Included
Included
Create Feature Class
Included
Included
Included
Create Unregistered Feature Class
Included
Included
Included
Integrate
Included
Included
Included
Recalculate Feature Class Extent
Not included
Included
Included
Set Feature Class Split Model
Included
Included
Included
Features toolset
Add XY Coordinates
Included
Included
Included
Adjust 3D Z
Included
Included
Included
Bearing Distance To Line
Included
Included
Included
Calculate Geometry Attributes
Included
Included
Included
Check Geometry
Some parameters are limited by license level.
Limited
Included
Included
Copy Features
Included
Included
Included
Delete Features
Included
Included
Included
Dice
Not included
Not included
Included
Feature Envelope To Polygon
Not included
Not included
Included
Feature To Line
Not included
Included
Included
Feature To Point
Included
Included
Included
Feature To Polygon
Limited
Included
Included
Feature Vertices To Points
Not included
Not included
Included
Geodetic Densify
Not included
Included
Included
Minimum Bounding Geometry
Included
Included
Included
Multipart To Singlepart
Included
Included
Included
Points To Line
Included
Included
Included
Polygon To Line
Not included
Not included
Included
Repair Geometry
Limited
Included
Included
Split Line at Point
Not included
Not included
Included
Split Line At Vertices
Not included
Not included
Included
Subdivide Polygon
Included
Included
Included
Table To Ellipse
Included
Included
Included
Unsplit Line
Not included
Not included
Included
XY Table To Point
Included
Included
Included
XY To Line
Included
Included
Included
Fields toolset
Add Field
Included
Included
Included
Add Fields (multiple)
Included
Included
Included
Alter Field
Included
Included
Included
Alter Fields (multiple)
Included
Included
Included
Alter Geometry Index Preference
Included
Included
Included
Assign Default To Field
Included
Included
Included
Batch Update Fields
Included
Included
Included
Calculate Field
Included
Included
Included
Calculate Fields (multiple)
Included
Included
Included
Delete Field
Included
Included
Included
Migrate Text Field
Not included
Included
Included
Fields/COGO toolset
Disable COGO
Not included
Included
Included
Enable COGO
Not included
Included
Included
Fields/Data Engineering toolset
Encode Field
Included
Included
Included
Field Statistics To Table
Included
Included
Included
Reclassify Field
Included
Included
Included
Standardize Field
Included
Included
Included
Transform Field
Included
Included
Included
Fields/Database toolset
Add Global IDs
Included
Included
Included
Add Incrementing ID Field
Not included
Included
Included
Disable Editor Tracking
Included
Included
Included
Enable Editor Tracking
Included
Included
Included
Fields/Date and Time toolset
Calculate End Time
Included
Included
Included
Convert Temporal Field
Included
Included
Included
Convert Time Zone
Included
Included
Included
Migrate Date Field To High Precision
Not included
Included
Included
Fields/GPS toolset
Add GPS Metadata Fields
Included
Included
Included
File Geodatabase toolset
Compact
Included
Included
Included
Compress File Geodatabase Data
Included
Included
Included
Generate File Geodatabase License
Not included
Included
Included
Generate Licensed File Geodatabase
Not included
Included
Included
Recover File Geodatabase
Included
Included
Included
Uncompress File Geodatabase Data
Included
Included
Included
General toolset
Append
Included
Included
Included
Copy
Included
Included
Included
Create AI Service Connection File
Included
Included
Included
Create Database View
Not included
Included
Included
Delete
Included
Included
Included
Delete Identical
Included
Included
Included
Delete Multiple
Included
Included
Included
Disable Last Edit Time
Not included
Included
Included
Enable Last Edit Time
Not included
Included
Included
Extract Data From Geodatabase
Not included
Included
Included
Find Identical
Included
Included
Included
Merge
Included
Included
Included
Rename
Included
Included
Included
Sort
With ArcGIS Pro Basic and ArcGIS Pro Standard, you will only be allowed to sort on one attribute field. To sort on the geometry field or multiple fields, you need ArcGIS Pro Advanced.
Limited
Limited
Included
Transfer Files
Included
Included
Included
Upload File To Portal
Included
Included
Included
Generalization toolset
Dissolve
Included
Included
Included
Eliminate
Not included
Not included
Included
Eliminate Polygon Part
Not included
Not included
Included
Geodatabase Administration toolset
Analyze Datasets
Not included
Included
Included
Change Privileges
Not included
Included
Included
Compress
Not included
Included
Included
Configure Geodatabase Log File Tables
Not included
Included
Included
Create Database Sequence
Not included
Included
Included
Create Database User
Not included
Included
Included
Create Enterprise Geodatabase
Not included
Included
Included
Create Role
Not included
Included
Included
Delete Database Sequence
Not included
Included
Included
Delete Schema Geodatabase
Not included
Included
Included
Diagnose Version Metadata
Not included
Included
Included
Diagnose Version Tables
Not included
Included
Included
Enable Enterprise Geodatabase
Not included
Included
Included
Export Geodatabase Configuration Keywords
Not included
Included
Included
Import Geodatabase Configuration Keywords
Not included
Included
Included
Migrate Object ID To 64 Bit
Included
Included
Included
Migrate Storage
Not included
Included
Included
Rebuild Indexes
Not included
Included
Included
Register With Geodatabase
Not included
Included
Included
Repair Version Metadata
Not included
Included
Included
Repair Version Tables
Not included
Included
Included
Update Enterprise Geodatabase License
Not included
Included
Included
Update Portal Dataset Owner
Not included
Included
Included
Upgrade Dataset
ArcGIS Desktop Standard or Desktop Advanced license is required to upgrade mosaic datasets.
Included
Included
Included
Upgrade Geodatabase
Only file geodatabases can be upgraded at the Basic license level. ArcGIS Desktop Standard or Desktop Advanced license is required to upgrade enterprise geodatabases.
Limited
Included
Included
Indexes toolset
Add Attribute Index
Included
Included
Included
Add Full-Text Index
Included
Included
Included
Add Spatial Index
Included
Included
Included
Remove Attribute Index
Included
Included
Included
Remove Spatial Index
Included
Included
Included
Joins and Relates toolset
Add Join
Included
Included
Included
Add Relate
Included
Included
Included
Add Spatial Join
Included
Included
Included
Join Field
Included
Included
Included
Remove Join
Included
Included
Included
Remove Relate
Included
Included
Included
Validate Join
Included
Included
Included
LAS Dataset toolset
Add Files To LAS Dataset
Requires 3D Analyst or Spatial Analyst
Included
Included
Build LAS Dataset Pyramid
Included
Included
Create LAS Dataset
Included
Included
LAS Dataset Statistics
Included
Included
LAS Point Statistics As Raster
Included
Included
Project LAS
Included
Included
Remove Files From LAS Dataset
Included
Included
Layers and Table Views toolset
Apply Symbology From Layer
Included
Included
Included
Generate Definition Query From Selection
Included
Included
Included
Make Aggregation Query Layer
Not included
Not included
Included
Make Building Layer
Included
Included
Included
Make Feature Layer
Included
Included
Included
Make Image Server Layer
Included
Included
Included
Make LAS Dataset Layer
Included
Included
Included
Make Mosaic Layer
Included
Included
Included
Make Query Layer
Included
Included
Included
Make Query Table
Included
Included
Included
Make Raster Layer
Included
Included
Included
Make Scene Layer
Included
Included
Included
Make Table View
Included
Included
Included
Make TIN Layer
Included
Included
Included
Make Trajectory Layer
Not included
Included
Included
Make WCS Layer
Included
Included
Included
Make XY Event Layer
Included
Included
Included
Match Layer Symbology To A Style
Included
Included
Included
Save To Layer File
Included
Included
Included
Select Layer By Attribute
Included
Included
Included
Select Layer By Location
Included
Included
Included
Layout toolset
Export Layouts
Included
Included
Included
Package toolset
Consolidate Layer
Included
Included
Included
Consolidate Locator
Included
Included
Included
Consolidate Map
Included
Included
Included
Consolidate Project
Included
Included
Included
Consolidate Toolbox
Included
Included
Included
Create Map Tile Package
Included
Included
Included
Create Mobile Map Package
Some parameters are limited by the Publisher extension—see the tool reference page for more detail.
Limited
Limited
Limited
Create Mobile Scene Package
Limited
Limited
Limited
Create Vector Tile Index
Included
Included
Included
Create Vector Tile Package
Included
Included
Included
Extract Package
Included
Included
Included
Package 3D Tiles
Included
Included
Included
Package Layer
Included
Included
Included
Package Locator
Included
Included
Included
Package Map
Included
Included
Included
Package Project
Included
Included
Included
Package Result
Included
Included
Included
Share Package
Included
Included
Included
Package/Scene Layers toolset
Create 3D Object Scene Layer Content
Included
Included
Included
Create Building Scene Layer Content
Included
Included
Included
Create Integrated Mesh Scene Layer Content
Included
Included
Included
Create Point Cloud Scene Layer Content
Included
Included
Included
Create Point Scene Layer Content
Included
Included
Included
Create Voxel Scene Layer Content
Included
Included
Included
Generate Level Of Detail
Included
Included
Included
Upgrade Scene Layer
Included
Included
Included
Validate Scene Layer
Included
Included
Included
Photos toolset
GeoTagged Photos To Points
Included
Included
Included
Match Photos To Rows By Time
Included
Included
Included
Projections and Transformations toolset
Batch Project
Included
Included
Included
Convert Coordinate Notation
Included
Included
Included
Create Custom Geographic Transformation
Included
Included
Included
Create Custom Vertical Transformation
Included
Included
Included
Create Spatial Reference
Included
Included
Included
Define Projection
Included
Included
Included
Project
Included
Included
Included
Projections and Transformations/Raster toolset
Flip
Included
Included
Included
Mirror
Included
Included
Included
Project Raster
Included
Included
Included
Register Raster
Included
Included
Included
Rescale
Included
Included
Included
Rotate
Included
Included
Included
Shift
Included
Included
Included
Warp
Included
Included
Included
Warp From File
Included
Included
Included
Raster/Mosaic Dataset toolset
Add Rasters To Mosaic Dataset
Not included
Included
Included
Alter Mosaic Dataset Schema
Not included
Included
Included
Analyze Mosaic Dataset
Not included
Included
Included
Build Boundary
Not included
Included
Included
Build Footprints
Not included
Included
Included
Build Mosaic Dataset Item Cache
Not included
Included
Included
Build Overviews
Not included
Included
Included
Build Seamlines
Not included
Included
Included
Calculate Cell Size Ranges
Not included
Included
Included
Clear Pixel Cache
Included
Included
Included
Color Balance Mosaic Dataset
Not included
Included
Included
Compute Dirty Area
Not included
Included
Included
Compute Mosaic Candidates
Not included
Included
Included
Create Mosaic Dataset
Not included
Included
Included
Create Referenced Mosaic Dataset
Not included
Included
Included
Define Mosaic Dataset NoData
Not included
Included
Included
Define Overviews
Not included
Included
Included
Delete Mosaic Dataset
Not included
Included
Included
Edit Raster Function
Not included
Included
Included
Export Mosaic Dataset Geometry
Not included
Included
Included
Export Mosaic Dataset Items
Not included
Included
Included
Export Mosaic Dataset Paths
Not included
Included
Included
Generate Exclude Area
Not included
Included
Included
Generate Raster Collection
Included
Included
Included
Import Mosaic Dataset Geometry
Not included
Included
Included
Merge Mosaic Dataset Items
Not included
Included
Included
Mosaic Dataset To Mobile Mosaic Dataset
Included
Included
Included
Remove Rasters From Mosaic Dataset
Not included
Included
Included
Repair Mosaic Dataset Paths
Not included
Included
Included
Set Mosaic Dataset Properties
Not included
Included
Included
Split Mosaic Dataset Items
Not included
Included
Included
Synchronize Mosaic Dataset
Not included
Included
Included
Raster/Ortho Mapping toolset
Analyze Control Points
Not included
Included
Included
Append Control Points
Not included
Included
Included
Apply Block Adjustment
Not included
Included
Included
Build Stereo Model
Included
Included
Included
Compute Block Adjustment
Requires the ArcGIS Desktop Advanced license when the Transformation Type value is set to RPC or Frame.
Not included
Requires ArcGIS Reality for ArcGIS Pro
Included
Compute Camera Model
Not included
Included
Compute Control Points
Not included
Included
Included
Compute Depth Map
Not included
Included
Compute Fiducials
Not included
Included
Compute Tie Points
Not included
Included
Included
Export Frame And Camera Parameters
Included
Included
Included
Generate Block Adjustment Report
Included
Included
Included
Generate Point Cloud
Not included
Included
Interpolate From Point Cloud
Not included
Included
Match Control Points
Not included
Included
Included
Remove Depth Map
Not included
Included
Update Interior Orientation
Not included
Included
Raster/Raster Dataset toolset
Copy Raster
Included
Included
Included
Create Random Raster
Included
Create Raster Dataset
Included
Included
Included
Download Rasters
Included
Included
Included
Generate Raster From Raster Function
Included
Included
Included
Mosaic
Included
Included
Included
Mosaic To New Raster
Included
Included
Included
Workspace To Raster Dataset
Included
Included
Included
Raster/Raster Processing toolset
Clip Raster
Included
Included
Included
Composite Bands
Included
Included
Included
Compute Pansharpen Weights
Included
Included
Included
Create Color Composite
Included
Included
Included
Create Ortho Corrected Raster Dataset
Included
Included
Included
Create Pansharpened Raster Dataset
Included
Included
Included
Extract Subdataset
Included
Included
Included
Generate Table From Raster Function
Included
Included
Included
Raster To DTED
Included
Included
Included
Resample
Included
Included
Included
Split Raster
Included
Included
Included
Raster/Raster Properties toolset
Add Colormap
Included
Included
Included
Batch Build Pyramids
Included
Included
Included
Batch Calculate Statistics
Included
Included
Included
Build Pyramids
Included
Included
Included
Build Pyramids And Statistics
Included
Included
Included
Build Raster Attribute Table
Included
Included
Included
Included
Included
Included
Convert Raster Function Template
Included
Included
Included
Delete Colormap
Included
Included
Included
Delete Raster Attribute Table
Included
Included
Included
Export Raster World File
Included
Included
Included
Get Cell Value
Included
Included
Included
Get Raster Properties
Included
Included
Included
Set Raster Properties
Included
Included
Included
Relationship Classes toolset
Add Rule To Relationship Class
Included
Included
Included
Create Relationship Class
Included
Included
Included
Migrate Relationship Class
Included
Included
Included
Remove Rule From Relationship Class
Included
Included
Included
Set Relationship Class Split Policy
Included
Included
Included
Table To Relationship Class
Included
Included
Included
Reports toolset
Export Report To Excel
Included
Included
Included
Export Report To PDF
Included
Included
Included
Sampling toolset
Create Fishnet
Included
Included
Included
Create Random Points
Included
Included
Included
Create Spatial Sampling Locations
Included
Included
Included
Create Spatially Balanced Points
Requires Geostatistical Analyst
Included
Generate Points Along Lines
Included
Included
Included
Generate Rectangles Along Lines
Included
Included
Included
Generate Tessellation
Included
Included
Included
Generate Transects Along Lines
Included
Included
Included
Subset Features
Included
Included
Included
Spectral Library toolset
Resample Library Spectra
Included
Included
Included
Subtypes toolset
Add Subtype
Included
Included
Included
Alter Subtype
Included
Included
Included
Remove Subtype
Included
Included
Included
Set Default Subtype
Included
Included
Included
Set Subtype Field
Included
Included
Included
Table toolset
Analyze
Not included
Included
Included
Copy Rows
Included
Included
Included
Create Table
Included
Included
Included
Create Unregistered Table
Included
Included
Included
Delete Rows
Included
Included
Included
Get Count
Included
Included
Included
Pivot Table
Not included
Not included
Included
Transpose Fields
Included
Included
Included
Truncate Table
Included
Included
Included
Tile Cache toolset
Export Tile Cache
Included
Included
Included
Generate Tile Cache Tiling Scheme
Included
Included
Included
Import Tile Cache
Included
Included
Included
Manage Tile Cache
Included
Included
Included
Toolbox toolset
Analyze Toolbox For Version
Included
Included
Included
Analyze Tools For Pro
Included
Included
Included
Save Toolbox To Version
Included
Included
Included
Topology toolset
Add Feature Class To Topology
Not included
Included
Included
Add Rule To Topology
Not included
Included
Included
Create Topology
Not included
Included
Included
Export Topology Errors
Included
Included
Included
Remove Feature Class From Topology
Not included
Included
Included
Remove Rule From Topology
Not included
Included
Included
Set Cluster Tolerance
Not included
Included
Included
Validate Topology
Limited
Included
Included
Trajectory Dataset toolset
Add Data To Trajectory Dataset
Not included
Included
Included
Create Trajectory Dataset
Not included
Included
Included
Repair Trajectory Dataset Paths
Not included
Included
Included
Versions toolset
Add Field Conflict Filter
Not included
Included
Included
Alter Version
Supported for branch versioning when using named user licensing.
Limited
Included
Included
Change Version
Limited
Included
Included
Create Version
Limited
Included
Included
Delete Version
Limited
Included
Included
Prune Branch History
Not included
Included
Included
Reconcile Versions
Limited
Included
Included
Register As Versioned
Not included
Included
Included
Remove Field Conflict Filter
Not included
Included
Included
Unregister As Versioned
Not included
Included
Included
Workspace toolset
Clear Workspace Cache
Included
Included
Included
Compare Schema
Included
Included
Included
Convert Schema Report
Included
Included
Included
Create Cloud Storage Connection File
Included
Included
Included
Create Database Connection
Not included
Included
Included
Create Database Connection String
Included
Included
Included
Create Feature Dataset
Included
Included
Included
Create File Geodatabase
Included
Included
Included
Create Folder
Included
Included
Included
Create Mobile Geodatabase
Included
Included
Included
Create Parquet Cache
Included
Included
Included
Create Spatial Type
Not included
Included
Included
Create SQLite Database
Included
Included
Included
Enable Editing Templates
Not included
Included
Included
Export XML Workspace Document
Included
Included
Included
Generate Schema Report
Included
Included
Included
Import XML Workspace Document
Included
Included
Included
Refresh Excel
Included
Included
Included
Update Geodatabase Connection Properties To Branch
Not included
Included
Included
